EPSG code for...
Christopher R. Thorne
christhorne at SYMPATICO.CA
Tue Jun 7 08:25:54 EDT 2005
Dean C. Mikkelsen wrote:
> Hi Chris,
> It may be a directory problem, MapServer is not reading the CONUS or
> NAD27/NAD83 files correctly in the proj directory.
> Are you using the MS4W or a later version of MapServer?
I am using the latest version of ms4w, with Chameleon using MapServer 4.4.2
Any suggestions?
> Cheers,
> Dean
> Dean C. Mikkelsen, B.Sc.,P.Eng.
> Consultant, Terra ETL Ltd.
> North Vancouver, BC
> Canada
> Phone: +1 604 929 8630
> E-mail: dcmikkelsen at shaw.ca
> -----Original Message-----
> From: Christopher R. Thorne [mailto:christhorne at sympatico.ca]
> Sent: Monday, June 06, 2005 4:10 PM
> To: Dean C. Mikkelsen
> Cc: MAPSERVER-USERS at LISTS.UMN.EDU
> Subject: Re: [UMN_MAPSERVER-USERS] EPSG code for...
> Yes I used these projections where
> 26911 NAD 83 is the projection of the mapfile and where NAD27 <26711> is
> being reprojected.
> See first attached image to see how messed up the Nad27 layer gets.
> If I don't define projection you can see the a shift between the line
> layer and the solid polygon layers.
> Comments/suggestions??
> Thanks
> Chris
>>Hi Chris,
>>Did you try the following?
>># NAD27 / UTM zone 11N
>><26711> +proj=utm +zone=11 +ellps=clrk66 +datum=NAD27 +units=m
>>no_defs <>
>># NAD83 / UTM zone 11N
>><26911> +proj=utm +zone=11 +ellps=GRS80 +datum=NAD83 +units=m no_defs
>>Cheers,
>>Dean
>>North Vancouver, BC
>>Canada
>>From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU]
>>On Behalf Of Christopher R. Thorne
>>Sent: Monday, June 06, 2005 3:29 PM
>>To: MAPSERVER-USERS at LISTS.UMN.EDU
>>Subject: [UMN_MAPSERVER-USERS] EPSG code for...
>>Hello all,
>>If you were given the following information for two projections for
>>California LA County region.
>>NAD83 UTM Zone 11 meters
>>NAD27 UTM Zone 11 meters
>>What would be your suggested codes? I have tried a few but can not
>>seem
>>to get it.
>>Thanks
>>Chris
Christopher R. Thorne, GIS Specialist
3406 Southgate Rd. Ottawa ON K1V 9P9
Tel:(613)523-6593
