From CGI to PHPMapscript
Daniele Margotti
margottid at COMUNE.LUGO.RA.IT
Sat Jun 4 07:08:25 EDT 2005
Hi list,
how can I create the following image using PHP Mapscript?
http://sit.comune.lugo.ra.it/cgi-bin/mapserv?
&mode=itemnquerymap&map_querymap_size=698 523&mapxy=1729559.6025
4927024.888&scale=6980&map=/dati/sit/Lugo_base.map&layers=CTR_5000 Mappali
Quadrocatasto Fabbricati&qlayer=Mappali&qitem=PARTKEY&qstring=/E730 77
344|E730 77 383|E730 77 384|E730 77 427|E730 77 479/
I can easily create it with CGI Mapserver, but now I need to create it
with PHP Mapscript.
My variables are:
- map_querymap_size (I need to modify it: in the mapfile I have another
size);
- mapxy (I have already calculated the center point of my new map, I only
need to specify it);
- scale (same as mapxy);
- layers (not all layers of the mapfile should be drawn);
- qlayer, qitem and qstring.
How can I perform an "itemnquerymap" with PHP Mapscript?
Thank you,
Daniele
