EPSG code for...
Christopher R. Thorne
christhorne at SYMPATICO.CA
Wed Jun 8 14:35:19 EDT 2005
I was worried about that ;) Unfortunately, it is not an easy thing to
pin point what the projection actually is.
Thanks again,
Chris
Dean C. Mikkelsen wrote:
> Hi Ken,
> Thanks for the information.
> The other problem I was looking at is that it may be a State Plane
> Coordinate System as well.
> California is divided into many zones and the dataset being worked with
> did not include some of the projection information.
> Cheers,
> Dean
> Consultant, Terra ETL Ltd.
> North Vancouver, BC
> Canada
> Phone: +1 604 929 8630
> E-mail: dcmikkelsen at shaw.ca <mailto:dcmikkelsen at shaw.ca>
> -----Original Message-----
> *From:* UMN MapServer Users List
> [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] *On Behalf Of *Ken Lord
> *Sent:* Tuesday, June 07, 2005 12:44 PM
> *To:* MAPSERVER-USERS at LISTS.UMN.EDU
> *Subject:* Re: [UMN_MAPSERVER-USERS] EPSG code for...
> Dean,
> Make sure you have the Proj software installed, there's information
> about it here:
> http://www.maptools.org/maplab/index.phtml?page=maplab_windows.txt
> and here:
> http://www.remotesensing.org/proj/
> <http://proj.maptools.org/>
> If you haven't already, grab the windows binaries, unzip and place
> the Proj folder on your C drive.
> C:/Proj
> Cheers,
> Ken Lord
> Vancouver BC
> On 6/7/05, *Christopher R. Thorne* <christhorne at sympatico.ca
> > Hi Chris,
> > It may be a directory problem, MapServer is not reading the
> CONUS or
> > NAD27/NAD83 files correctly in the proj directory.
> > Are you using the MS4W or a later version of MapServer?
> I am using the latest version of ms4w, with Chameleon using
> MapServer 4.4.2
> Any suggestions?
> > Cheers,
> > Dean
> > Dean C. Mikkelsen, B.Sc.,P.Eng.
> > North Vancouver, BC
> > Canada
> > From: Christopher R. Thorne [mailto:christhorne at sympatico.ca
> <mailto:christhorne at sympatico.ca>]
> > Sent: Monday, June 06, 2005 4:10 PM
> > To: Dean C. Mikkelsen
> > Cc: MAPSERVER-USERS at LISTS.UMN.EDU
> <mailto:MAPSERVER-USERS at LISTS.UMN.EDU>
> > Subject: Re: [UMN_MAPSERVER-USERS] EPSG code for...
> > Yes I used these projections where
> > 26911 NAD 83 is the projection of the mapfile and where NAD27
> <26711> is
> > being reprojected.
> > See first attached image to see how messed up the Nad27 layer
> gets.
> > If I don't define projection you can see the a shift between
> the line
> > layer and the solid polygon layers.
> > Comments/suggestions??
> > Thanks
> > Chris
> >>Hi Chris,
> >>Did you try the following?
> >># NAD27 / UTM zone 11N
> >><26711> +proj=utm +zone=11 +ellps=clrk66 +datum=NAD27 +units=m
> >>no_defs <>
> >># NAD83 / UTM zone 11N
> >><26911> +proj=utm +zone=11 +ellps=GRS80 +datum=NAD83
> +units=m no_defs
> >>Cheers,
> >>Dean
> >>North Vancouver, BC
> >>Canada
> >>From: UMN MapServer Users List
> <mailto:MAPSERVER-USERS at LISTS.UMN.EDU>]
> >>On Behalf Of Christopher R. Thorne
> >>Sent: Monday, June 06, 2005 3:29 PM
> >>To: MAPSERVER-USERS at LISTS.UMN.EDU
> >>Subject: [UMN_MAPSERVER-USERS] EPSG code for...
> >>Hello all,
> >>If you were given the following information for two
> projections for
> >>California LA County region.
> >>NAD83 UTM Zone 11 meters
> >>NAD27 UTM Zone 11 meters
> >>What would be your suggested codes? I have tried a few but
> can not
> >>seem
> >>to get it.
> >>Thanks
> >>Chris
> Christopher R. Thorne, GIS Specialist
> 3406 Southgate Rd. Ottawa ON K1V 9P9
> christhorne at sympatico.ca <mailto:christhorne at sympatico.ca>
> Tel:(613)523-6593
Tel:(613)523-6593
