EPSG code for...
Dean C. Mikkelsen
dcmikkelsen at SHAW.CA
Mon Jun 6 16:24:24 PDT 2005
Hi Chris,
It may be a directory problem, MapServer is not reading the CONUS or
NAD27/NAD83 files correctly in the proj directory.
Are you using the MS4W or a later version of MapServer?
Cheers,
Dean
Dean C. Mikkelsen, B.Sc.,P.Eng.
Consultant, Terra ETL Ltd.
North Vancouver, BC
Canada
Phone: +1 604 929 8630
E-mail: dcmikkelsen at shaw.ca
-----Original Message-----
From: Christopher R. Thorne [mailto:christhorne at sympatico.ca]
Sent: Monday, June 06, 2005 4:10 PM
To: Dean C. Mikkelsen
Cc: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: Re: [UMN_MAPSERVER-USERS] EPSG code for...
Yes I used these projections where
26911 NAD 83 is the projection of the mapfile and where NAD27 <26711> is
being reprojected.
See first attached image to see how messed up the Nad27 layer gets.
If I don't define projection you can see the a shift between the line
layer and the solid polygon layers.
Comments/suggestions??
Thanks
Chris
Dean C. Mikkelsen wrote:
> Hi Chris,
> Did you try the following?
> # NAD27 / UTM zone 11N
> <26711> +proj=utm +zone=11 +ellps=clrk66 +datum=NAD27 +units=m
> no_defs <>
> # NAD83 / UTM zone 11N
> <26911> +proj=utm +zone=11 +ellps=GRS80 +datum=NAD83 +units=m no_defs
> Cheers,
> Dean
> North Vancouver, BC
> Canada
> From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU]
> On Behalf Of Christopher R. Thorne
> Sent: Monday, June 06, 2005 3:29 PM
> To: MAPSERVER-USERS at LISTS.UMN.EDU
> Subject: [UMN_MAPSERVER-USERS] EPSG code for...
> Hello all,
> If you were given the following information for two projections for
> California LA County region.
> NAD83 UTM Zone 11 meters
> NAD27 UTM Zone 11 meters
> What would be your suggested codes? I have tried a few but can not
> seem
> to get it.
> Thanks
> Chris
Christopher R. Thorne, GIS Specialist
3406 Southgate Rd. Ottawa ON K1V 9P9
Tel:(613)523-6593
More information about the MapServer-users
