ogr2ogr with file list
Bill Binko
bill at BINKO.NET
Tue Jul 26 13:49:09 EDT 2005
What Operating System (and which Shell -- if Linux/Unix) are you using?
If you're using Linux and bash (or something similar), you can do this:
(Assuming list.in has a list of input filenames in it)
for i in `cat list.in`; do ogr2ogr $i output_$i -t_srs WGS84 ; done
Probably easier for automation would be to put all of your "input"
shapefiles in an input directory and create an empty output directory.
Then run something like this:
for i in input/*.shp; do ogr2ogr $i output/`basename $i` -t_srs
WGS84; done
Hope this helps.
Bill
On Tue, 26 Jul 2005, Yar Doroshenko wrote:
> Hi Guys,
> I'm working on automating my shapefile coordinate conversions. I know how
> to do single file conversion:
> ogr2ogr input.shp output.shp -t_srs WGS84
> Now, can I automate the process? Let's say I have a list of shapefiles that
> I want to convert, would I do something like:
> for %f in (path_here\list.in) do ogr2ogr %f
> I tried this one in many different ways, but I do get errors.
> Would anyone have a correct syntax for multiple file conversions?
> Thank you
> Yar
