perl mapscript crash "Can't locate
auto/mapscript/classObj/swig_size_s.al"
Joseph Bussell
joe at OTSYS.COM
Thu Jun 9 18:23:33 EDT 2005
No one has any ideas???
Joseph Bussell wrote:
> I have a mapfile that when viewed at certain zoom levels, generates a
> failure. The Apache log indicates that a specific object cannot be
> found. I explicitly turned off all the layers, intending to add them
> one at a time until I observed a failure, but the failure still
> existed for scales 2000001 and higher. I do not understand why some
> Perl module is differentially available based on my scale. Back in
> the days when TrafficDodger was an active application this was
> working. I updated the mapscript to the latest stable rev and had to
> make a few changes (like my extents were improperly ordered). Lower
> scales work nicely. I have other maps that show the whole planet,
> these render nicely. Does anyone have any ideas?
> I am using perl mapscript from version mapserver-4.4.2, ( set up
> with ./configure --with-proj --with-gdal --with-gd --with-perl
> --with-php=../mapserverDeps/php-5.0.2/ )
> Linux 2.6.10-1.771_FC2 #1 built Mon Mar 28 00:50:14 EST 2005 i686
> athlon i386 GNU/Linux
> Server version: Apache/1.3.31 (Unix)
> I offer the error string:
> Can't locate auto/mapscript/classObj/swig_size_s.al in @INC (@INC
> contains: /usr/traffic2/perl
> /usr/lib/perl5/5.8.3/i386-linux-thread-multi /usr/lib/perl5/5.8.3
> /usr/lib/perl5/site_perl/5.8.3/i386-linux-thread-multi
> /usr/lib/perl5/site_perl/5.8.2/i386-linux-thread-multi
> /usr/lib/perl5/site_perl/5.8.1/i386-linux-thread-multi
> /usr/lib/perl5/site_perl/5.8.0/i386-linux-thread-multi
> /usr/lib/perl5/site_perl/5.8.3 /usr/lib/perl5/site_perl/5.8.2
> /usr/lib/perl5/site_perl/5.8.1 /usr/lib/perl5/site_perl/5.8.0
> /usr/lib/perl5/vendor_perl/5.8.3/i386-linux-thread-multi
> /usr/lib/perl5/vendor_perl/5.8.2/i386-linux-thread-multi
> /usr/lib/perl5/vendor_perl/5.8.1/i386-linux-thread-multi
> /usr/lib/perl5/vendor_perl/5.8.0/i386-linux-thread-multi
> /usr/lib/perl5/vendor_perl/5.8.3 /usr/lib/perl5/vendor_perl/5.8.2
> /usr/lib/perl5/vendor_perl/5.8.1 /usr/lib/perl5/vendor_perl/5.8.0
> /usr/lib/perl5/vendor_perl /usr/local/apache/
> /usr/local/apache/lib/perl) at
> /usr/lib/perl5/site_perl/5.8.3/i386-linux-thread-multi/mapscript.pm
> line 35\n
> My map file is as follows:
> # Start of map file
> NAME CA
> STATUS ON
> SIZE 325 325
> PROJECTION
> "proj=latlong"
> END
> #EXTENT -118.236313 34.013892 -118.201033 34.049172
> # EXTENT -118.884 33.39597 -114.487 35.607288
> # xmin, ymin, xmax, ymax
> EXTENT -180.0 -90.0 180.0 90.0
> #These paths are set in mapdrawing.pm via Perl/Mapscript
> #SHAPEPATH "/hardcoded/paths/lead/to/diminished/potency/shapefiles/"
> #FONTSET /hardcoded/paths/lead/to/diminished/potency/fonts.list
> SYMBOLSET symbols.sym
> IMAGECOLOR 161 161 161 TRANSPARENT ON
> UNITS dd
> # you may need to change this to match your MapServer build
> IMAGETYPE PNG
> # The Reference map is the thumbnail map that allows users to
> # quickly navigate over the 'zoomed-out' map.
> REFERENCE
> IMAGE graphics/reference_ca.png
> EXTENT -124.39263784515 32.5357813439163 -114.125230507624
> 42.0021917751363
> SIZE 120 120
> STATUS ON
> COLOR -1 -1 -1
> OUTLINECOLOR 255 0 0
> END
> # The legend
> LEGEND
> STATUS OFF
> KEYSIZE 18 12
> LABEL
> TYPE TRUETYPE
> FONT Arial
> SIZE 8
> COLOR 0 0 89
> END
> END
> # Scalebar
> SCALEBAR
> STATUS ON
> COLOR 0 0 0
> IMAGECOLOR 230 230 230
> POSTLABELCACHE FALSE
> LABEL
> COLOR 0 0 0
> SIZE tiny
> END
> STYLE 1
> SIZE 200 3
> POSITION lr
> UNITS MILES
> INTERVALS 5
> TRANSPARENT FALSE
> END
> # td_* are layers derived from tileing the TANA shapefiles
> # order is important as the first layer declared is painted first.
