EPSG code for...
Dean C. Mikkelsen
dm at S-AND-A.COM
Tue Jun 7 23:58:30 EDT 2005
Hi Ken,
Thanks for the information.
The other problem I was looking at is that it may be a State Plane
Coordinate System as well.
California is divided into many zones and the dataset being worked with
did not include some of the projection information.
Cheers,
Dean
Consultant, Terra ETL Ltd.
North Vancouver, BC
Canada
Phone: +1 604 929 8630
E-mail: <mailto:dcmikkelsen at shaw.ca> dcmikkelsen at shaw.ca
-----Original Message-----
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On
Behalf Of Ken Lord
Sent: Tuesday, June 07, 2005 12:44 PM
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: Re: [UMN_MAPSERVER-USERS] EPSG code for...
Dean,
Make sure you have the Proj software installed, there's information
about it here:
http://www.maptools.org/maplab/index.phtml?page=maplab_windows.txt
and here:
http://www.remotesensing.org/proj/
<http://proj.maptools.org/>
If you haven't already, grab the windows binaries, unzip and place the
Proj folder on your C drive.
C:/Proj
Cheers,
Ken Lord
Vancouver BC
On 6/7/05, Christopher R. Thorne <christhorne at sympatico.ca> wrote:
Dean C. Mikkelsen wrote:
> Hi Chris,
> It may be a directory problem, MapServer is not reading the CONUS or
> NAD27/NAD83 files correctly in the proj directory.
> Are you using the MS4W or a later version of MapServer?
I am using the latest version of ms4w, with Chameleon using MapServer
4.4.2
Any suggestions?
> Cheers,
> Dean
> Dean C. Mikkelsen, B.Sc.,P.Eng.
> North Vancouver, BC
> Canada
> E-mail: dcmikkelsen at shaw.ca
> From: Christopher R. Thorne [mailto:christhorne at sympatico.ca
<mailto:christhorne at sympatico.ca> ]
> Sent: Monday, June 06, 2005 4:10 PM
> To: Dean C. Mikkelsen
> Cc: MAPSERVER-USERS at LISTS.UMN.EDU
> Yes I used these projections where
> 26911 NAD 83 is the projection of the mapfile and where NAD27 <26711>
is
> being reprojected.
> See first attached image to see how messed up the Nad27 layer gets.
> If I don't define projection you can see the a shift between the line
> layer and the solid polygon layers.
> Comments/suggestions??
> Thanks
> Chris
>>Hi Chris,
>>Did you try the following?
>># NAD27 / UTM zone 11N
>><26711> +proj=utm +zone=11 +ellps=clrk66 +datum=NAD27 +units=m
>>no_defs <>
>># NAD83 / UTM zone 11N
>><26911> +proj=utm +zone=11 +ellps=GRS80 +datum=NAD83 +units=m no_defs
>>Cheers,
>>Dean
>>North Vancouver, BC
>>Canada
<mailto:MAPSERVER-USERS at LISTS.UMN.EDU> ]
>>On Behalf Of Christopher R. Thorne
>>Sent: Monday, June 06, 2005 3:29 PM
>>Subject: [UMN_MAPSERVER-USERS] EPSG code for...
>>Hello all,
>>If you were given the following information for two projections for
>>California LA County region.
>>NAD83 UTM Zone 11 meters
>>NAD27 UTM Zone 11 meters
>>What would be your suggested codes? I have tried a few but can not
>>seem
>>to get it.
>>Thanks
>>Chris
Christopher R. Thorne, GIS Specialist
3406 Southgate Rd. Ottawa ON K1V 9P9
Tel:(613)523-6593
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20050607/d13e3cbd/attachment.html
