client side image map: classitem [solved]
Dylan Beaudette
dylan at IICI.NO-IP.ORG
Fri Jul 22 17:40:08 EDT 2005
Bob,
Since that message I have found the problem. thanks!
On Friday 22 July 2005 12:48 pm, Bob Bruce wrote:
> Dylan:
> I just had a look at your page that was in your post and the map
> looks just fine. The <map has all of the areas labeled with their names and
> clicking on the areas does the alert with the name. What is the problem?
> Bob Bruce, Winnipeg, Manitoba
> http://www.hwps.ca
> On Thu, 21 Jul 2005 15:53:05 -0700, Dylan Beaudette <dylan at IICI.NO-IP.ORG>
> wrote:
> >Greetings,
> >I have recently set up a working version of the image map example provided
> > on the mapserver wiki here:
> >http://169.237.35.250/~dylan/mapserver/dhtml/image_map_test.php
> >However, the polygons are labeled as 0,1,2,3 ... is there some way for the
> >image map to be constructed using an attribute in the original data
> > source?
> >Per Jim Donaghy's suggestion, I have tried adding CLASSITEM "NAME" to my
> >mapfile, but it does not seem to affect the resulting image map...
> >any ideas?
> >Dylan Beaudette
> >Soils and Biogeochemistry Graduate Group
> >University of California at Davis
> >530.754.7341
> Dylan:
Dylan Beaudette
530.754.7341
