perl mapscript crash "Can't locate
auto/mapscript/classObj/swig_size_s.al"
Joseph Bussell
joe at OTSYS.COM
Wed Jun 8 16:57:09 EDT 2005
I have a mapfile that when viewed at certain zoom levels, generates a
failure. The Apache log indicates that a specific object cannot be
found. I explicitly turned off all the layers, intending to add them
one at a time until I observed a failure, but the failure still existed
for scales 2000001 and higher. I do not understand why some Perl module
is differentially available based on my scale. Back in the days when
TrafficDodger was an active application this was working. I updated the
mapscript to the latest stable rev and had to make a few changes (like
my extents were improperly ordered). Lower scales work nicely. I have
other maps that show the whole planet, these render nicely. Does anyone
have any ideas?
I am using perl mapscript from version mapserver-4.4.2,
( set up with ./configure --with-proj --with-gdal --with-gd
--with-perl --with-php=../mapserverDeps/php-5.0.2/ )
Linux 2.6.10-1.771_FC2 #1 built Mon Mar 28 00:50:14 EST 2005 i686 athlon
i386 GNU/Linux
Server version: Apache/1.3.31 (Unix)
I offer the error string:
Can't locate auto/mapscript/classObj/swig_size_s.al in @INC (@INC
contains: /usr/traffic2/perl
/usr/lib/perl5/5.8.3/i386-linux-thread-multi /usr/lib/perl5/5.8.3
/usr/lib/perl5/site_perl/5.8.3/i386-linux-thread-multi
/usr/lib/perl5/site_perl/5.8.2/i386-linux-thread-multi
/usr/lib/perl5/site_perl/5.8.1/i386-linux-thread-multi
/usr/lib/perl5/site_perl/5.8.0/i386-linux-thread-multi
/usr/lib/perl5/site_perl/5.8.3 /usr/lib/perl5/site_perl/5.8.2
/usr/lib/perl5/site_perl/5.8.1 /usr/lib/perl5/site_perl/5.8.0
/usr/lib/perl5/vendor_perl/5.8.3/i386-linux-thread-multi
/usr/lib/perl5/vendor_perl/5.8.2/i386-linux-thread-multi
/usr/lib/perl5/vendor_perl/5.8.1/i386-linux-thread-multi
/usr/lib/perl5/vendor_perl/5.8.0/i386-linux-thread-multi
/usr/lib/perl5/vendor_perl/5.8.3 /usr/lib/perl5/vendor_perl/5.8.2
/usr/lib/perl5/vendor_perl/5.8.1 /usr/lib/perl5/vendor_perl/5.8.0
/usr/lib/perl5/vendor_perl /usr/local/apache/
/usr/local/apache/lib/perl) at
/usr/lib/perl5/site_perl/5.8.3/i386-linux-thread-multi/mapscript.pm line
35\n
My map file is as follows:
# Start of map file
NAME CA
STATUS ON
SIZE 325 325
PROJECTION
"proj=latlong"
END
#EXTENT -118.236313 34.013892 -118.201033 34.049172
# EXTENT -118.884 33.39597 -114.487 35.607288
# xmin, ymin, xmax, ymax
EXTENT -180.0 -90.0 180.0 90.0
#These paths are set in mapdrawing.pm via Perl/Mapscript
#SHAPEPATH "/hardcoded/paths/lead/to/diminished/potency/shapefiles/"
#FONTSET /hardcoded/paths/lead/to/diminished/potency/fonts.list
SYMBOLSET symbols.sym
IMAGECOLOR 161 161 161
TRANSPARENT ON
UNITS dd
# you may need to change this to match your MapServer build
IMAGETYPE PNG
# The Reference map is the thumbnail map that allows users to
# quickly navigate over the 'zoomed-out' map.
REFERENCE
IMAGE graphics/reference_ca.png
EXTENT -124.39263784515 32.5357813439163 -114.125230507624
42.0021917751363
SIZE 120 120
STATUS ON
COLOR -1 -1 -1
OUTLINECOLOR 255 0 0
END
# The legend
LEGEND
STATUS OFF
KEYSIZE 18 12
LABEL
TYPE TRUETYPE
FONT Arial
SIZE 8
COLOR 0 0 89
END
END
# Scalebar
SCALEBAR
STATUS ON
COLOR 0 0 0
IMAGECOLOR 230 230 230
POSTLABELCACHE FALSE
LABEL
COLOR 0 0 0
SIZE tiny
END
STYLE 1
SIZE 200 3
POSITION lr
UNITS MILES
INTERVALS 5
TRANSPARENT FALSE
END
# td_* are layers derived from tileing the TANA shapefiles
# order is important as the first layer declared is painted first.
# the scales are determined by MapServer as follows:
# map_distance = (map_width-1)/(MS_PPI*inches_per_unit);
# ground_distance = extent_maxx - extent_minx;
# scale = ground_distance/map_distance;
#where
# MS_PPI = number of pixels per inch for a computer monitor = 72;
# inches_per_unit = number of inches per map unit (i.e. UNITS ...)
LAYER
NAME background
TYPE polygon
STATUS ON
# MAXSCALE 20000
CLASS
NAME "World"
OUTLINECOLOR 0 0 0
COLOR 30 144 255
SIZE 1
SYMBOL 0
END
FEATURE
POINTS
-180 90
-180 -90
180 -90
180 90
-180 90 END
END
END
LAYER
NAME world
DATA world.shp
STATUS ON
# LABELITEM "NAME"
CLASSITEM "NAME"
TYPE POLYGON
# MAXSCALE 20000
CLASS
NAME "World"
OUTLINECOLOR 0 0 0
COLOR 0 255 100
SIZE 1
SYMBOL 0
LABEL
ANGLE AUTO
ANTIALIAS TRUE
BUFFER 2
COLOR 0 0 0
FONT Georgia
FORCE FALSE
MINDISTANCE 10
MINFEATURESIZE 25
# MINSIZE 5
# MAXSIZE 256
PARTIALS FALSE
POSITION cc
SIZE 10
TYPE TRUETYPE
END
END
END
LAYER
NAME states
GROUP defaultLayer
TYPE POLYGON
DATA state.shp
STATUS ON
LABELITEM "ST_NAME"
CLASSITEM "ST_NAME"
#MAXSCALE 9000
CLASS
COLOR 0 255 100
OUTLINECOLOR 0 0 0
SIZE 1
# SYMBOL 'circle'
LABEL
ANGLE AUTO
ANTIALIAS TRUE
BUFFER 2
COLOR 0 0 0
FONT Arial_Bold
FORCE TRUE
# MAXSIZE 256
# MINDISTANCE 10
MINFEATURESIZE AUTO
# MINSIZE 4
OFFSET 0 0
PARTIALS TRUE
POSITION cc
SIZE 12
TYPE TRUETYPE
END
END
END
LAYER
NAME county
GROUP defaultLayer
TYPE POLYGON
TILEINDEX td_a8.shp
STATUS ON
LABELITEM "NAME"
CLASSITEM "NAME"
MAXSCALE 200001
CLASS
NAME "County Boundary"
COLOR 245 245 245
OUTLINECOLOR 255 239 219
MAXSIZE 50
MINSIZE 0
SIZE 1
SYMBOL 0
LABEL
ANGLE AUTO
ANTIALIAS TRUE
BUFFER 2
COLOR 0 0 0
FONT Arial
FORCE FALSE
MAXSIZE 256
MINDISTANCE 10
MINFEATURESIZE AUTO
MINSIZE 4
OFFSET 0 0
PARTIALS FALSE
POSITION cc
SIZE 12
TYPE TRUETYPE
END
END
END
LAYER
NAME CountyNameAnnotation
GROUP PlaceName
TYPE POLYGON
TILEINDEX td_a8.shp
STATUS ON
LABELITEM "NAME"
CLASSITEM "NAME"
MAXSCALE 4500000
MINSCALE 2000000
CLASS
NAME "CountyNameAnnotation"
LABEL
ANGLE AUTO
ANTIALIAS TRUE
BUFFER 2
COLOR 0 0 0
FONT Georgia
FORCE TRUE
# MINDISTANCE 10
MINFEATURESIZE 40
WRAP " "
MINSIZE 10
MAXSIZE 256
OFFSET 0 0
PARTIALS FALSE
POSITION CC
TYPE TRUETYPE
END
END
END
LAYER
NAME OrangeCountyAnnotation
GROUP defaultLayer
TYPE POLYGON
DATA usa06059______a8.shp
