PostGIS vs. MySQL spatial in MapServer
Klaus Benndorf
benndorf at MAIL.BT-GIS.DE
Thu Jun 2 04:13:43 EDT 2005
as Arnulf wrote, we built myWMS as we needed special carthographic functions
for our german customers. But as so often, you do much more than intended
when starting the project. Meanwhile myWMS is a complete map server that
covers a lot of functionality described by OGC/WMS.
We decided to use MySQL, as many of our customers already worked with it. But
myWMS does not strictly depend on MySQL. As a Java servlet, using JDBC, you
should be able to connect to PostGIS as well. Maybe it takes some adjustments
in SQL statements, but I don't think it is too much.
If you compare PostGIS and MySQL, you see, that MySQL offers not so many
functions and some of them are only working on the bounding box of an object.
But it is enough for what we want to do with myWMS.
Looking at the performance, MySQL seems to be excellent. We tested the import
of about 3 Million objects and MySQL was about 30% faster than PostGIS. Maybe
thats due to the fact, that MySQL implements spatial objects in MYISAM , not
in INNODB. MYISAM does not know transactions. So it is very lean and fast.
Also the spatial index in MySQL seems to work excellent. We could not find any
performance leak, i.e. depending on the number of objects, the size of the
database, or the number of concurrent accesses.
I'm going to describe more technical background on myWMS website
(http://www.bt-gis.de/mywms), but it takes a while. Unfortunately we don't
have an english website yet, but I am working on it. Hope it will be
available in about 2 weeks.
Klaus
Am Mittwoch, 1. Juni 2005 14:53 schrieb Arnulf Christl:
> Kralidis,Tom [Burlington] wrote:
> > Hi,
> > Can someone point me to some comparisons of the spatial functionality of
> > these packages?
> > Thanks
> > ..Tom
> > Tom Kralidis
> > Senior Systems Scientist
> > Environment Canada
> > Tel: +01-905-336-4409
> > http://www.ec.gc.ca/
> Just to add to the confusion... there is a project called MyWMS which
> has been implemented by Klaus Benndorf (all in German:
> http://www.bt-gis.de) in cooperation with MySQL AB.
> There is a case study (very short, German language):
> http://www.mysql.de/it-resources/case-studies/mysql-bt-gis-anwenderbericht.
>pdf
> It states that MyWMS is OGC WMS compliant (it probably should say
> implementing) and uses some MySQL "spatial operations".
> The proprietary forerunner GISeye contains a very powerful rendering
> engine which can handle the cartographic wilderness that German
> cadastral maps boast (Steve added some of this functionality to
> MapServer last year). It will be (was, is) released under the GNU/GPL
> with a dual licensing simliar to that by MySQL AB.
> i did not yet have time to dig into it. If you are interested in
> internal details of MySQL spatial functionality probably Klaus will know
> best.
BT-GIS
Klaus Benndorf
Kessenicher Straße 108
53129 Bonn
Telefon 0049228 978510
Fax 0049228 9785111
Mail benndorf at mail.bt-gis.de
WWW http://www.bt-gis.de
