perl wrapper redirs work great for WMS, bomb for WFS via .map
Charlton Purvis
cpurvis at ASG.SC.EDU
Fri Jun 3 09:22:26 EDT 2005
Hi, folks:
I think I mailed the list w/ this problem earlier, but I may have punted
trying to really buckle down and figure out what the issue was. Well,
it's back rearing its ugly face, and I have upgraded MS, GDAL, you name it
to make sure it wasn't a version issue.
I serve up in-situ weather data via WMS and WFS. So I wanted to make sure
that a client .map could get to my data via WFS to display it however they
wanted. Makes sense. Well, both the WMS and WFS services are perl
wrappers that do some magic and then redirect the request to a new URL.
WMS works splendidly, but WFS bombs by not following the new URL. Why is
there this difference?
Here is an example of a LAYER that should work and pull back air
temperatures as a bunch of ugly numbers on a map.
LAYER
NAME air_temperature
TYPE POINT
STATUS DEFAULT
CONNECTIONTYPE WFS
CONNECTION "http://nautilus.baruch.sc.edu/wfs/seacoos_in_situ?"
METADATA
"wfs_service" "WFS"
"wfs_typename" "air_temperature_obs_hourly"
"wfs_version" "1.0.0"
"wfs_request_method" "GET"
"wfs_connectiontimeout" "60"
END
PROJECTION
"init=epsg:4269"
END
LABELITEM "temperature_celcius"
CLASS
LABEL
TYPE BITMAP
SIZE SMALL
FORCE TRUE
COLOR 0 0 0
END
STYLE END
END
END
Running this through shp2img w/ the latest and greatest MS gives me:
msDrawMap(): Image handling error. Failed to draw layer
named 'air_temperature'.
msWFSLayerWhichShapes(): WFS connection error. Got HTTP status 302
downloading WFS layer air_temperature
msHTTPExecuteRequests(): HTTP request error. HTTP GET request failed with
status 302 () for http://nautilus.baruch.sc.edu/wfs/seacoos_in_situ?
&REQUEST=GetFeature&VERSION=1.0.0&SERVICE=WFS&TYPENAME=air_temperature_obs_
hourly&BBOX=-89,23.797368421052628,-79.849999999999994,31.502631578947373
But if you plug that URL into anything other than IE (IE for some reason
doesn't like it), you *do* get back valid GML because it does get rerouted
to a different URL.
Now if you're trying to ping my WFS services via anything other than
a .map, it works just find. GDAL => psql works great.
Any ideas?
Thanks mucho.
Charlton