STATUS OFF
LABELITEM "NAME"
CLASSITEM "NAME"
#MAXSCALE 15550000
#MINSCALE 4000000
CLASS
NAME "Orange County Boundary"
COLOR 255 222 173
MAXSIZE 50
MINSIZE 0
SIZE 1
SYMBOL 0
LABEL
ANGLE AUTO
ANTIALIAS TRUE
BUFFER 2
COLOR 0 0 0
FONT Georgia
FORCE TRUE
# MINDISTANCE 10
MINFEATURESIZE 10
MINSIZE 10
MAXSIZE 256
OFFSET 0 10
PARTIALS FALSE
POSITION CC
TYPE TRUETYPE
END
END
END
LAYER
NAME LA_County
GROUP defaultLayer
TYPE POLYGON
DATA usa06037______a8.shp
STATUS ON
# LABELITEM "NAME"
CLASSITEM "NAME"
#MAXSCALE 15550000
# MINSCALE 100000
CLASS
NAME "Los Angeles County Boundary"
OUTLINECOLOR 0 0 0
COLOR 225 254 244
MAXSIZE 50
MINSIZE 60
SIZE 1
SYMBOL 0
LABEL
ANGLE AUTO
ANTIALIAS TRUE
BUFFER 2
COLOR 0 0 0
FONT Georgia
FORCE TRUE
# MINDISTANCE 10
MINFEATURESIZE 25
MINSIZE 5
MAXSIZE 256
OFFSET 6 2
PARTIALS FALSE
POSITION CC
# SIZE 8
TYPE TRUETYPE
WRAP " "
END
END
END
LAYER
NAME Orange_County
GROUP defaultLayer
TYPE POLYGON
STATUS ON
# LABELITEM "NAME"
CLASSITEM "NAME"
#MAXSCALE 15550000
# MINSCALE 100000
CLASS
COLOR 255 239 219
OUTLINECOLOR 0 0 0
MAXSIZE 50
MINSIZE 0
SIZE 1
SYMBOL 0
LABEL
ANGLE AUTO
ANTIALIAS TRUE
BUFFER 2
COLOR 0 0 0
FONT Georgia
FORCE TRUE
# MINDISTANCE 10
MINFEATURESIZE 20
MINSIZE 5
MAXSIZE 256
OFFSET 0 0
PARTIALS FALSE
POSITION CC
# SIZE 8
TYPE TRUETYPE
END
END
END
LAYER
NAME Riverside_County
GROUP defaultLayer
TYPE POLYGON
DATA usa06065______a8.shp
STATUS ON
# LABELITEM "NAME"
CLASSITEM "NAME"
#MAXSCALE 15550000
# MINSCALE 100000
CLASS
NAME "Riverside County Boundary"
COLOR 187 255 255
OUTLINECOLOR 0 0 0
MAXSIZE 50
MINSIZE 0
SIZE 1
SYMBOL 0
LABEL
ANGLE AUTO
ANTIALIAS TRUE
BUFFER 2
COLOR 0 0 0
FONT Georgia
FORCE TRUE
# MINDISTANCE 10
MINFEATURESIZE 20
MINSIZE 5
MAXSIZE 256
OFFSET 0 0
PARTIALS FALSE
POSITION CC
# SIZE 8
TYPE TRUETYPE
END
END
END
LAYER
NAME San_Benardino_County
GROUP defaultLayer
TYPE POLYGON
DATA usa06071______a8.shp
STATUS ON
# LABELITEM "NAME"
CLASSITEM "NAME"
#MAXSCALE 15550000
# MINSCALE 100000
CLASS
NAME "San Bernardino County Boundary"
COLOR 255 225 255
OUTLINECOLOR 0 0 0
MAXSIZE 50
MINSIZE 0
SIZE 1
SYMBOL 0
LABEL
ANGLE AUTO
ANTIALIAS TRUE
BUFFER 2
COLOR 0 0 0
FONT Georgia
FORCE TRUE
# MINDISTANCE 10
MINFEATURESIZE 20
MINSIZE 5
MAXSIZE 256
OFFSET 0 0
PARTIALS FALSE
POSITION CC
# SIZE 8
TYPE TRUETYPE
WRAP " "
END
END
END
LAYER
NAME Ventura_County
GROUP defaultLayer
TYPE POLYGON
DATA usa06111______a8.shp
STATUS ON
# LABELITEM "NAME"
CLASSITEM "NAME"
#MAXSCALE 15550000
# MINSCALE 100000
CLASS
NAME "Ventura County Boundary"
COLOR 255 250 205
OUTLINECOLOR 0 0 0
MAXSIZE 50
MINSIZE 0
SIZE 1
SYMBOL 0
LABEL
ANGLE AUTO
ANTIALIAS TRUE
BUFFER 2
COLOR 0 0 0
FONT Georgia
FORCE TRUE
# MINDISTANCE 10
MINFEATURESIZE 20
MINSIZE 5
MAXSIZE 256
OFFSET -1 6
PARTIALS FALSE
POSITION CC
# SIZE AUTO
TYPE TRUETYPE
END
END
END
LAYER
NAME urbanAreas
GROUP defaultLayer
TYPE POLYGON
TILEINDEX td_oa2.shp
STATUS OFF
LABELITEM "NAME"
CLASSITEM "FEATTYP"
CLASS
NAME "Urban Area"
EXPRESSION ( ( [FEATTYP] = 9342 ) )
COLOR 238 232 205
OUTLINECOLOR 238 232 205
MAXSIZE 50
MINSIZE 0
SIZE 1
SYMBOL 0
LABEL
ANGLE AUTO
ANTIALIAS TRUE
BUFFER 2
COLOR 0 0 0
FONT Arial
FORCE FALSE
MAXSIZE 256
MINDISTANCE 10
MINFEATURESIZE AUTO
MINSIZE 4
OFFSET 0 0
PARTIALS FALSE
POSITION cc
SIZE 8
TYPE TRUETYPE
END
END
END
LAYER
NAME landUse
GROUP defaultLayer
TYPE POLYGON
TILEINDEX td_lu.shp
STATUS ON
LABELITEM "NAME"
CLASSITEM "DISPLTYP"
MAXSCALE 180000
CLASS
NAME "Land use"
COLOR 143 188 143
OUTLINECOLOR 0 0 0
MINSIZE 20
SIZE 1
SYMBOL 0
LABEL
ANGLE AUTO
ANTIALIAS TRUE
BUFFER 2
COLOR 90 90 90
WRAP " "
FONT Arial
FORCE FALSE
MAXSIZE 256
MINDISTANCE 10
MINFEATURESIZE 100
MINSIZE 4
OFFSET 0 0
PARTIALS FALSE
POSITION cc
SIZE 8
TYPE TRUETYPE
END
END
END
LAYER
NAME majorWater
GROUP defaultLayer
TYPE POLYGON
TILEINDEX td_wa.shp
STATUS ON
LABELITEM "NAME"
CLASSITEM "DISPCLASS"
MINSCALE 200000
# MAXSCALE 1000000
CLASS
EXPRESSION ( ( [DISPCLASS] < 3 ) )
COLOR 30 144 255
OUTLINECOLOR 30 144 255
SIZE 1
SYMBOL 0
LABEL
ANGLE AUTO
ANTIALIAS TRUE
BUFFER 2
COLOR 0 0 0
FONT Arial
FORCE FALSE
MAXSIZE 256
MINDISTANCE 10
MINFEATURESIZE AUTO
MINSIZE 4
OFFSET 0 0
PARTIALS FALSE
POSITION cc
SIZE 8
TYPE TRUETYPE
END
END
END
LAYER
NAME majorWaterIn
GROUP defaultLayer
TYPE POLYGON
TILEINDEX td_wa.shp
STATUS ON
LABELITEM "NAME"
MAXSCALE 200001
CLASS
COLOR 30 144 255
SIZE 1
SYMBOL 0
LABEL
ANGLE AUTO
ANTIALIAS TRUE
BUFFER 2
COLOR 0 0 0
FONT Arial
FORCE FALSE
MAXSIZE 256
MINDISTANCE 10
MINFEATURESIZE AUTO
MINSIZE 4
OFFSET 0 0
PARTIALS FALSE
POSITION cc
SIZE 8
TYPE TRUETYPE
END
END
END
LAYER
NAME minorWater
GROUP defaultLayer
TYPE LINE
TILEINDEX td_wl.shp
STATUS ON
LABELITEM "NAME"
CLASSITEM "NAME"
MAXSCALE 200000
CLASS
NAME "River"
COLOR 99 184 255
OUTLINECOLOR 0 0 0
MAXSIZE 50
MINSIZE 0
SIZE 1
SYMBOL 0
LABEL
ANGLE AUTO
ANTIALIAS TRUE
BUFFER 2
COLOR 0 0 0
FONT Arial
FORCE FALSE
MAXSIZE 256
MINDISTANCE 10
MINFEATURESIZE AUTO
MINSIZE 4
OFFSET 0 0
PARTIALS FALSE
POSITION cc
SIZE 8
TYPE TRUETYPE
END
END
END
LAYER
NAME pointsOfInterrest
GROUP defaultLayer
TYPE POINT
TILEINDEX td_pi.shp
#DATA usa06037______pi
STATUS ON
LABELITEM "NAME"
CLASSITEM "FEATTYP"
MAXSCALE 150000
CLASS
# museum
EXPRESSION ( ( [FEATTYP] = 7317 ) )
NAME "Museum"
BACKGROUNDCOLOR 255 255 255
COLOR 126 126 126
OUTLINECOLOR 0 0 0
MAXSIZE 50
MINSIZE 0
SIZE 8
SYMBOL 'circle'
LABEL
ANGLE AUTO
ANTIALIAS TRUE
BUFFER 2
COLOR 0 0 0
WRAP " "
FONT Arial
FORCE FALSE
MAXSIZE 256
MINDISTANCE 10
#MINFEATURESIZE AUTO
MINSIZE 4
OFFSET 0 0
PARTIALS FALSE
POSITION lr
SIZE 6
TYPE TRUETYPE
END
END
CLASS
# shopping center
EXPRESSION ( ( [FEATTYP] = 7373 ) )
NAME "Shopping Center"
COLOR 126 126 126
OUTLINECOLOR 0 0 0
MAXSIZE 50
MINSIZE 0
SIZE 4
SYMBOL 'circle'
LABEL
ANGLE AUTO
ANTIALIAS TRUE
BUFFER 2
COLOR 0 0 0
WRAP " "
FONT Arial
FORCE FALSE
MAXSIZE 256
MINDISTANCE 10
