Error compiling gdal with ecw support
Stéphane MOREL
stephane.morel at VANOISE.COM
Mon Jun 6 04:44:28 EDT 2005
I received an answer of a person of Veremes but I removed the mail
accidentally. Can you return it again to me please ?
TIA
Stéphane
Stéphane MOREL a écrit :
> Hi,
> I try to compile gdal-cvs-2005.06.01 with ecw
> support(ecwsdk-3.1.25jan05-linux). Configure works fine (./configure
> --with-ecw=/opt/ecwsdk-3.1.25jan05-linux)
> Make give the following error :
> make[1]: Entering directory `/opt/gdal-cvs-2005.06.01'
> GNUmakefile:43: warning: overriding commands for target `libgdal.la'
> GNUmakefile:39: warning: ignoring old commands for target `libgdal.la'
> /bin/sh ./libtool --mode=link g++ -ljasper -lm -ldl -o libgdal.la
> ./frmts/o/*.lo ./gcore/*.lo ./port/*.lo ./alg/*.lo
> ./ogr/ogrsf_frmts/o/*.lo ./ogr/ogrgeometryfactory.lo ./ogr/ogrpoint.lo
> ./ogr/ogrcurve.lo ./ogr/ogrlinestring.lo ./ogr/ogrlinearring.lo
> ./ogr/ogrpolygon.lo ./ogr/ogrutils.lo ./ogr/ogrgeometry.lo
> ./ogr/ogrgeometrycollection.lo ./ogr/ogrmultipolygon.lo
> ./ogr/ogrsurface.lo ./ogr/ogrmultipoint.lo ./ogr/ogrmultilinestring.lo
> ./ogr/ogr_api.lo ./ogr/ogrfeature.lo ./ogr/ogrfeaturedefn.lo
> ./ogr/ogrfeaturequery.lo ./ogr/ogrfeaturestyle.lo
> ./ogr/ogrfielddefn.lo ./ogr/ogrspatialreference.lo
> ./ogr/ogr_srsnode.lo ./ogr/ogr_srs_proj4.lo ./ogr/ogr_fromepsg.lo
> ./ogr/ogrct.lo ./ogr/ogr_opt.lo ./ogr/ogr_srs_esri.lo
> ./ogr/ogr_srs_pci.lo ./ogr/ogr_srs_usgs.lo ./ogr/ogr_srs_dict.lo
> ./ogr/swq.lo ./ogr/ogr_srs_validate.lo ./ogr/ogr_srs_xml.lo
> ./ogr/ograssemblepolygon.lo ./ogr/ogr2gmlgeometry.lo
> ./ogr/gml2ogrgeometry.lo \
> -rpath /usr/local/lib \
> -no-undefined \
> -version-info 8:0:7
> grep: /usr/lib/libjpeg.la: No such file or directory
> /usr/bin/sed: can't read /usr/lib/libjpeg.la: No such file or directory
> libtool: link: `/usr/lib/libjpeg.la' is not a valid libtool archive
> make[1]: *** [libgdal.la] Error 1
> make[1]: Leaving directory `/opt/gdal-cvs-2005.06.01'
> make: *** [check-lib] Error 2
> I also try to disable libtool but without success
> my linux box : Suse 9.2
> gcc 3.3.4
> Thanks for any help.
> Stéphane
>No virus found in this incoming message.
>Checked by AVG Anti-Virus.
>Version: 7.0.323 / Virus Database: 267.6.2 - Release Date: 04/06/2005
Type: text/x-vcard
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapserver-users/attachments/20050606/37da1c4f/stephane.morel.vcf
