multiple join - shp to dbf
Gambin Dejan Dejan.Gambin at PULA.HR
Thu Jun 2 23:59:33 PDT 2005
I am using CONNECTIONTYPE OGR and it works fine but this is for
one-to-one join. I had some problems with JOIN clause in map file so I
used OGR joins. I suppose this won't help you cause it seems only joins
using JOIN clause in map file can be used for one-to-many joins. But I
am not much experienced so I hope you will get some better answer
regards, dejan
-----Original Message-----
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On
Behalf Of william paul
Sent: Thursday, June 02, 2005 4:16 PM
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: Re: [UMN_MAPSERVER-USERS] multiple join - shp to dbf
Hi:
I want to join a shp file with a dbf file. It's ONE TO MANY join. I have
seen that more people have the same problem. Also I want to make a
classification based on the attributes from the DBF file. I tried with
OGR and JOIN OBJECT from Mapserver, but nothing
Does any one have a working example?
Thank you in advance
William
__________________________________________________
Do You Yahoo!?
Tired of spam? Yahoo! Mail has the best spam protection around
http://mail.yahoo.com
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20050603/b62708a4/attachment.htm>
More information about the MapServer-users mailing list