MINSIZE 4
OFFSET 0 0
PARTIALS FALSE
POSITION lr
SIZE 6
TYPE TRUETYPE
END
END
CLASS
# outdoor stadium
EXPRESSION ( ( [FEATTYP] = 7374 ) )
NAME "Stadium"
COLOR 126 126 126
OUTLINECOLOR 0 0 0
MAXSIZE 50
MINSIZE 0
SIZE 8
SYMBOL 'circle'
LABEL
ANGLE AUTO
ANTIALIAS TRUE
BUFFER 2
COLOR 0 0 0
WRAP " "
FONT Arial
FORCE FALSE
MAXSIZE 256
MINDISTANCE 10
MINSIZE 4
OFFSET 0 0
PARTIALS FALSE
POSITION lr
SIZE 6
TYPE TRUETYPE
END
END
CLASS
# tourist attractions
EXPRESSION ( ( [FEATTYP] = 7376 ) )
NAME "Attraction"
COLOR 126 0 0
OUTLINECOLOR 0 0 0
MAXSIZE 50
MINSIZE 0
SIZE 8
SYMBOL 'circle'
LABEL
ANGLE AUTO
ANTIALIAS TRUE
BUFFER 2
COLOR 0 0 0
WRAP " "
FONT Arial
FORCE FALSE
MAXSIZE 256
MINDISTANCE 10
MINSIZE 4
OFFSET 0 0
PARTIALS FALSE
POSITION lr
SIZE 6
TYPE TRUETYPE
END
END
CLASS
# university & college
EXPRESSION ( ( [FEATTYP] = 7377 ) )
NAME "University"
COLOR 126 126 126
OUTLINECOLOR 0 0 0
MAXSIZE 50
MINSIZE 0
SIZE 8
SYMBOL 'circle'
LABEL
ANGLE AUTO
ANTIALIAS TRUE
BUFFER 2
COLOR 0 0 0
WRAP " "
FONT Arial
FORCE FALSE
MAXSIZE 256
MINDISTANCE 10
MINSIZE 4
OFFSET 0 0
PARTIALS FALSE
POSITION lr
SIZE 6
TYPE TRUETYPE
END
END
CLASS
# railway station
EXPRESSION ( ( [FEATTYP] = 7380 ) )
NAME "Rail Station"
COLOR 126 126 126
OUTLINECOLOR 0 0 0
MAXSIZE 50
MINSIZE 0
SIZE 8
SYMBOL 'circle'
LABEL
ANGLE AUTO
ANTIALIAS TRUE
BUFFER 2
COLOR 0 0 0
WRAP " "
FONT Arial
FORCE FALSE
MAXSIZE 256
MINDISTANCE 10
MINSIZE 4
OFFSET 0 0
PARTIALS FALSE
POSITION lr
SIZE 6
TYPE TRUETYPE
END
END
CLASS
# airport
EXPRESSION ( ( [FEATTYP] = 7383 ) )
NAME "Airport"
#BACKGROUNDCOLOR 255 255 255
COLOR 0 0 0
#MAXSIZE 50
#MINSIZE 0
SIZE 25
SYMBOL 'airportIcon'
LABEL
ANGLE AUTO
ANTIALIAS TRUE
BUFFER 2
COLOR 0 0 0
WRAP " "
FONT Arial
FORCE TRUE
MAXSIZE 256
MINDISTANCE 10
MINSIZE 4
OFFSET 0 0
PARTIALS FALSE
POSITION lr
SIZE 10
TYPE TRUETYPE
END
END
CLASS
# conference and exhibition centers
EXPRESSION ( ( [FEATTYP] = 7385 ) )
NAME "Conference Center"
COLOR 126 126 126
OUTLINECOLOR 0 0 0
MAXSIZE 50
MINSIZE 0
SIZE 8
SYMBOL 'circle'
LABEL
ANGLE AUTO
ANTIALIAS TRUE
BUFFER 2
COLOR 0 0 0
WRAP " "
FONT Arial
FORCE FALSE
MAXSIZE 256
MINDISTANCE 10
MINSIZE 4
OFFSET 0 0
PARTIALS FALSE
POSITION lr
SIZE 6
TYPE TRUETYPE
END
END
CLASS
# rest areas
EXPRESSION ( ( [FEATTYP] = 7395 ) )
NAME "Rest Area"
COLOR 0 126 0
OUTLINECOLOR 0 0 0
SIZE 8
SYMBOL 0
LABEL
ANGLE AUTO
ANTIALIAS TRUE
BUFFER 2
COLOR 0 0 0
WRAP " "
FONT Arial
FORCE FALSE
MAXSIZE 256
MINDISTANCE 10
MINSIZE 4
OFFSET 0 0
PARTIALS FALSE
POSITION lr
SIZE 6
TYPE TRUETYPE
END
END
CLASS
# zoo
EXPRESSION ( ( [FEATTYP] = 9927 ) )
NAME "Zoo"
COLOR 126 126 126
OUTLINECOLOR 0 0 0
MAXSIZE 50
MINSIZE 0
SIZE 8
SYMBOL 0
LABEL
ANGLE AUTO
ANTIALIAS TRUE
BUFFER 2
COLOR 0 0 0
WRAP " "
FONT Arial
FORCE FALSE
MAXSIZE 256
MINDISTANCE 10
MINSIZE 4
OFFSET 0 0
PARTIALS FALSE
POSITION lr
SIZE 6
TYPE TRUETYPE
END
END
END
LAYER
NAME cityCenterOut
GROUP defaultLayer
TYPE POINT
TILEINDEX td_sm.shp
STATUS ON
LABELITEM "NAME"
MAXSCALE 1500000
MINSCALE 500001
CLASS
EXPRESSION ( ( [DISPCLASS] = 3 ) )
#NAME "Big City"
COLOR 0 0 0
SIZE 9
SYMBOL 'circleNoFill'
LABEL
ANGLE AUTO
ANTIALIAS TRUE
BUFFER 2
COLOR 0 0 0
OUTLINECOLOR 255 255 255
WRAP " "
FONT Arial_Bold
FORCE TRUE
MAXSIZE 256
MINDISTANCE 50
MINSIZE 4
OFFSET 0 0
PARTIALS FALSE
POSITION lr
SIZE 9
TYPE TRUETYPE
END
END
CLASS
EXPRESSION ( ( [DISPCLASS] = 6 ) )
#NAME "Medium City"
COLOR 0 0 0
SIZE 7
LABEL
ANGLE AUTO
ANTIALIAS TRUE
BUFFER 2
COLOR 0 0 0
WRAP " "
FONT Arial_Bold
FORCE TRUE
MAXSIZE 256
MINDISTANCE 75
MINSIZE 4
OFFSET 0 0
PARTIALS FALSE
POSITION lr
SIZE 7
TYPE TRUETYPE
END
END
CLASS
EXPRESSION ( ( [DISPCLASS] = 7 ) )
#NAME "Small City"
COLOR 0 0 0
MAXSIZE 50
MINSIZE 0
SIZE 6
SYMBOL 'circle'
LABEL
ANGLE AUTO
ANTIALIAS TRUE
BUFFER 2
COLOR 0 0 0
WRAP " "
FONT Arial
FORCE FALSE
MAXSIZE 256
MINDISTANCE 100
MINSIZE 4
OFFSET 0 0
PARTIALS FALSE
POSITION lr
SIZE 7
TYPE TRUETYPE
END
END
CLASS
EXPRESSION ( ( [DISPCLASS] = 8 ) )
#NAME "Big Town"
COLOR 126 126 126
MAXSIZE 50
MINSIZE 0
SIZE 5
SYMBOL 'circle'
LABEL
ANGLE AUTO
ANTIALIAS TRUE
BUFFER 1
COLOR 0 0 0
WRAP " "
FONT Arial
FORCE FALSE
MAXSIZE 256
MINDISTANCE 100
MINSIZE 4
OFFSET 0 0
PARTIALS FALSE
POSITION lr
SIZE 6
TYPE TRUETYPE
END
END
END
LAYER
NAME cityCenter
GROUP defaultLayer
TYPE POINT
TILEINDEX td_sm.shp
STATUS ON
LABELITEM "NAME"
MAXSCALE 500000
CLASS
#NAME "Big City"
COLOR 0 0 0
MAXSIZE 50
MINSIZE 1
SIZE 9
LABEL
ANGLE AUTO
ANTIALIAS TRUE
BUFFER 2
COLOR 0 0 0
WRAP " "
FONT Arial_Bold
FORCE TRUE
MAXSIZE 256
MINDISTANCE 75
MINSIZE 4
OFFSET 0 0
PARTIALS FALSE
POSITION lr
SIZE 10
TYPE TRUETYPE
END
END
CLASS
#NAME "Medium City"
COLOR 0 0 0
MAXSIZE 50
MINSIZE 1
SIZE 7
LABEL
ANGLE AUTO
ANTIALIAS TRUE
BUFFER 2
COLOR 0 0 0
WRAP " "
FONT Arial_Bold
FORCE FALSE
MAXSIZE 256
MINDISTANCE 75
MINSIZE 4
OFFSET 0 0
PARTIALS FALSE
POSITION lr
SIZE 8
TYPE TRUETYPE
END
END
CLASS
#NAME "Small City"
COLOR 0 0 0
MAXSIZE 50
MINSIZE 0
SIZE 7
SYMBOL 'circle'
LABEL
ANGLE AUTO
ANTIALIAS TRUE
BUFFER 2
COLOR 0 0 0
WRAP " "
FONT Arial
FORCE FALSE
MAXSIZE 256
MINDISTANCE 10
MINSIZE 4
OFFSET 0 0
PARTIALS FALSE
POSITION lr
SIZE 7
TYPE TRUETYPE
END
END
CLASS
#NAME "Big Town"
COLOR 126 126 126
MAXSIZE 50
MINSIZE 0
SIZE 5
SYMBOL 'circle'
LABEL
ANGLE AUTO
ANTIALIAS TRUE
BUFFER 2
COLOR 0 0 0
WRAP " "
FONT Arial
FORCE FALSE
MAXSIZE 256
MINDISTANCE 10
MINSIZE 4
OFFSET 0 0
PARTIALS FALSE
POSITION lr
SIZE 6
TYPE TRUETYPE
END
END
CLASS
EXPRESSION ( ( [DISPCLASS] = 9 ) )
#NAME "Medium Town"
COLOR 126 126 126
MAXSIZE 50
MINSIZE 0
SIZE 4
SYMBOL 'circle'
LABEL
ANGLE AUTO
ANTIALIAS TRUE
BUFFER 2
COLOR 0 0 0
WRAP " "
FONT Arial
FORCE FALSE
MAXSIZE 256
MINDISTANCE 10
MINSIZE 4
OFFSET 0 0
PARTIALS FALSE
POSITION lr
SIZE 6
TYPE TRUETYPE
END
END
CLASS
EXPRESSION ( ( [DISPCLASS] = 10 ) )
#NAME "Village"
COLOR 126 126 126
MAXSIZE 50
MINSIZE 0
