Unsubcribe
    Thanh Nguyen
    ngvietthanhvn at GMAIL.COM
    Sat Jun  4 06:20:06 PDT 2005
On 6/4/05, Bart van den Eijnden <bartvde at xs4all.nl> wrote:
> ---------------------- Information from the mail header -----------------------
> Sender:       UMN MapServer Users List <MAPSERVER-USERS at LISTS.UMN.EDU>
> Poster:       Bart van den Eijnden <bartvde at XS4ALL.NL>
> Organization: Syncera IT Solutions
> Subject:      Re: From CGI to PHPMapscript
> Hi,
> did you already look at the PHP/Mapscript reference?
> http://mapserver.gis.umn.edu/doc44/phpmapscript-class-guide.html
> Look especially at the functions:
> queryByAttributes and drawQuery
> If you need examples I would recommend downloading Chameleon and looking
> for examples in there.
> http://chameleon.maptools.org/index.phtml
> Best regards,
> Bart
> On Sat, 04 Jun 2005 13:08:25 +0200, Daniele Margotti
> <margottid at COMUNE.LUGO.RA.IT> wrote:
> > Hi list,
> > how can I create the following image using PHP Mapscript?
> > http://sit.comune.lugo.ra.it/cgi-bin/mapserv?
> > &mode=itemnquerymap&map_querymap_size=698 523&mapxy=1729559.6025
> > 4927024.888&scale=6980&map=/dati/sit/Lugo_base.map&layers=CTR_5000
> > Mappali
> > Quadrocatasto Fabbricati&qlayer=Mappali&qitem=PARTKEY&qstring=/E730   77
> > 344|E730   77  383|E730   77  384|E730   77  427|E730   77  479/
> > I can easily create it with CGI Mapserver, but now I need to create it
> > with PHP Mapscript.
> > My variables are:
> >  - map_querymap_size (I need to modify it: in the mapfile I have another
> > size);
> >  - mapxy (I have already calculated the center point of my new map, I
> > only
> > need to specify it);
> >  - scale (same as mapxy);
> >  - layers (not all layers of the mapfile should be drawn);
> >  - qlayer, qitem and qstring.
> > How can I perform an "itemnquerymap" with PHP Mapscript?
> > Thank you,
> >     Daniele
> Using Opera's revolutionary e-mail client: http://www.opera.com/mail/
More information about the MapServer-users
