Question:How-to Use of ESRI Shape Files
bino_oetomo
bino at INDOAKSES-ONLINE.COM
Sun Jun 5 22:56:08 EDT 2005
Thanks for your help.
----- Original Message -----
To: <MAPSERVER-USERS at LISTS.UMN.EDU>
Sent: Saturday, June 04, 2005 4:11 PM
Subject: Re: [UMN_MAPSERVER-USERS] Question:How-to Use of ESRI Shape Files
> Hi Bino,
> There are numerous examples out there of using ESRI Shapefiles with
> Mapserver.
> Have you tried for example the tutorial that uses shapefiles?
> http://terrasip.gis.umn.edu/projects/tutorial/section1.html
Ok , Here it is.
Using ogrinfo to my polygon.shp, and got
-----Start ogrinfo-----
D:\ms4w\tools\gdal-ogr-utils>ogrinfo -all d:\ms4w\shp\polygon.shp
INFO: Open of `d:\ms4w\shp\polygon.shp'
using driver `ESRI Shapefile' successful.
Layer name: polygon
Geometry: Polygon
Feature Count: 50603
Extent: (109.999930, -10.000030) - (115.000030, -5.000000)
Layer SRS WKT:
(unknown)
type: Integer (5.0)
label: String (80.0)
level: Integer (5.0)
endlevel: Integer (5.0)
-----end ogrinfo-------
I copied map file from
http://terrasip.gis.umn.edu/projects/tutorial/example1-1.html
Below is my map file, i just modified the "extent" .. refer from ogrinfo
------Start - map file--------
MAP
IMAGETYPE PNG
EXTENT 110.999930 -10.000030 115.000030 -6.000000
SIZE 400 300
SHAPEPATH "d:\ms4w\shp"
IMAGECOLOR 255 255 255
PROJECTION
"proj=laea"
"ellps=clrk66"
"lat_0=45"
"lon_0=-100"
# Alternatively, you can specify an EPSG code.
# "init=epsg:2163"
END
# Start of LAYER DEFINITIONS ---------------------------------------------
LAYER # States polygon layer begins here
NAME states
DATA polygon
STATUS DEFAULT
TYPE POLYGON
PROJECTION
"init=epsg:4269"
END
CLASS
COLOR 232 232 232
OUTLINECOLOR 32 32 32
END
END # States polygon layer ends here
# End of LAYER DEFINITIONS -------------------------------
END # end of map file/object
------End - map file----------
I try to access this using :
http://127.0.0.1/cgi-bin/mapserv_46.exe?map=/ms4w/proj/bino/map1.map&mode=ma
p
And got :
getString(): Symbol definition error. Parsing error near (polygon):(line 22)
Question : Is it because wrong "projection" ? How to fix it ?
Regards
-bino-
