How to draw simple closed polygons at the client side ?
Pierre GIRAUD
bluecarto at GMAIL.COM
Thu Jul 28 05:53:54 EDT 2005
Sure it is possible.
Using walterzorn drawing API is a good way for this.
If you take a look at the Cartoweb online demo, you'll find a first
sample of polygon drawing with the polygon outline or measure surface
tools.
At this time, we are redevelopping this in an API, in order to give
the user a real editing interface. People will be able to draw, move
features, add, move, delete vertices (with simple snapping functions).
In this API, polygons are filled and I suppose they suit your needs.
regards
Pierre GIRAUD
On 7/27/05, Richard Roger <richard.roger at agric.nsw.gov.au> wrote:
> Dear List
> I am after some advice, please. I want to know a good way to draw simple
> polygons (simply-connected polygons with no sides crossing each other) on
> the client side in a web browser. I see that Rosa does ellipses and
> polylines - does "polyline" in Rosa mean a closed polygon as it does in
> Mapserver? What about jbox? Geotools looks as if it might be a bit heavy.
> And I suppose that one could build upon Javascript "vectorgraphics" (e.g.,
> the www.walterzorn.com/jsgraphics library or www.karlson.ru/jsgraphics ).
> Any advice gratefully received.
> Cheers
> Richard E. Roger
> Dr. R. E. Roger NSW Department of
> Primary Industries
> Spatial Information Officer Systems 161 Kite St
> Resource Information Unit Locked Bag 21
> ORANGE NSW 2800
> ph: (02) 6391 3697 fax: (02) 6391 3740
> This message is intended for the addressee named and may contain
> confidential information. If you are not the intended recipient or received
> it in error, please delete the message and notify sender. Views expressed
> are those of the individual sender and are not necessarily the views of
> their organisation.