SIZE 3
SYMBOL 'circle'
LABEL
ANGLE AUTO
ANTIALIAS TRUE
BUFFER 2
COLOR 0 0 0
WRAP " "
FONT Arial
FORCE FALSE
MAXSIZE 256
MINDISTANCE 10
MINSIZE 4
OFFSET 0 0
PARTIALS FALSE
POSITION lr
SIZE 6
TYPE TRUETYPE
END
END
CLASS
EXPRESSION ( ( [DISPCLASS] = 11 ) )
#NAME "Community"
COLOR 126 126 126
MAXSIZE 50
MINSIZE 0
SIZE 2
SYMBOL 'circle'
LABEL
ANGLE AUTO
ANTIALIAS TRUE
BUFFER 2
COLOR 0 0 0
WRAP " "
FONT Arial
FORCE FALSE
MAXSIZE 256
MINDISTANCE 10
MINSIZE 4
OFFSET 0 0
PARTIALS FALSE
POSITION lr
SIZE 6
TYPE TRUETYPE
END
END
CLASS
EXPRESSION ( ( [DISPCLASS] = 12 ) )
#NAME "Small Community"
COLOR 126 126 126
MAXSIZE 50
MINSIZE 0
SIZE 1
SYMBOL 'circle'
LABEL
ANGLE AUTO
ANTIALIAS TRUE
BUFFER 2
COLOR 0 0 0
WRAP " "
FONT Arial
FORCE FALSE
MAXSIZE 256
MINDISTANCE 10
MINSIZE 4
OFFSET 0 0
PARTIALS FALSE
POSITION lr
SIZE 6
TYPE TRUETYPE
END
END
END
LAYER
NAME bridges
GROUP defaultLayer
TYPE LINE
TILEINDEX td_ls.shp
STATUS ON
LABELITEM "NAME"
CLASSITEM "STRUCTTYP"
MAXSCALE 70000
CLASS
NAME "Bridge"
COLOR 126 126 126
OUTLINECOLOR 0 0 0
MAXSIZE 50
MINSIZE 0
SIZE 1
SYMBOL 0
OVERLAYBACKGROUNDCOLOR 255 255 255
OVERLAYCOLOR 126 126 126
OVERLAYOUTLINECOLOR 0 0 0
OVERLAYSIZE 1
OVERLAYMINSIZE 0
OVERLAYMAXSIZE 50
OVERLAYSYMBOL 0
LABEL
ANGLE AUTO
ANTIALIAS TRUE
BUFFER 2
COLOR 0 0 0
FONT Arial
FORCE FALSE
MAXSIZE 256
MINDISTANCE 40
# MINFEATURESIZE AUTO
MINSIZE 4
OFFSET 0 0
PARTIALS FALSE
POSITION cc
SIZE 8
TYPE TRUETYPE
END
END
END
LAYER
NAME ferries
GROUP defaultLayer
TYPE LINE
TILEINDEX td_fe.shp
STATUS ON
LABELITEM "NAME"
CLASSITEM "FRC"
MAXSCALE 70000
CLASS
NAME "Ferry"
COLOR 126 126 126
OUTLINECOLOR 0 0 0
MAXSIZE 50
MINSIZE 0
SIZE 1
SYMBOL 0
LABEL
ANGLE AUTO
ANTIALIAS TRUE
BUFFER 2
COLOR 0 0 0
FONT Arial
FORCE FALSE
MAXSIZE 256
MINDISTANCE 100
MINFEATURESIZE AUTO
MINSIZE 4
OFFSET 0 0
PARTIALS FALSE
POSITION uc
SIZE 8
TYPE TRUETYPE
END
END
END
LAYER
NAME street8
GROUP defaultLayer
TYPE LINE
TILEINDEX td_08.shp
STATUS OFF
LABELITEM "NAME"
CLASSITEM "FRC"
MAXSCALE 10000
CLASS
NAME "Allies & Small Streets"
COLOR 126 126 126
MAXSIZE 50
MINSIZE 0
SIZE 1
SYMBOL 0
LABEL
ANGLE AUTO
ANTIALIAS TRUE
BUFFER 2
COLOR 0 0 0
FONT Arial
FORCE FALSE
MAXSIZE 256
MINDISTANCE 100
MINFEATURESIZE AUTO
MINSIZE 4
OFFSET 0 0
PARTIALS FALSE
POSITION uc
SIZE 6
TYPE TRUETYPE
END
END
END
LAYER
NAME street7
GROUP defaultLayer
TYPE LINE
TILEINDEX td_07.shp
STATUS ON
LABELITEM "NAME"
CLASSITEM "FRC"
MAXSCALE 10000
CLASS
NAME "Small Streets"
COLOR 126 126 126
MAXSIZE 50
MINSIZE 0
SIZE 1
SYMBOL 0
LABEL
ANGLE AUTO
ANTIALIAS TRUE
BUFFER 2
COLOR 0 0 0
FONT Arial
FORCE FALSE
MAXSIZE 256
MINDISTANCE 100
MINFEATURESIZE AUTO
MINSIZE 4
OFFSET 0 0
PARTIALS FALSE
POSITION uc
SIZE 8
TYPE TRUETYPE
END
END
END
LAYER
NAME street6
GROUP defaultLayer
TYPE LINE
TILEINDEX td_06.shp
STATUS ON
LABELITEM "NAME"
CLASSITEM "FRC"
MAXSCALE 90000
CLASS
NAME "Small surface streets"
COLOR 126 126 126
MAXSIZE 50
MINSIZE 0
SIZE 1
SYMBOL 0
LABEL
ANGLE AUTO
ANTIALIAS TRUE
BUFFER 2
COLOR 0 0 0
FONT Arial
FORCE FALSE
MAXSIZE 256
MINDISTANCE 100
MINFEATURESIZE AUTO
MINSIZE 4
OFFSET 0 0
PARTIALS FALSE
POSITION uc
SIZE 8
TYPE TRUETYPE
END
END
END
LAYER
NAME street5
GROUP defaultLayer
TYPE LINE
TILEINDEX td_05.shp
STATUS ON
LABELITEM "NAME"
CLASSITEM "FRC"
MAXSCALE 100000
MINSCALE 0.01
CLASS
NAME "Streets"
COLOR 126 126 126
MAXSIZE 50
MINSIZE 0
SIZE 1
SYMBOL 0
LABEL
ANGLE AUTO
ANTIALIAS TRUE
BUFFER 2
COLOR 0 0 0
FONT Arial
FORCE FALSE
MINDISTANCE 100
MINFEATURESIZE AUTO
OFFSET 0 0
PARTIALS FALSE
POSITION uc
SIZE 8
TYPE TRUETYPE
END
END
END
LAYER
NAME street4
GROUP defaultLayer
TYPE LINE
TILEINDEX td_04.shp
STATUS ON
LABELITEM "NAME"
CLASSITEM "FRC"
MAXSCALE 150000
CLASS
NAME "Major Streets"
COLOR 126 126 126
MAXSIZE 50
MINSIZE 0
SIZE 2
SYMBOL "circle"
LABEL
ANGLE AUTO
ANTIALIAS TRUE
BUFFER 2
COLOR 0 0 0
FONT Arial
FORCE FALSE
MAXSIZE 256
MINDISTANCE 100
MINFEATURESIZE AUTO
MINSIZE 4
OFFSET 0 0
PARTIALS FALSE
POSITION uc
SIZE 8
TYPE TRUETYPE
END
END
END
LAYER
NAME street3
GROUP defaultLayer
TYPE LINE
TILEINDEX td_03.shp
STATUS ON
LABELITEM "NAME"
CLASSITEM "FRC"
MAXSCALE 2000000
CLASS
NAME "Highways"
COLOR 88 88 88
SIZE 2
SYMBOL 'circle'
LABEL
ANGLE AUTO
ANTIALIAS TRUE
BUFFER 2
COLOR 0 0 0
FONT Arial
FORCE FALSE
MAXSIZE 256
MINDISTANCE 100
MINFEATURESIZE AUTO
MINSIZE 4
OFFSET 0 0
PARTIALS FALSE
POSITION uc
SIZE 8
TYPE TRUETYPE
END
END
END
LAYER
NAME street1
GROUP defaultLayer
TYPE LINE
TILEINDEX td_01.shp
#DATA usa06037______01
STATUS ON
#LABELITEM "NAME"
#MAXSCALE 15550000.0
#MINSCALE 0.00001
CLASS
NAME "US Highways"
COLOR 105 105 105
SIZE 3
SYMBOL 'circle'
LABEL
ANGLE AUTO
ANTIALIAS TRUE
BUFFER 2
COLOR 0 0 0
FONT Arial
FORCE FALSE
#MINDISTANCE 5
MINFEATURESIZE AUTO
OFFSET 0 0
PARTIALS FALSE
POSITION lr
SIZE 8
TYPE TRUETYPE
END
END
END
LAYER
NAME street1
GROUP defaultLayer
TYPE LINE
TILEINDEX td_01.shp
STATUS ON
#LABELITEM "NAME"
#MINSCALE 0.00001
CLASS
NAME "US Highways"
COLOR 188 188 188
SIZE 1
SYMBOL 'circle'
END
END
LAYER
NAME street0
GROUP defaultLayer
TYPE LINE
TILEINDEX td_00.shp
STATUS ON
#LABELITEM "NAME"
#MAXSCALE 15550000
#MINSCALE 0.001
CLASS
NAME "Interstates"
COLOR 61 61 61
SIZE 3
SYMBOL 'circle'
END
END
LAYER
NAME street0
GROUP defaultLayer
TYPE LINE
TILEINDEX td_00.shp
STATUS ON
LABELITEM "NAME"
#MAXSCALE 15550000
#MINSCALE 0.001
CLASS
COLOR 188 188 188
SIZE 1
SYMBOL 'circle'
END
END
LAYER
NAME street01_annotation
GROUP defaultLayer
STATUS ON
TILEINDEX td_01.shp
TYPE ANNOTATION
LABELITEM "ROUTENUM"
CLASSITEM "NAME"
MAXSCALE 4500000
#CLASS
# EXPRESSION /.*\/.*/
# END
CLASS
EXPRESSION /HWY.*/
COLOR 0 0 0
SYMBOL 'symbols/sthwy.png'
LABEL
COLOR 0 0 0
WRAP "/"
#MINFEATURESIZE 40
MINDISTANCE 300
POSITION cc
PARTIALS FALSE
SIZE tiny
END
END
CLASS
EXPRESSION /US.*/
COLOR 0 0 0
SYMBOL 'symbols/ushwy.png'
LABEL
COLOR 0 0 0
WRAP "/"
#MINFEATURESIZE 40
