Installing Java MapScript on Windows
Ajay Ranipeta
sc0rp10nau at YAHOO.COM.AU
Sun Jul 24 07:31:57 EDT 2005
Hi Bas,
Did you try the comment part at the
http://ms.gis.umn.edu/docs/howto/java_mapscript_Tomcat_55 webpage? Follow
that, and you should be set.
Basically, make sure the files are under the C:\mapserver, make sure the
folder is part of the System Environment path, and you should be ok.
cheers,
Ajay
On Fri, 22 Jul 2005 11:53:03 +0200, Bas Vanmeulebrouk
<bvanmeul at EBE.UCT.AC.ZA> wrote:
>Hi list,
>I am trying to install Java MapScript on a Windows XP Professional machine.
>I have downloaded a binary from http://hobu.stat.iastate.edu/mapserver/.
>When I try to load the MapScript dll in my Java class, it causes the
>following error: The procedure entry point CPLGetLastErrorMsg could not be
>located in the dynamic link library gdal12.dll and then Exception in thread
>"main" java.lang.UnsatisfiedLinkError: C:\Program
>Files\MapServer\JavaMapScript\mapscript.dll: The specified procedure could
>not be found.
>I assume mapscript.dll can't find the additional dll's like gdal12.dll. I am
>positive there is only one instance of these dll's on my machine. I have
>tried to set the PATH environment variable and I have put all the dll's in
>the same directory as my Java class, none of which seem to work. Does anyone
>know how to solve this problem? I have read the instructions on
>http://ms.gis.umn.edu/docs/howto/java_mapscript_Tomcat_55 and the MapServer
>wiki, but these don't seem to help.
>The binary also contains a mapserv.exe CGI executable and this one is
>working fine, both mapserv.exe -v and when I invoke it through a webbrowser.
>Kind regards,
>Bas Vanmeulebrouk.
>import java.io.IOException;
>import edu.umn.gis.mapscript.*;
>public class myFirstMapMain {
> public static void main(String[] args) throws IOException {
> mapObj map = new mapObj("c:\\temp\\test.map");
> imageObj image = map.draw();
> image.save("c:\\temp\\test.png", map);
