Getting MapServer working (PHP MapScript)
Abe Gillespie
abe.gillespie at GMAIL.COM
Wed Jun 1 17:07:03 EDT 2005
Shall I build PHP or MapServer from source?
Thanks.
-Abe
On 6/1/05, Bill Binko <bill at binko.net> wrote:
> On Wed, 1 Jun 2005, Abe Gillespie wrote:
> > I'll look into doing the other items later. The output of phpinfo()
> > is attached.
> > How can I run under GDB?
> Assuming Linux (YMMV)
> Make sure that your PHP library path is in your LD_LIBRARY_PATH:
> $ export LD_LIBRARY_PATH=/usr/lib/php/extenions:$LD_LIBRARY_PATH
> $ gdb php
> <startup text, loading symbols etc.>
> {gdb} run yourfile.php
> <error saying SIGSEGV occurred>
> (gdb) bt
> <backtrace of error> <-- Cut and paste this
> If this doesn't work, contact Daniel and I offline and we'll work with
> you. It looks to me like you're using a PHP that uses their internal
> regex methods. This can cause a great deal of pain up until very
> recently. However, a recent CVS build may solve this for you. Do you
> build from source?
> Bill
> > Thanks.
> > -Abe
> > > Abe,
> > > Sorry I'm coming in late on this... what versions of Mapserver/PHP/OS are
> > > you running? Also, could you run this command:
> > > echo "<? phpinfo(); ?>" | php
> > > Daniel and I have been fixing a problem that can cause this under certain
> > > circumstances. (You can play along at home at bug 1354 in the Mapserver
> > > bugzilla database).
> > > If you can, it would be helpful to run your script under GDB and send the
> > > stack trace where the seg fault occurs.
> > > Bill
> > > > Ok, it simply Seg Faults at the ms_newMapObj().
> > > > -Abe
> > > > On 6/1/05, Abe Gillespie <abe.gillespie at gmail.com> wrote:
> > > > > Never mind. -f switch. Cool!
> > > > > -Abe
> > > > > > That sounds like an excellent idea ... how do I do that? :)
> > > > > > -Abe
> > > > > > On 6/1/05, Camden Daily <cdaily at gmail.com> wrote:
> > > > > > > Perhaps try running the script from the command line? That would at
> > > > > > > least take Apache out of the picture, and error messages might get
> > > > > > > displayed.
> > > > > > > -Camden
