Vewing Image in "Browse" mode
Jacob Delfos
jacob.delfos at MAUNSELL.COM
Tue Jul 26 23:29:59 EDT 2005
Kichi,
Please check out the following line:
<input type="image" name="img"src="\mapexamples\temp\" width="800" height="900">
The src of the image should point to the map image. So set the src as follows:
SRC="[img]"
The [img] will be substituted with the URL. Also make sure there is a space between "img" and src, because it doesn't like like you have it.
regards,
Jacob
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On Behalf Of krishnaa sridharan
Sent: 27 July 2005 11:15
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: [UMN_MAPSERVER-USERS] Vewing Image in "Browse" mode
Hi all,
I am a new user of mapserver and was going throught the tutorial in the documentation section.
When i was trying create a html file which display the map in the browse mode, I am not able to view the image though mapserver creates temporary PNG files in the directory were i wanted it too. I tried opening the map in 'map' mode and i could get the image .
here is my html code
<form name="mapserv" method="GET" action="/cgi-bin/mapserv.exe">
<!-- HIDDEN MAPSERVER CGI VARIABLES -->
<input type="hidden" name="map" value="\mapexamples\1.map">
<input type="hidden" name="imgext" value="-2217.186321 -3797.903064 1468.370211 -24.437500">
<input type="hidden" name="imgxy" value="800 900">
<input type="hidden" name="zoom" value="0">
<input type="hidden" name="layer" value="SID">
<input type="hidden" name="mode" value="BROWSE">
<div align="center">
<table border="1" cellpadding="0" cellspacing="0">
<tr>
<td>
<!-- THE INTERACTIVE, DYNAMICALLY CREATED MAP -->
</td>
</tr>
</table>
</div>
</form>
I am sure the mapserver initiates well as it creates temp images. I also made sure that the folder had full read/write acess. this is the map file i tried to acess.
MAP
IMAGETYPE PNG24
EXTENT -2217.186321 -3797.903064 1468.370211 -24.437500
SIZE 800 900
SHAPEPATH "\data"
IMAGECOLOR 251 251 251
SYMBOLSET "\symbols\SYMBOLS35.SYM"
WEB
TEMPLATE '\mapexamples\map1.html'
IMAGEPATH '\mapexamples\temp\'
IMAGEURL '\mapexamples\temp\'
END
LAYER
NAME SID
DATA Da06
STATUS on
END
Please help!
Thanks for your help in advance
Kichi
JACOB DELFOS
SPATIAL INFORMATION ANALYST
Maunsell Australia Pty Ltd
629 Newcastle Street, WA 6007
PO Box 81, WA 6902
Leederville
Western Australia
ABN 20 093 846 925
Tel + 61 8 9281 6185
Fax + 61 8 9281 6297
jacob.delfos at maunsell.com
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20050727/65a2474c/attachment.html
