multiple join - shp to dbf
Alberto Gomez
agomez at CCCMM.CESGA.ES
Fri Jun 3 00:19:22 PDT 2005
MessageHi Gambin,
I'm doing an one-to-one join with ogr conn too, but my problem is that my dbf file is in the server, not in the webserver. It tell me that is "Unable to open secondary datasource `z:/GIS/ESZBAT.DBF' required by JOIN". Is this your case?
Thanks in advance.
Alberto
----- Original Message -----
To: MAPSERVER-USERS at LISTS.UMN.EDU
Sent: Friday, June 03, 2005 8:59 AM
Subject: Re: [UMN_MAPSERVER-USERS] multiple join - shp to dbf
I am using CONNECTIONTYPE OGR and it works fine but this is for one-to-one join. I had some problems with JOIN clause in map file so I used OGR joins. I suppose this won't help you cause it seems only joins using JOIN clause in map file can be used for one-to-many joins. But I am not much experienced so I hope you will get some better answer
regards, dejan
-----Original Message-----
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On Behalf Of william paul
Sent: Thursday, June 02, 2005 4:16 PM
Hi:
I want to join a shp file with a dbf file. It's ONE TO MANY join. I have seen that more people have the same problem. Also I want to make a classification based on the attributes from the DBF file. I tried with OGR and JOIN OBJECT from Mapserver, but nothing
Does any one have a working example?
Thank you in advance
William
__________________________________________________
Do You Yahoo!?
Tired of spam? Yahoo! Mail has the best spam protection around
http://mail.yahoo.com
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20050603/9876fffc/attachment.htm>
More information about the MapServer-users
