Getting MapServer working (PHP MapScript)
Bill Binko
bill at BINKO.NET
Wed Jun 1 15:41:03 EDT 2005
Abe,
Sorry I'm coming in late on this... what versions of Mapserver/PHP/OS are
you running? Also, could you run this command:
echo "<? phpinfo(); ?>" | php
Daniel and I have been fixing a problem that can cause this under certain
circumstances. (You can play along at home at bug 1354 in the Mapserver
bugzilla database).
If you can, it would be helpful to run your script under GDB and send the
stack trace where the seg fault occurs.
Bill
On Wed, 1 Jun 2005, Abe Gillespie wrote:
> Ok, it simply Seg Faults at the ms_newMapObj().
> -Abe
> On 6/1/05, Abe Gillespie <abe.gillespie at gmail.com> wrote:
> > Never mind. -f switch. Cool!
> > -Abe
> > > That sounds like an excellent idea ... how do I do that? :)
> > > -Abe
> > > On 6/1/05, Camden Daily <cdaily at gmail.com> wrote:
> > > > Perhaps try running the script from the command line? That would at
> > > > least take Apache out of the picture, and error messages might get
> > > > displayed.
> > > > -Camden
