ESRI files : Attributes didn't showed
Wim Blanken
w.blanken at GEON.NL
Tue Jun 7 06:12:25 EDT 2005
Hello Bino,
Well, I'm sure you know the main mapfile doc
(http://mapserver.gis.umn.edu/doc44/mapfile-reference.html)
I do not know if a better mapfile document exists.
I learned mapserver mainly by looking at the tutorials.
By the way this summer some books regarding mapserver will be published. You
can search for them using f.e. google.
Succes and regards,
Wim Blanken
----- Original Message -----
To: <MAPSERVER-USERS at LISTS.UMN.EDU>
Sent: Tuesday, June 07, 2005 10:28 AM
Subject: Re: [UMN_MAPSERVER-USERS] ESRI files : Attributes didn't showed
> Hello Wim,
> Thanks for your enlightment.
> Well i have to comment-out some line ... i think it caused by my PC
> configuration.
> I Use MS4W ...
> I think I have to read more docs.
> Can you give me URL to docs that contain deep explanation and variation of
> all MapFile lines per line ?
> Regards
> -bino-
> From: "Wim Blanken" <w.blanken at GEON.NL>
> Sent: Tuesday, June 07, 2005 2:03 PM
>> From: "Wim Blanken" <w.blanken at geon.nl>
>> To: "bino_oetomo" <bino at INDOAKSES-ONLINE.COM>
>> Sent: Tuesday, June 07, 2005 9:02 AM
>> > Hello bino,
>> > You have to use the label object. See the example beneath:
>> > <snip>.....
>> > LABELITEM "STATE"
>> > CLASS
>> > EXPRESSION 'land'
>> > COLOR 232 232 232
>> > LABEL
>> > COLOR 132 31 31
>> > SHADOWCOLOR 218 218 218
>> > SHADOWSIZE 2 2
>> > TYPE TRUETYPE
>> > FONT arial-bold
>> > SIZE 12
>> > ANTIALIAS TRUE
>> > POSITION CL
>> > PARTIALS FALSE
>> > MINDISTANCE 300
>> > BUFFER 4
>> > END # end of label
>> > END<snip>.....
>> > regards,
>> > Wim Blanken
>> > Look at the example
>> > From: "bino_oetomo" <bino at INDOAKSES-ONLINE.COM>
>> > Sent: Tuesday, June 07, 2005 3:35 AM
>> > Subject: [UMN_MAPSERVER-USERS] ESRI files : Attributes didn't showed
>> >> Dear All
>> >> My ESRI files made of (for line layer only):
>> >> - line.shp
>> >> - line.shx
>> >> - line.dbf
>> >> And here is my (part of) MS map file :
>> >> ----Start---------------
>> >> MAP
>> >> IMAGETYPE PNG
>> >> EXTENT 110.999930 -10.000030 115.000030 -6.000000
>> >> SIZE 600 600
>> >> SHAPEPATH "d:\ms4w\shp"
>> >> IMAGECOLOR 255 255 255
>> >> WEB
>> >> TEMPLATE '/ms4w/apache/htdocs/bino.html'
>> >> IMAGEPATH '/ms4w/tmp/ms_tmp/'
>> >> IMAGEURL '/ms_tmp/'
>> >> END
>> >> # Start of LAYER DEFINITIONS ---
>> >> LAYER # States line layer begins here
>> >> NAME lay-1
>> >> DATA line.shp
>> >> STATUS DEFAULT
>> >> TYPE LINE
>> >> CLASS
>> >> COLOR 0 0 255
>> >> #OUTLINECOLOR 32 32 32
>> >> END
>> >> END # States line layer ends here
>> >> ----STOP-------------------
>> >> Using http://terrasip.gis.umn.edu/projects/tutorial/section1.html ,
>> >> The lines showed up.
>> >> But I can't see the street names.
>> >> I think the street name is in that line.dbf file.
>> >> How to show that street names ?
>> >> Regards
>> >> -bino-