MINDISTANCE 300
POSITION cc
PARTIALS FALSE
SIZE tiny
END
END
CLASS
EXPRESSION /I.*/
COLOR 0 0 0
SYMBOL 'symbols/interstate.png'
LABEL
COLOR 255 255 255
WRAP "/"
#MINFEATURESIZE 40
MINDISTANCE 300
POSITION cc
PARTIALS FALSE
SIZE tiny
END
END
END
LAYER
NAME street00_annotation
GROUP defaultLayer
STATUS ON
TILEINDEX td_00.shp
TYPE ANNOTATION
CLASSITEM "NAME"
MAXSCALE 4500000
CLASS
COLOR 200 0 0
LABEL
COLOR 255 255 255
WRAP "/"
#MINFEATURESIZE 40
MINDISTANCE 200
POSITION cc
PARTIALS FALSE
SIZE TINY
END
END
END
# LAYER
# NAME county
# GROUP defaultLayer
# TYPE POLYGON
# TILEINDEX td_a8.shp
# STATUS ON
# LABELITEM "NAME"
# CLASSITEM "NAME"
# MAXSCALE 40000
# CLASS
# NAME "County Boundary"
# COLOR 245 245 245
# OUTLINECOLOR 97 97 97
# MAXSIZE 50
# MINSIZE 0
# SIZE 1
# # SYMBOL 'circle'
# LABEL
# ANGLE AUTO
# ANTIALIAS TRUE
# BUFFER 2
# COLOR 0 0 0
# FONT Arial
# FORCE FALSE
# MAXSIZE 256
# MINDISTANCE 10
# MINSIZE 4
# OFFSET 0 0
# PARTIALS FALSE
# POSITION AUTO
# SIZE 12
# TYPE TRUETYPE
# END
# END
# END
# LAYER
# NAME urbanAreas
# TYPE POLYGON
# TILEINDEX td_oa2.shp
# STATUS ON
# LABELITEM "NAME"
# CLASSITEM "FEATTYP"
# MAXSCALE 5000
# CLASS
# NAME "Urban Area"
# EXPRESSION ( ( [FEATTYP] = 9342 ) )
# COLOR 238 232 205
# OUTLINECOLOR 250 235 215
# MAXSIZE 50
# MINSIZE 0
# SIZE 1
# # SYMBOL 'circle'
# LABEL
# ANGLE AUTO
# ANTIALIAS TRUE
# BUFFER 2
# COLOR 0 0 0
# FONT Arial
# FORCE FALSE
# MAXSIZE 256
# MINDISTANCE 10
# MINSIZE 4
# OFFSET 0 0
# PARTIALS FALSE
# POSITION AUTO
# SIZE 8
# TYPE TRUETYPE
# END
# END
# END
# LAYER
# NAME landUse
# TYPE POLYGON
# #DATA usa06037______lu.shp
# TILEINDEX td_lu.shp
# STATUS ON
# LABELITEM "NAME"
# CLASSITEM "DISPLTYP"
# MAXSCALE 40000
# CLASS
# NAME "Land use"
# COLOR 143 188 143
# OUTLINECOLOR 0 0 0
# MINSIZE 20
# SIZE 1
# # SYMBOL 'circle'
# LABEL
# ANGLE AUTO
# ANTIALIAS TRUE
# BUFFER 2
# COLOR 90 90 90
# WRAP " "
# FONT Arial
# FORCE TRUE
# MAXSIZE 256
# MINDISTANCE 10
# MINFEATURESIZE 100
# MINSIZE 4
# OFFSET 0 0
# PARTIALS TRUE
# POSITION AUTO
# SIZE 8
# TYPE TRUETYPE
# END
# END
# END
# LAYER
# NAME majorWater
# TYPE POLYGON
# TILEINDEX td_wa.shp
# STATUS ON
# LABELITEM "NAME"
# CLASSITEM "NAME"
# MAXSCALE 40000
# CLASS
# COLOR 30 144 255
# OUTLINECOLOR 30 144 255
# SIZE 1
# # SYMBOL 'circle'
# LABEL
# ANGLE AUTO
# ANTIALIAS TRUE
# BUFFER 2
# COLOR 96 96 96
# WRAP " "
# FONT Arial
# FORCE FALSE
# MAXSIZE 256
# MINDISTANCE 10
# MINSIZE 4
# OFFSET 0 0
# PARTIALS FALSE
# POSITION AUTO
# SIZE 10
# TYPE TRUETYPE
# END
# END
# END
# LAYER
# NAME minorWater
# TYPE LINE
# TILEINDEX td_wl.shp
# STATUS ON
# LABELITEM "NAME"
# CLASSITEM "NAME"
# MAXSCALE 40000
# CLASS
# NAME "River"
# COLOR 99 184 255
# MAXSIZE 50
# MINSIZE 0
# SIZE 3
# SYMBOL 'circle'
# LABEL
# ANGLE AUTO
# ANTIALIAS TRUE
# BUFFER 2
# COLOR 0 0 0
# FONT Arial
# FORCE TRUE
# MAXSIZE 256
# MINDISTANCE 100
# MINSIZE 4
# OFFSET 0 0
# PARTIALS FALSE
# POSITION AUTO
# SIZE 8
# TYPE TRUETYPE
# END
# END
# END
# LAYER
# NAME bridges
# TYPE LINE
# TILEINDEX td_ls.shp
# STATUS ON # blah
# LABELITEM "NAME"
# CLASSITEM "STRUCTTYP"
# MAXSCALE 70000
# CLASS
# NAME "Bridge"
# COLOR 126 126 126
# MAXSIZE 50
# MINSIZE 0
# SIZE 1
# SYMBOL "circle"
# OVERLAYBACKGROUNDCOLOR 255 255 255
# OVERLAYCOLOR 126 126 126
# OVERLAYOUTLINECOLOR 0 0 0
# OVERLAYSIZE 1
# OVERLAYMINSIZE 0
# OVERLAYMAXSIZE 50
# OVERLAYSYMBOL 0
# LABEL
# ANGLE AUTO
# ANTIALIAS TRUE
# BUFFER 2
# COLOR 0 0 0
# FONT Arial
# FORCE FALSE
# MAXSIZE 256
# MINDISTANCE 10
# MINSIZE 4
# OFFSET 0 0
# PARTIALS FALSE
# POSITION AUTO
# SIZE 8
# TYPE TRUETYPE
# END
# END
# END
# LAYER
# NAME ferries
# TYPE LINE
# TILEINDEX td_fe.shp
# STATUS ON # blah
# LABELITEM "NAME"
# CLASSITEM "FRC"
# MAXSCALE 70000
# CLASS
# NAME "Ferry"
# BACKGROUNDCOLOR 255 255 255
# COLOR 126 126 126
# MAXSIZE 50
# MINSIZE 0
# SIZE 1
# SYMBOL 'circle'
# OVERLAYSIZE 1
# OVERLAYMINSIZE 0
# OVERLAYMAXSIZE 50
# OVERLAYSYMBOL 0
# LABEL
# ANGLE AUTO
# ANTIALIAS TRUE
# BUFFER 2
# COLOR 0 0 0
# FONT Arial
# FORCE FALSE
# MAXSIZE 256
# MINDISTANCE 10
# MINSIZE 4
# OFFSET 0 0
# PARTIALS FALSE
# POSITION AUTO
# SIZE 8
# TYPE TRUETYPE
# END
# END
# END
# LAYER
# NAME street8
# TYPE LINE
# TILEINDEX td_08.shp
# STATUS ON # blah
# LABELITEM "NAME"
# CLASSITEM "FRC"
# MAXSCALE 10000
# CLASS
# NAME "Alleys & Small Streets"
# COLOR 126 126 126
# MAXSIZE 50
# MINSIZE 0
# SIZE 1
# SYMBOL 'circle'
# OVERLAYSIZE 1
# OVERLAYMINSIZE 0
# OVERLAYMAXSIZE 50
# OVERLAYSYMBOL 0
# LABEL
# ANGLE AUTO
# ANTIALIAS TRUE
# BUFFER 2
# COLOR 0 0 0
# FONT Arial
# FORCE FALSE
# MAXSIZE 256
# MINDISTANCE 10
# MINSIZE 4
# OFFSET 0 0
# PARTIALS FALSE
# POSITION AUTO
# SIZE 6
# TYPE TRUETYPE
# END
# END
# END
# LAYER
# NAME street7
# TYPE LINE
# TILEINDEX td_07.shp
# STATUS ON # blah
# LABELITEM "NAME"
# CLASSITEM "FRC"
# MAXSCALE 10000
# CLASS
# NAME "Small Streets"
# COLOR 126 126 126
# MAXSIZE 50
# MINSIZE 0
# SIZE 1
# SYMBOL 'circle'
# OVERLAYSIZE 1
# OVERLAYMINSIZE 0
# OVERLAYMAXSIZE 50
# OVERLAYSYMBOL 0
# LABEL
# ANGLE AUTO
# ANTIALIAS TRUE
# BUFFER 2
# COLOR 0 0 0
# FONT Arial
# FORCE FALSE
# MAXSIZE 256
# MINDISTANCE 10
# MINSIZE 4
# OFFSET 0 0
# PARTIALS FALSE
# POSITION AUTO
# SIZE 8
# TYPE TRUETYPE
# END
# END
# END
# LAYER
# NAME street6
# TYPE LINE
# TILEINDEX td_06.shp
# STATUS ON # blah
# LABELITEM "NAME"
# CLASSITEM "FRC"
# MAXSCALE 40000
# CLASS
# NAME "Small surface streets"
# COLOR 126 126 126
# MAXSIZE 50
# MINSIZE 0
# SIZE 1
# SYMBOL 'circle'
# OVERLAYSIZE 1
# OVERLAYMINSIZE 0
# OVERLAYMAXSIZE 50
# OVERLAYSYMBOL 0
# LABEL
# ANGLE AUTO
# ANTIALIAS TRUE
# BUFFER 2
# COLOR 0 0 0
# FONT Arial
# FORCE FALSE
# MAXSIZE 256
# MINDISTANCE 10
# MINSIZE 4
# OFFSET 0 0
# PARTIALS FALSE
# POSITION AUTO
# SIZE 8
# TYPE TRUETYPE
# END
# END
# END
# LAYER
# NAME street5
# TYPE