Error compiling gdal with ecw support
Stéphane MOREL
stephane.morel at VANOISE.COM
Fri Jun 3 06:32:55 PDT 2005
I try to compile gdal-cvs-2005.06.01 with ecw
support(ecwsdk-3.1.25jan05-linux). Configure works fine (./configure
--with-ecw=/opt/ecwsdk-3.1.25jan05-linux)
Make give the following error :
make[1]: Entering directory `/opt/gdal-cvs-2005.06.01'
GNUmakefile:43: warning: overriding commands for target `libgdal.la'
GNUmakefile:39: warning: ignoring old commands for target `libgdal.la'
/bin/sh ./libtool --mode=link g++ -ljasper -lm -ldl -o libgdal.la
./frmts/o/*.lo ./gcore/*.lo ./port/*.lo ./alg/*.lo
./ogr/ogrsf_frmts/o/*.lo ./ogr/ogrgeometryfactory.lo ./ogr/ogrpoint.lo
./ogr/ogrcurve.lo ./ogr/ogrlinestring.lo ./ogr/ogrlinearring.lo
./ogr/ogrpolygon.lo ./ogr/ogrutils.lo ./ogr/ogrgeometry.lo
./ogr/ogrgeometrycollection.lo ./ogr/ogrmultipolygon.lo
./ogr/ogrsurface.lo ./ogr/ogrmultipoint.lo ./ogr/ogrmultilinestring.lo
./ogr/ogr_api.lo ./ogr/ogrfeature.lo ./ogr/ogrfeaturedefn.lo
./ogr/ogrfeaturequery.lo ./ogr/ogrfeaturestyle.lo ./ogr/ogrfielddefn.lo
./ogr/ogrspatialreference.lo ./ogr/ogr_srsnode.lo ./ogr/ogr_srs_proj4.lo
./ogr/ogr_fromepsg.lo ./ogr/ogrct.lo ./ogr/ogr_opt.lo
./ogr/ogr_srs_esri.lo ./ogr/ogr_srs_pci.lo ./ogr/ogr_srs_usgs.lo
./ogr/ogr_srs_dict.lo ./ogr/swq.lo ./ogr/ogr_srs_validate.lo
./ogr/ogr_srs_xml.lo ./ogr/ograssemblepolygon.lo
./ogr/ogr2gmlgeometry.lo ./ogr/gml2ogrgeometry.lo \
-rpath /usr/local/lib \
-no-undefined \
-version-info 8:0:7
grep: /usr/lib/libjpeg.la: No such file or directory
/usr/bin/sed: can't read /usr/lib/libjpeg.la: No such file or directory
libtool: link: `/usr/lib/libjpeg.la' is not a valid libtool archive
make[1]: *** [libgdal.la] Error 1
make[1]: Leaving directory `/opt/gdal-cvs-2005.06.01'
make: *** [check-lib] Error 2
I also try to disable libtool but without success
my linux box : Suse 9.2
gcc 3.3.4
Thanks for any help.
Stéphane
Type: text/x-vcard
Desc: not available
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20050603/cdbd8d38/attachment.vcf>
More information about the MapServer-users
