Performance issue on labeling
Erki Veersalu
oraakel at GMAIL.COM
Mon Jun 6 06:43:06 PDT 2005
Dear MapServer users,
I need help for improving speed of my web-application. I would really
appreciate if someone could comment following issue.
I'm using MapServer for displaying road network with labels over
PostGis,Postgresql. Database is not that big, but making a GIF file of
only roads (~200000 road segments) with angular true type labeling
takes ~3 sec. If I don't use labeling it's 0,5 sec and with bitmap
labels it's 0,6 sec
Mapserver is running on Solaris 9.
Why is labeling so slow? What can I do to speed up generation of an image?
mapserv -v
MapServer version 4.4.1 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
SUPPORTS=PROJ SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER INPUT=EPPL7
INPUT=POSTGIS INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
map file:
MAP
NAME tuwa
STATUS ON
IMAGETYPE GIF
SIZE 400 300
EXTENT -876000 1330000 2230000 3650000
SHAPEPATH "/usr/local/apache2/htdocs/mapserver/tuwa/data/"
FONTSET "/usr/local/apache2/htdocs/mapserver/tuwa/data/fonts/fonts.list"
UNITS METERS
WEB
IMAGEPATH "/usr/local/apache2/htdocs/mapserver/tmp/"
IMAGEURL "/mapserver/tmp/"
END
SCALEBAR
STATUS on
INTERVALS 4
SIZE 200 2
COLOR 0 0 0
OUTLINECOLOR 0 0 0
UNITS kilometers
LABEL
COLOR 0 0 0
SIZE small
END
END
LAYER
NAME A40
STATUS default
CONNECTIONTYPE postgis
CONNECTION "user=postgres dbname=tuwa"
DATA "the_geom from streets"
TYPE line
LABELITEM "name"
LABELMAXSCALE 45000
CLASS
SYMBOL 0
COLOR 150 150 150
MAXSCALE 50000
LABEL
TYPE TRUETYPE
FONT "arial"
SIZE 9
MINSIZE 8
MAXSIZE 10
FORCE FALSE
COLOR 0 0 0
OUTLINECOLOR 255 255 255
POSITION cc
ANGLE auto
ANTIALIAS TRUE
MINFEATURESIZE 3
MINDISTANCE 100
PARTIALS TRUE
END
END
END
END
Erki Salu
Estonia
More information about the MapServer-users