LINE
# TILEINDEX td_05.shp
# STATUS ON # blah
# LABELITEM "NAME"
# CLASSITEM "FRC"
# MAXSCALE 40000
# CLASS
# NAME "Streets"
# COLOR 126 126 126
# MAXSIZE 50
# MINSIZE 0
# SIZE 1
# SYMBOL 'circle'
# OVERLAYSIZE 1
# OVERLAYMINSIZE 0
# OVERLAYMAXSIZE 50
# OVERLAYSYMBOL 0
# LABEL
# ANGLE AUTO
# ANTIALIAS TRUE
# BUFFER 2
# COLOR 0 0 0
# FONT Arial
# FORCE FALSE
# MAXSIZE 256
# MINDISTANCE 10
# MINSIZE 4
# OFFSET 0 0
# PARTIALS FALSE
# POSITION AUTO
# SIZE 8
# TYPE TRUETYPE
# END
# END
# END
# LAYER
# NAME street4
# TYPE LINE
# TILEINDEX td_04.shp
# STATUS ON # blah
# LABELITEM "NAME"
# CLASSITEM "FRC"
# MAXSCALE 90000
# CLASS
# NAME "Major Streets"
# COLOR 126 126 126
# MAXSIZE 50
# MINSIZE 0
# SIZE 1
# SYMBOL 'circle'
# OVERLAYSIZE 1
# OVERLAYMINSIZE 0
# OVERLAYMAXSIZE 50
# OVERLAYSYMBOL 0
# LABEL
# ANGLE AUTO
# ANTIALIAS TRUE
# BUFFER 2
# COLOR 0 0 0
# FONT Arial
# FORCE FALSE
# MAXSIZE 256
# MINDISTANCE 10
# MINSIZE 4
# OFFSET 0 0
# PARTIALS FALSE
# POSITION AUTO
# SIZE 8
# TYPE TRUETYPE
# END
# END
# END
# LAYER
# NAME street3
# TYPE LINE
# TILEINDEX td_03.shp
# STATUS ON # blah
# LABELITEM "NAME"
# CLASSITEM "FRC"
# MAXSCALE 2000000
# CLASS
# NAME "Highways"
# COLOR 88 88 88
# SIZE 2
# SYMBOL 'circle'
# LABEL
# ANGLE AUTO
# ANTIALIAS TRUE
# BUFFER 2
# COLOR 0 0 0
# OUTLINECOLOR 255 255 255
# FONT Arial
# FORCE FALSE
# MAXSIZE 256
# MINDISTANCE 100
# MINSIZE 4
# OFFSET 0 0
# PARTIALS FALSE
# POSITION uc
# SIZE 8
# TYPE TRUETYPE
# END
# END
# END
# LAYER
# NAME street1
# TYPE LINE
# TILEINDEX td_01.shp
# #DATA usa06037______01
# STATUS ON # blah
# #MAXSCALE 40000
# CLASS
# NAME "US Highways"
# COLOR 105 105 105
# SIZE 3
# SYMBOL 'circle'
# LABEL
# ANGLE AUTO
# ANTIALIAS TRUE
# BUFFER 2
# COLOR 0 0 0
# FONT Arial
# FORCE FALSE
# #MINDISTANCE 5
# OFFSET 0 0
# PARTIALS FALSE
# POSITION uc
# SIZE 8
# TYPE TRUETYPE
# END
# END
# END
# LAYER
# NAME street1
# TYPE LINE
# STATUS ON # blah
# #LABELITEM "NAME"
# #MAXSCALE 15550000.0
# #MINSCALE 0.00001
# CLASS
# COLOR 188 188 188
# SIZE 1
# SYMBOL 'circle'
# END
# END
# LAYER
# NAME street0
# TYPE LINE
# TILEINDEX td_00.shp
# STATUS ON # blah
# #MAXSCALE 40000
# CLASS
# NAME "Interstates"
# COLOR 61 61 61
# SIZE 3
# SYMBOL 'circle'
# END
# END
# LAYER
# NAME street0
# TYPE LINE
# STATUS ON # blah
# CLASS
# COLOR 188 188 188
# SIZE 1
# SYMBOL 'circle'
# END
# END
# LAYER
# NAME street01_annotation
# STATUS ON # blah
# TYPE ANNOTATION
# LABELITEM "ROUTENUM"
# CLASSITEM "NAME"
# #MAXSCALE 40000
# CLASS
# EXPRESSION /HWY.*/
# COLOR 0 0 0
# SYMBOL 'symbols/sthwy.png'
# LABEL
# COLOR 0 0 0
# WRAP "/"
# #MINFEATURESIZE 40
# MINDISTANCE 200
# POSITION CC
# PARTIALS false
# SIZE tiny
# END
# END
# CLASS
# EXPRESSION /US.*/
# COLOR 0 0 0
# SYMBOL 'symbols/ushwy.png'
# LABEL
# COLOR 0 0 0
# WRAP "/"
# MINDISTANCE 200
# POSITION CC
# PARTIALS false
# SIZE tiny
# END
# END
# CLASS
# EXPRESSION /I.*/
# COLOR 0 0 0
# SYMBOL 'symbols/interstate.png'
# LABEL
# COLOR 255 255 255
# WRAP "/"
# MINDISTANCE 200
# POSITION CC
# PARTIALS false
# SIZE tiny
# END
# END
# END
# LAYER
# NAME street00_annotation
# STATUS ON # blah
# TYPE ANNOTATION
# MAXSCALE 4500000
# CLASS
# COLOR 200 0 0
# LABEL
# COLOR 255 255 255
# WRAP "/"
# MINDISTANCE 200
# POSITION CC
# PARTIALS false
# SIZE TINY
# END
# END
# END
# LAYER
# NAME pointsOfInterest
# TYPE POINT
# TILEINDEX td_pi.shp
# STATUS ON
# LABELITEM "NAME"
# MAXSCALE 40000
# CLASS
# # museum
# EXPRESSION ( ( [FEATTYP] = 7317 ) )
# NAME "Museum"
# COLOR 126 126 126
# MAXSIZE 50
# MINSIZE 0
# SIZE 8
# SYMBOL 'circle'
# LABEL
# WRAP " "
# ANGLE AUTO
# ANTIALIAS TRUE
# BUFFER 2
# COLOR 0 0 0
# WRAP " "
# FONT Arial
# FORCE FALSE
# MAXSIZE 256
# MINDISTANCE 10
# MINSIZE 4
# OFFSET 0 0
# PARTIALS FALSE
# POSITION AUTO
# SIZE 7
# TYPE TRUETYPE
# END
# END
# CLASS
# # shopping center
# EXPRESSION ( ( [FEATTYP] = 7373 ) )
# NAME "Shopping Center"
# COLOR 126 126 126
# MAXSIZE 50
# MINSIZE 0
# SIZE 8
# SYMBOL 'circle'
# LABEL
# WRAP " "
# ANGLE AUTO
# ANTIALIAS TRUE
# BUFFER 2
# COLOR 0 0 0
# FONT Arial
# FORCE FALSE
# MAXSIZE 256
# MINDISTANCE 10
# MINSIZE 4
# OFFSET 0 0
# PARTIALS FALSE
# POSITION AUTO
# SIZE 6
# TYPE TRUETYPE
# END
# END
# CLASS
# # outdoor stadium
# EXPRESSION ( ( [FEATTYP] == 7374 ) )
# NAME "Stadium"
# COLOR 126 126 126
# MAXSIZE 50
# MINSIZE 0
# SIZE 8
# SYMBOL 'circle'
# LABEL
# WRAP " "
# ANGLE AUTO
# ANTIALIAS TRUE
# BUFFER 2
# COLOR 0 0 0
# FONT Arial
# FORCE FALSE
# MAXSIZE 256
# MINDISTANCE 10
# MINSIZE 4
# OFFSET 0 0
# PARTIALS TRUE
# POSITION AUTO
# SIZE 7
# TYPE TRUETYPE
# END
# END
# CLASS
# # tourist attractions
# EXPRESSION ( ( [FEATTYP] == 7376 ) )
# NAME "Attraction"
# COLOR 126 0 0
# MAXSIZE 50
# MINSIZE 0
# SIZE 8
# SYMBOL 'circle'
# LABEL
# WRAP " "
# ANGLE AUTO
# ANTIALIAS TRUE
# BUFFER 2
# COLOR 0 0 0
# FONT Arial
# FORCE FALSE
# MAXSIZE 256
# MINDISTANCE 10
# MINSIZE 4
# OFFSET 0 0
# PARTIALS TRUE
# POSITION AUTO
# SIZE 7
# TYPE TRUETYPE
# END
# END
# CLASS
# # university & college
# EXPRESSION ( ( [FEATTYP] == 7377 ) )
# NAME "University"
# COLOR 126 126 255
# OUTLINECOLOR 255 0 0
# MAXSIZE 50
# MINSIZE 0
# SIZE 8
# SYMBOL 'circle'
# LABEL
# ANGLE AUTO
# WRAP " "
# ANTIALIAS TRUE
# BUFFER 2
# COLOR 0 0 0
# FONT Arial
# FORCE FALSE
# MAXSIZE 256
# MINDISTANCE 10
# MINSIZE 4
# OFFSET 0 0
# PARTIALS TRUE
# POSITION AUTO
# SIZE 7
# TYPE TRUETYPE
# END
# END
# CLASS
# # railway station
# EXPRESSION ( ( [FEATTYP] == 7380 ) )
# NAME "Rail Station"
# COLOR 255 255 255
# SIZE 40
# SYMBOL 'transBack'
# OVERLAYSYMBOL 'railIcon'
# OVERLAYCOLOR 0 0 170
# OVERLAYSIZE 40
# LABEL
# WRAP " "
# ANGLE AUTO
# ANTIALIAS TRUE
# BUFFER 2
# COLOR 0 0 0
# FONT Arial_Bold
# FORCE FALSE
# MAXSIZE 256
# MINDISTANCE 10
# MINSIZE 4
# OFFSET 0 0
# PARTIALS FALSE
# POSITION AUTO
# SIZE 6
# TYPE