displaying multiple points from database using phpmapscript
Camden Daily
cdaily at GMAIL.COM
Thu Jun 2 13:08:24 EDT 2005
Here's the function I use:
function add_point_to_layer($layer, $longitude, $latitude) {
// create and initialize new point object
$point = ms_newPointObj();
$point->setXY($longitude, $latitude);
// create and initialize new line object
$line = ms_newLineObj();
$line->add($point);
// create and initialize new shape object
$shape = ms_newShapeObj(MS_SHAPE_POINT);
$shape->add($line);
// add our shape
$layer->addFeature($shape);
In your code, you might use it like this:
$layer = $map->getLayerByName('POINTLOC');
for ($j=0; $j < mysql_num_rows($reStation); $j++) {
$row = mysql_fetch_assoc($reStation);
add_point_to_layer($layer, $row["x"], $row["y"])
$url = $img->saveWebImage();
That code works if the points are already in geographic (long/lat)
coordinates. You'll have to play with things a bit since yours are in
pixel coordinates, but that at least shows how to use the addFeature
to add points to your map.
-Camden Daily
Prudential Preferred Properties
http://www.prupref.com
