Getting MapServer working (PHP MapScript)
Abe Gillespie
abe.gillespie at GMAIL.COM
Wed Jun 1 16:00:12 EDT 2005
I'll look into doing the other items later. The output of phpinfo()
is attached.
How can I run under GDB?
Thanks.
-Abe
On 6/1/05, Bill Binko <bill at binko.net> wrote:
> Abe,
> Sorry I'm coming in late on this... what versions of Mapserver/PHP/OS are
> you running? Also, could you run this command:
> echo "<? phpinfo(); ?>" | php
> Daniel and I have been fixing a problem that can cause this under certain
> circumstances. (You can play along at home at bug 1354 in the Mapserver
> bugzilla database).
> If you can, it would be helpful to run your script under GDB and send the
> stack trace where the seg fault occurs.
> Bill
> On Wed, 1 Jun 2005, Abe Gillespie wrote:
> > Ok, it simply Seg Faults at the ms_newMapObj().
> > -Abe
> > On 6/1/05, Abe Gillespie <abe.gillespie at gmail.com> wrote:
> > > Never mind. -f switch. Cool!
> > > -Abe
> > > > That sounds like an excellent idea ... how do I do that? :)
> > > > -Abe
> > > > On 6/1/05, Camden Daily <cdaily at gmail.com> wrote:
> > > > > Perhaps try running the script from the command line? That would at
> > > > > least take Apache out of the picture, and error messages might get
> > > > > displayed.
> > > > > -Camden
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20050601/e7d48c44/phpinfo.html
