Getting MapServer working (PHP MapScript)
Bill Binko
bill at BINKO.NET
Wed Jun 1 18:31:50 EDT 2005
No Problem
(Daniel, remind me to fix more of his bugs)
Bill
On Wed, 1 Jun 2005, Abe Gillespie wrote:
> beta3 works! Thank you so much you geniui!
> -Abe
> On 6/1/05, Abe Gillespie <abe.gillespie at gmail.com> wrote:
> > I build both PHP and MapServer from source. But I'll start with
> > upgrading to MS 4.6. I'll let you know.
> > Thanks for the help!
> > -Abe
> > > > Shall I build PHP or MapServer from source?
> > > You should build MapServer from source. Ideally, you should build CVS
> > > HEAD or the latest beta ( 4.6Beta3 ?).
> > > If your PHP Header files are in /usr/include/php, then all you should have
> > > to do is configure with --with-php=/usr and it should detect everything
> > > for PHP. Of course, depending on what else you're using (GDAL, OGR, WMS,
> > > WFS, etc, etc) there are other configure options you'll need.
> > > If you don't build from source right now, perhaps a 4.6beta3 binary is
> > > available (?).
> > > Unfortunately, you are probably in exactly the position I was in when I
> > > decided to tackle this bug: I had a binary PHP that I didn't want to mess
> > > with that was built with the PHP regex. Older versions of Mapserver just
> > > don't play nicely that way. That's what the fix is about: it allows you
> > > to build against a binary PHP (assuming you have the include files) and
> > > uses the right regex.
> > > The good news for you is that there IS a fix now, and "all" you have to do
> > > is build Mapserver 4.6beta from source.
> > > Bill
