ESRI files : Attributes didn't showed
bino_oetomo
bino at INDOAKSES-ONLINE.COM
Tue Jun 7 01:28:20 PDT 2005
Hello Wim,
Thanks for your enlightment.
Well i have to comment-out some line ... i think it caused by my PC
configuration.
I Use MS4W ...
I think I have to read more docs.
Can you give me URL to docs that contain deep explanation and variation of
all MapFile lines per line ?
Regards
-bino-
----- Original Message -----
To: <MAPSERVER-USERS at LISTS.UMN.EDU>
Sent: Tuesday, June 07, 2005 2:03 PM
Subject: Re: [UMN_MAPSERVER-USERS] ESRI files : Attributes didn't showed
> From: "Wim Blanken" <w.blanken at geon.nl>
> To: "bino_oetomo" <bino at INDOAKSES-ONLINE.COM>
> Sent: Tuesday, June 07, 2005 9:02 AM
> > Hello bino,
> > You have to use the label object. See the example beneath:
> > <snip>.....
> > LABELITEM "STATE"
> > CLASS
> > EXPRESSION 'land'
> > COLOR 232 232 232
> > LABEL
> > COLOR 132 31 31
> > SHADOWCOLOR 218 218 218
> > SHADOWSIZE 2 2
> > TYPE TRUETYPE
> > FONT arial-bold
> > SIZE 12
> > ANTIALIAS TRUE
> > POSITION CL
> > PARTIALS FALSE
> > MINDISTANCE 300
> > BUFFER 4
> > END # end of label
> > END<snip>.....
> > regards,
> > Wim Blanken
> > Look at the example
> > From: "bino_oetomo" <bino at INDOAKSES-ONLINE.COM>
> > Sent: Tuesday, June 07, 2005 3:35 AM
> > Subject: [UMN_MAPSERVER-USERS] ESRI files : Attributes didn't showed
> >> Dear All
> >> My ESRI files made of (for line layer only):
> >> - line.shp
> >> - line.shx
> >> - line.dbf
> >> And here is my (part of) MS map file :
> >> ----Start---------------
> >> MAP
> >> IMAGETYPE PNG
> >> EXTENT 110.999930 -10.000030 115.000030 -6.000000
> >> SIZE 600 600
> >> SHAPEPATH "d:\ms4w\shp"
> >> IMAGECOLOR 255 255 255
> >> WEB
> >> TEMPLATE '/ms4w/apache/htdocs/bino.html'
> >> IMAGEPATH '/ms4w/tmp/ms_tmp/'
> >> IMAGEURL '/ms_tmp/'
> >> END
> >> # Start of LAYER DEFINITIONS ---
> >> LAYER # States line layer begins here
> >> NAME lay-1
> >> DATA line.shp
> >> STATUS DEFAULT
> >> TYPE LINE
> >> CLASS
> >> COLOR 0 0 255
> >> #OUTLINECOLOR 32 32 32
> >> END
> >> END # States line layer ends here
> >> ----STOP-------------------
> >> Using http://terrasip.gis.umn.edu/projects/tutorial/section1.html ,
> >> The lines showed up.
> >> But I can't see the street names.
> >> I think the street name is in that line.dbf file.
> >> How to show that street names ?
> >> Regards
> >> -bino-
More information about the MapServer-users
