tileindex and sequence/level
Bart van den Eijnden
bartvde at XS4ALL.NL
Wed Jun 1 15:13:49 EDT 2005
Hi list,
I want to use gdaltindex to create a tileindex for rasters. The rasters do
overlap, so I wanted to add an extra column to the generated tileindex
with a display level. The higher the level, the more on top the raster
should be, if they do overlap.
Would sorting the generated tileindex with sortshp work? Would I need to
sort ascending or descending? Ie in what sequence are the individual
rasters drawn?
Is adding a level column to the tileindex a good solution or can other
(better) approaches be followed?
Thanks in advance.
Best regards,
Bart
Using Opera's revolutionary e-mail client: http://www.opera.com/mail/
