From CGI to PHPMapscript
Bart van den Eijnden
bartvde at XS4ALL.NL
Sat Jun 4 07:26:00 EDT 2005
did you already look at the PHP/Mapscript reference?
http://mapserver.gis.umn.edu/doc44/phpmapscript-class-guide.html
Look especially at the functions:
queryByAttributes and drawQuery
If you need examples I would recommend downloading Chameleon and looking
for examples in there.
http://chameleon.maptools.org/index.phtml
Best regards,
Bart
On Sat, 04 Jun 2005 13:08:25 +0200, Daniele Margotti
<margottid at COMUNE.LUGO.RA.IT> wrote:
> Hi list,
> how can I create the following image using PHP Mapscript?
> http://sit.comune.lugo.ra.it/cgi-bin/mapserv?
> &mode=itemnquerymap&map_querymap_size=698 523&mapxy=1729559.6025
> 4927024.888&scale=6980&map=/dati/sit/Lugo_base.map&layers=CTR_5000
> Mappali
> Quadrocatasto Fabbricati&qlayer=Mappali&qitem=PARTKEY&qstring=/E730 77
> 344|E730 77 383|E730 77 384|E730 77 427|E730 77 479/
> I can easily create it with CGI Mapserver, but now I need to create it
> with PHP Mapscript.
> My variables are:
> - map_querymap_size (I need to modify it: in the mapfile I have another
> size);
> - mapxy (I have already calculated the center point of my new map, I
> only
> need to specify it);
> - scale (same as mapxy);
> - layers (not all layers of the mapfile should be drawn);
> - qlayer, qitem and qstring.
> How can I perform an "itemnquerymap" with PHP Mapscript?
> Thank you,
> Daniele
Using Opera's revolutionary e-mail client: http://www.opera.com/mail/