TRUETYPE
# END
# END
# CLASS
# # airport
# EXPRESSION ( ( [FEATTYP] == 7383 ) )
# NAME "Airport"
# COLOR 0 0 0
# MAXSIZE 50
# MINSIZE 0
# SIZE 25
# SYMBOL 'airportIcon'
# LABEL
# ANGLE AUTO
# WRAP " "
# ANTIALIAS TRUE
# BUFFER 2
# COLOR 0 0 0
# FONT Arial_Bold
# FORCE FALSE
# MAXSIZE 256
# MINDISTANCE 10
# MINSIZE 4
# OFFSET 0 0
# PARTIALS TRUE
# POSITION AUTO
# SIZE 7
# TYPE TRUETYPE
# END
# END
# CLASS
# # conference and exhibition centers
# EXPRESSION ( ( [FEATTYP] == 7385 ) )
# NAME "Conference Center"
# COLOR 126 126 126
# MAXSIZE 50
# MINSIZE 0
# SIZE 8
# SYMBOL 'circle'
# LABEL
# WRAP " "
# ANGLE AUTO
# ANTIALIAS TRUE
# BUFFER 2
# COLOR 0 0 0
# FONT Arial
# FORCE FALSE
# MAXSIZE 256
# MINDISTANCE 10
# MINSIZE 4
# OFFSET 0 0
# PARTIALS TRUE
# POSITION AUTO
# SIZE 7
# TYPE TRUETYPE
# END
# END
# CLASS
# # rest areas
# EXPRESSION ( ( [FEATTYP] = 7395 ) )
# NAME "Rest Area"
# COLOR 255 255 255
# MAXSIZE 50
# MINSIZE 0
# SIZE 30
# OVERLAYSIZE 30
# OVERLAYCOLOR 0 0 180
# OVERLAYSYMBOL 'restAreaIcon'
# TEXT "Rest Area"
# LABEL
# WRAP " "
# ANGLE AUTO
# ANTIALIAS TRUE
# BUFFER 2
# COLOR 0 0 0
# FONT Arial
# FORCE FALSE
# MAXSIZE 256
# MINDISTANCE 10
# MINSIZE 4
# OFFSET 0 0
# PARTIALS TRUE
# POSITION lr
# SIZE 12
# TYPE TRUETYPE
# END
# END
# CLASS
# # zoo
# EXPRESSION ( ( [FEATTYP] == 9927 ) )
# NAME "Zoo"
# COLOR 126 126 126
# MAXSIZE 50
# MINSIZE 0
# SIZE 8
# SYMBOL 'circle'
# LABEL
# WRAP " "
# ANGLE AUTO
# ANTIALIAS TRUE
# BUFFER 2
# COLOR 0 0 0
# FONT Arial
# FORCE FALSE
# MAXSIZE 256
# MINDISTANCE 10
# MINSIZE 4
# OFFSET 0 0
# PARTIALS TRUE
# POSITION AUTO
# SIZE 7
# TYPE TRUETYPE
# END
# END
# END
# LAYER
# NAME cityCenter
# TYPE POINT
# TILEINDEX td_sm.shp
# STATUS ON
# LABELITEM "NAME"
# CLASSITEM "DISPCLASS"
# MAXSCALE 40000
# CLASS
# EXPRESSION ( ( [DISPCLASS] = 3 ) )
# #NAME "Big City"
# COLOR 126 126 126
# MAXSIZE 50
# MINSIZE 1
# SIZE 10
# SYMBOL 'circle'
# LABEL
# ANGLE AUTO
# ANTIALIAS TRUE
# BUFFER 2
# COLOR 0 0 0
# WRAP " "
# FONT Arial_Bold
# FORCE TRUE
# MAXSIZE 256
# MINDISTANCE 10
# MINSIZE 4
# OFFSET 2 2
# PARTIALS TRUE
# POSITION AUTO
# SIZE 14
# TYPE TRUETYPE
# END
# END
# CLASS
# EXPRESSION ( ( [DISPCLASS] = 6 ) )
# #NAME "Medium City"
# COLOR 126 126 126
# MAXSIZE 50
# MINSIZE 1
# SIZE 7
# SYMBOL 'circleNoFill'
# LABEL
# ANGLE AUTO
# ANTIALIAS TRUE
# BUFFER 2
# COLOR 0 0 0
# WRAP " "
# FONT Arial_Bold
# FORCE TRUE
# MAXSIZE 256
# MINDISTANCE 10
# MINSIZE 4
# OFFSET 0 0
# PARTIALS TRUE
# POSITION AUTO
# SIZE 11
# TYPE TRUETYPE
# END
# END
# CLASS
# EXPRESSION ( ( [DISPCLASS] = 7 ) )
# #NAME "Small City"
# COLOR 126 126 126
# MAXSIZE 50
# MINSIZE 0
# SIZE 1
# SYMBOL 'circle'
# LABEL
# ANGLE AUTO
# ANTIALIAS TRUE
# BUFFER 2
# COLOR 0 0 0
# WRAP " "
# FONT Arial
# FORCE FALSE
# MAXSIZE 256
# MINDISTANCE 10
# MINSIZE 4
# OFFSET 0 0
# PARTIALS TRUE
# POSITION AUTO
# SIZE 10
# TYPE TRUETYPE
# END
# END
# CLASS
# EXPRESSION ( ( [DISPCLASS] = 8 ) )
# #NAME "Big Town"
# COLOR 126 126 126
# MAXSIZE 50
# MINSIZE 0
# SIZE 1
# SYMBOL 'circle'
# LABEL
# ANGLE AUTO
# ANTIALIAS TRUE
# BUFFER 2
# COLOR 0 0 0
# WRAP " "
# FONT Arial_Bold
# FORCE TRUE
# MAXSIZE 256
# MINDISTANCE 10
# MINSIZE 4
# OFFSET 0 0
# PARTIALS TRUE
# POSITION AUTO
# FORCE FALSE
# MAXSIZE 256
# MINDISTANCE 10
# MINSIZE 4
# OFFSET 0 0
# PARTIALS TRUE
# POSITION AUTO
# SIZE 8
# TYPE TRUETYPE
# END
# END
# CLASS
# EXPRESSION ( ( [DISPCLASS] = 9 ) )
# #NAME "Medium Town"
# COLOR 126 126 126
# MAXSIZE 50
# MINSIZE 0
# SIZE 1
# SYMBOL 'circle'
# LABEL
# ANGLE AUTO
# ANTIALIAS TRUE
# BUFFER 2
# COLOR 0 0 0
# WRAP " "
# FONT Arial
# FORCE FALSE
# MAXSIZE 256
# MINDISTANCE 10
# MINSIZE 4
# OFFSET 0 0
# PARTIALS TRUE
# POSITION AUTO
# SIZE 8
# TYPE TRUETYPE
# END
# END
# CLASS
# EXPRESSION ( ( [DISPCLASS] = 10 ) )
# #NAME "Village"
# COLOR 126 126 126
# MAXSIZE 50
# MINSIZE 0
# SIZE 3
# SYMBOL 'circle'
# LABEL
# ANGLE AUTO
# ANTIALIAS TRUE
# BUFFER 2
# COLOR 0 0 0
# WRAP " "
# FONT Arial
# FORCE FALSE
# MAXSIZE 256
# MINDISTANCE 10
# MINSIZE 4
# OFFSET 0 0
# PARTIALS TRUE
# POSITION AUTO
# SIZE 8
# TYPE TRUETYPE
# END
# END
# CLASS
# EXPRESSION ( ( [DISPCLASS] = 11 ) )
# #NAME "Community"
# COLOR 126 126 126
# MAXSIZE 50
# MINSIZE 0
# SIZE 2
# SYMBOL 'circle'
# LABEL
# ANGLE AUTO
# ANTIALIAS TRUE
# BUFFER 2
# COLOR 0 0 0
# WRAP " "
# FONT Arial
# FORCE FALSE
# MAXSIZE 256
# MINDISTANCE 10
# MINSIZE 4
# OFFSET 0 0
# PARTIALS TRUE
# POSITION AUTO
# SIZE 8
# TYPE TRUETYPE
# END
# END
# CLASS
# EXPRESSION ( ( [DISPCLASS] = "12" ) )
# #NAME "Small Community"
# COLOR 126 126 126
# MAXSIZE 50
# MINSIZE 0
# SIZE 1
# SYMBOL 'circle'
# LABEL
# ANGLE AUTO
# ANTIALIAS TRUE
# BUFFER 2
# COLOR 0 0 0
# WRAP " "
# FONT Arial
# FORCE FALSE
# MAXSIZE 256
# MINDISTANCE 10
# MINSIZE 4
# OFFSET 0 0
# PARTIALS TRUE
# POSITION AUTO
# SIZE 8
# TYPE TRUETYPE
# END
# END
# END
LAYER
NAME MSensors1
TYPE POINT
STATUS ON
TILEINDEX sensors/means.shp
CLASSITEM LEVEL
LABELITEM LEVEL
MAXSCALE 30000
CLASS
NAME 'fast'
EXPRESSION ( ( [SPEED] > 55 ) AND ( [LEVEL] == 1 ) )
OUTLINECOLOR 0 255 0
SIZE 11
OVERLAYSYMBOL 'circleNoFill'
OVERLAYOUTLINECOLOR 0 255 0
OVERLAYSIZE 8
TEXT ( [LEVEL]/[ID]/[SPEED] )
LABEL
BUFFER 2
ANGLE AUTO
ANTIALIAS TRUE
COLOR 50 50 50
FONT Arial
POSITION AUTO
SIZE 20
TYPE TRUETYPE
END
END
CLASS
NAME 'medium'
EXPRESSION ( ( [SPEED] >= 35 ) AND ( [SPEED] <= 55 ) AND (
[LEVEL] == 1 ) )
OUTLINECOLOR 255 255 0
SIZE 11
OVERLAYOUTLINECOLOR 255 255 0
OVERLAYSIZE 8
END
CLASS
NAME 'mediumslow'
EXPRESSION ( ( [SPEED] >= 20 ) AND ( [SPEED] <= 35 ) AND (
[LEVEL] == 1 ) )
OUTLINECOLOR 255 128 0
SIZE 11
OVERLAYOUTLINECOLOR 255 128 0
OVERLAYSIZE 8
END
CLASS
NAME 'slow'
EXPRESSION ( ( [SPEED] < 20 ) AND ( [SPEED] > 0 ) AND (
[LEVEL] == 1 ) )
SIZE 11
OVERLAYOUTLINECOLOR 255 0 0
OVERLAYSIZE 8
END
END
LAYER
NAME MSensors2
