PerlMapScript Testers Needed NOW
Lowell Filak
lfilak at MEDINACO.ORG
Wed Jun 1 08:27:39 EDT 2005
The following message was sent by Sean Gillies <sgillies at FRII.COM> on
Tue, 31 May 2005 16:06:09 -0600.
> On May 31, 2005, at 3:23 PM, Lowell Filak wrote:
> > Hello all,
> > The SWIG typemap for imageObj->write is ready for testing at:
> > http://www.highwayengineer.co.medina.oh.us/temp/mapscript.tar.gz
> > There are 3 files included:
> > medina1.patch - the patch file containing the code changes.
> > medina1_autogen.patch - the patch file containing changes to the SWIG
> > output if you don't feel like re-SWIG'ing yourself.
> > nonwrite.cgi - sample code for using the 'write' method in both GD:: &
> > Image::Magick.
> > Requirements:
> > Mapserver & MapScript 4.4.2.
> > Perl 5.8.0 + (this uses PerlIO vs. stdio).
> > Thanks go to the Steve Lime, MS-team(et. al.), Sean Gillies, & Chip
> > Salzenberg.
> > Lowell
> > P.S. The changes for map->processXTemplate are also included but I have
> > not tested those yet.
> Well, better late than never ;) Create a bug in our bugzilla and let's
> get this done. Better if this is tested against MapServer 4.6 beta 3 if
> y'all want this in the next big release.
Sean,
The bug posting should go in today.
Thanks.
Lowell