TYPE POINT
STATUS ON
CLASSITEM LEVEL
MINSCALE 30001
MAXSCALE 200000
CLASS
NAME 'fast'
EXPRESSION ( ( [SPEED] > 55 ) AND ( [LEVEL] == 2 ) )
SIZE 9
OVERLAYSIZE 7
END
CLASS
NAME 'medium'
[LEVEL] == 2 ) )
SIZE 9
OVERLAYSIZE 7
END
CLASS
NAME 'mediumslow'
[LEVEL] == 2 ) )
SIZE 9
OVERLAYSIZE 7
END
CLASS
NAME 'slow'
[LEVEL] == 2 ) )
SIZE 9
OVERLAYSIZE 7
END
END
LAYER
NAME MSensors3
TYPE POINT
STATUS ON
CLASSITEM LEVEL
MINSCALE 200001
MAXSCALE 1000000
CLASS
NAME 'fast'
EXPRESSION ( ( [SPEED] > 55 ) AND ( [LEVEL] == 3 ) )
SIZE 5
OVERLAYSIZE 4
END
CLASS
NAME 'medium'
[LEVEL] == 3 ) )
SIZE 5
OVERLAYSIZE 4
END
CLASS
NAME 'mediumslow'
[LEVEL] == 3 ) )
SIZE 5
OVERLAYSIZE 4
END
CLASS
NAME 'slow'
[LEVEL] == 3 ) )
SIZE 5
OVERLAYSIZE 4
END
END
LAYER
NAME MSensors4
TYPE POINT
STATUS ON
CLASSITEM LEVEL
MINSCALE 1000001
CLASS
NAME 'fast'
COLOR 0 255 0
SIZE 3
END
CLASS
NAME 'medium'
[LEVEL] == 3 ) )
COLOR 255 255 0
SIZE 3
END
CLASS
NAME 'mediumslow'
[LEVEL] == 3 ) )
COLOR 255 128 0
SIZE 3
END
CLASS
NAME 'slow'
[LEVEL] == 3 ) )
COLOR 255 0 0
SIZE 3
END
END
LAYER
NAME Sensors1
TYPE POINT
STATUS ON
TILEINDEX CurrentSensorData.shp
MAXSCALE 30000
CLASS
NAME 'fast'
COLOR 0 255 0
OUTLINECOLOR 140 140 140
SYMBOL 'circle'
SIZE 11
END
CLASS
NAME 'medium'
[LEVEL] == 1 ) )
COLOR 255 255 0
SYMBOL 'circle'
SIZE 11
END
CLASS
NAME 'mediumslow'
[LEVEL] == 1 ) )
COLOR 255 128 0
SYMBOL 'circle'
SIZE 11
END
CLASS
NAME 'slow'
[LEVEL] == 1 ) )
COLOR 255 0 0
SYMBOL 'circle'
SIZE 11
END
END
LAYER
NAME Sensors2
TYPE POINT
STATUS ON
MINSCALE 30001
MAXSCALE 200000
CLASS
NAME 'fast'
COLOR 0 255 0
SYMBOL 'circle'
SIZE 9
END
CLASS
NAME 'medium'
[LEVEL] == 2 ) )
COLOR 255 255 0
SYMBOL 'circle'
SIZE 9
END
CLASS
NAME 'mediumslow'
[LEVEL] == 2 ) )
COLOR 255 128 0
SYMBOL 'circle'
SIZE 9
END
CLASS
NAME 'slow'
[LEVEL] == 2 ) )
COLOR 255 0 0
SYMBOL 'circle'
SIZE 9
END
END
LAYER
NAME Sensors3
TYPE POINT
STATUS ON
MINSCALE 200001
MAXSCALE 1000000
CLASS
NAME 'fast'
COLOR 0 255 0
#OUTLINECOLOR 140 140 140
SYMBOL 'circle'
SIZE 5
END
CLASS
NAME 'medium'
[LEVEL] == 3 ) )
COLOR 255 255 0
SYMBOL 'circle'
SIZE 5
END
CLASS
NAME 'mediumslow'
[LEVEL] == 3 ) )
COLOR 255 128 0
SYMBOL 'circle'
SIZE 5
END
CLASS
NAME 'slow'
[LEVEL] == 3 ) )
COLOR 255 0 0
SYMBOL 'circle'
SIZE 5
END
END
LAYER
NAME Sensors4
TYPE POINT
STATUS ON
MINSCALE 1000001
CLASS
NAME 'fast'
COLOR 0 255 0
SYMBOL 'circle'
SIZE 3
END
CLASS
NAME 'medium'
[LEVEL] == 3 ) )
COLOR 255 255 0
SYMBOL 'circle'
SIZE 3
END
CLASS
NAME 'mediumslow'
[LEVEL] == 3 ) )
COLOR 255 128 0
SYMBOL 'circle'
SIZE 3
END
CLASS
NAME 'slow'
[LEVEL] == 3 ) )
COLOR 255 0 0
SYMBOL 'circle'
SIZE 3
END
END
LAYER
NAME SensorPoint
TYPE POINT
STATUS ON
CLASS
NAME 'Slow'
COLOR 255 0 0
OUTLINECOLOR 0 0 0
SYMBOL 'circle'
SIZE 6
LABEL
BUFFER 2
ANGLE AUTO
ANTIALIAS TRUE
COLOR 0 0 0
FONT Arial
POSITION AUTO
SIZE 8
TYPE TRUETYPE
END
END
CLASS
NAME 'Medium'
COLOR 255 255 0
OUTLINECOLOR 0 0 0
SYMBOL 'circle'
SIZE 6
LABEL
BUFFER 2
ANGLE AUTO
ANTIALIAS TRUE
COLOR 0 0 0
FONT Arial
POSITION AUTO
SIZE 8
TYPE TRUETYPE
END
END
CLASS
NAME 'Fast'
COLOR 0 255 0
OUTLINECOLOR 0 0 0
SYMBOL 'circle'
SIZE 6
LABEL
BUFFER 2
ANGLE AUTO
ANTIALIAS TRUE
COLOR 0 0 0
FONT Arial
POSITION AUTO
SIZE 8
TYPE TRUETYPE
END
END
CLASS
NAME 'Start'
COLOR 0 255 0
SYMBOL 'star'
SIZE 15
LABEL
ANGLE AUTO
ANTIALIAS TRUE
COLOR 0 255 0
FONT Arial
POSITION AUTO
SIZE 8
TYPE TRUETYPE
END
END
CLASS
NAME 'Finish'
COLOR 255 0 0
SYMBOL 'star'
SIZE 15
LABEL
ANGLE AUTO
ANTIALIAS TRUE
COLOR 255 0 0
FONT Arial
POSITION AUTO
SIZE 8
TYPE TRUETYPE
END
END
CLASS
NAME 'Unknown'
COLOR 128 128 128
OUTLINECOLOR 0 0 0
SYMBOL 'circle'
SIZE 6
LABEL
ANGLE AUTO
ANTIALIAS TRUE
COLOR 128 128 128
FONT Arial
POSITION AUTO
SIZE 8
TYPE TRUETYPE
END
END
CLASS
NAME 'UserStart'
#COLOR 0 255 0
SYMBOL 'star'
SIZE 12
LABEL
ANGLE AUTO
ANTIALIAS TRUE
COLOR 0 255 0
FONT Arial
POSITION AUTO
SIZE 8
TYPE TRUETYPE
END
END
CLASS
NAME 'UserFinish'
#COLOR 255 0 0
SYMBOL 'star'
SIZE 12
LABEL
ANGLE AUTO
ANTIALIAS TRUE
COLOR 255 0 0
FONT Arial
POSITION AUTO
SIZE 8
TYPE TRUETYPE
END
END
END
LAYER
NAME Incident
TYPE POINT
STATUS ON
DATA incidents.shp
MAXSCALE 2000000
CLASS
# test
NAME "Test"
COLOR 0 0 0
MAXSIZE 50
MINSIZE 0
# SIZE 19
# SYMBOL 'event'
SYMBOL 'symbols/incident.png'
# OVERLAYSYMBOL 'triangle'
# OVERLAYCOLOR 255 255 0
# OVERLAYSIZE 14
# TEXT "!"
LABEL
WRAP " "
ANGLE AUTO
ANTIALIAS TRUE
BUFFER 2
COLOR 255 0 0
FONT Arial_Bold
FORCE TRUE
MAXSIZE 256
MINDISTANCE 30
MINSIZE 4
OFFSET 0 0
PARTIALS TRUE
POSITION cc
SIZE 11
TYPE TRUETYPE
END
END
END
LAYER
NAME Labelling
TYPE POLYGON
STATUS ON
TRANSFORM FALSE
LABELCACHE FALSE
CLASS
NAME 'gray'
SIZE 1
COLOR 220 220 220
LABEL
ANTIALIAS TRUE
COLOR 0 0 0
TYPE TRUETYPE
FONT Arial
SIZE 7
POSITION cc
END
END
CLASS
NAME 'red'
SIZE 1
COLOR 230 230 230
LABEL
ANTIALIAS TRUE
COLOR 200 0 0
TYPE TRUETYPE
FONT Arial
SIZE 7
POSITION cc
END
END
CLASS
NAME 'blue'
SIZE 1
COLOR 230 230 230
LABEL
ANTIALIAS TRUE
COLOR 0 0 200
TYPE TRUETYPE
FONT Arial
SIZE 7
POSITION cc
END
END
FEATURE
END
END
LAYER
NAME RouteLine
TYPE LINE
STATUS ON
FEATURE
END
CLASS
NAME 'Path'
COLOR 204 153 255
OUTLINECOLOR 0 0 0
SYMBOL 'circle'
SIZE 15
OVERLAYSYMBOL 'pointer'
OVERLAYCOLOR 155 0 155
OVERLAYSIZE 20
END
END
# Start of web interface definition (including WMS enabling metadata)
# ignored as near as I can tell for what we are doing.
WEB
HEADER route_header.html
TEMPLATE route.html
FOOTER route_footer.html
MINSCALE 0.001
MAXSCALE 15550000
LOG "/tmp/log.txt"
METADATA
WMS_TITLE "TrafficDodger Demo"
WMS_ABSTRACT "This is the TrafficDodger Demo application for Los
Angeles Metro."
WMS_ACCESSCONSTRAINTS none
# change this value to match your setup
WMS_ONLINERESOURCE "http://extempore.otsys.com/~dodger/mapsite/"
WMS_SRS "EPSG:26915"
END
END
END # Map File
Cordially,
Joe Bussell
On Time Systems