> # the scales are determined by MapServer as follows:
> # map_distance = (map_width-1)/(MS_PPI*inches_per_unit);
> # ground_distance = extent_maxx - extent_minx;
> # scale = ground_distance/map_distance;
> #where
> # MS_PPI = number of pixels per inch for a computer monitor = 72;
> # inches_per_unit = number of inches per map unit (i.e. UNITS ...)
> LAYER
> NAME background
> TYPE polygon
> STATUS ON
> # MAXSCALE 20000
> CLASS
> NAME "World"
> OUTLINECOLOR 0 0 0
> COLOR 30 144 255
> SIZE 1
> SYMBOL 0
> END
> FEATURE
> POINTS
> -180 90
> -180 -90
> 180 -90
> 180 90
> -180 90 END
> END
> END
> LAYER
> NAME world
> DATA world.shp
> STATUS ON
> # LABELITEM "NAME"
> CLASSITEM "NAME"
> TYPE POLYGON
> # MAXSCALE 20000
> CLASS
> NAME "World"
> OUTLINECOLOR 0 0 0
> COLOR 0 255 100
> SIZE 1
> SYMBOL 0
> LABEL
> ANGLE AUTO
> ANTIALIAS TRUE
> BUFFER 2
> COLOR 0 0 0
> FONT Georgia
> FORCE FALSE
> MINDISTANCE 10
> MINFEATURESIZE 25
> # MINSIZE 5
> # MAXSIZE 256
> PARTIALS FALSE
> POSITION cc
> SIZE 10
> TYPE TRUETYPE
> END
> END
> END
> LAYER
> NAME states
> GROUP defaultLayer
> TYPE POLYGON
> DATA state.shp
> STATUS ON
> LABELITEM "ST_NAME"
> CLASSITEM "ST_NAME"
> #MAXSCALE 9000
> CLASS
> COLOR 0 255 100
> OUTLINECOLOR 0 0 0
> SIZE 1
> # SYMBOL 'circle'
> LABEL
> ANGLE AUTO
> ANTIALIAS TRUE
> BUFFER 2
> COLOR 0 0 0
> FONT Arial_Bold
> FORCE TRUE
> # MAXSIZE 256
> # MINDISTANCE 10
> MINFEATURESIZE AUTO
> # MINSIZE 4
> OFFSET 0 0
> PARTIALS TRUE
> POSITION cc
> SIZE 12
> TYPE TRUETYPE
> END
> END
> END
> LAYER
> NAME county
> GROUP defaultLayer
> TYPE POLYGON
> TILEINDEX td_a8.shp
> STATUS ON
> LABELITEM "NAME"
> CLASSITEM "NAME"
> MAXSCALE 200001
> CLASS
> NAME "County Boundary"
> COLOR 245 245 245
> OUTLINECOLOR 255 239 219
> MAXSIZE 50
> MINSIZE 0
> SIZE 1
> SYMBOL 0
> LABEL
> ANGLE AUTO
> ANTIALIAS TRUE
> BUFFER 2
> COLOR 0 0 0
> FONT Arial
> FORCE FALSE
> MAXSIZE 256
> MINDISTANCE 10
> MINFEATURESIZE AUTO
> MINSIZE 4
> OFFSET 0 0
> PARTIALS FALSE
> POSITION cc
> SIZE 12
> TYPE TRUETYPE
> END
> END
> END
> LAYER
> NAME CountyNameAnnotation
> GROUP PlaceName
> TYPE POLYGON
> TILEINDEX td_a8.shp
> STATUS ON
> LABELITEM "NAME"
> CLASSITEM "NAME"
> MAXSCALE 4500000
> MINSCALE 2000000
> CLASS
> NAME "CountyNameAnnotation"
> LABEL
> ANGLE AUTO
> ANTIALIAS TRUE
> BUFFER 2
> COLOR 0 0 0
> FONT Georgia
> FORCE TRUE
> # MINDISTANCE 10
> MINFEATURESIZE 40
> WRAP " "
> MINSIZE 10
> MAXSIZE 256
> OFFSET 0 0
> PARTIALS FALSE
> POSITION CC
> TYPE TRUETYPE
> END
> END
> END
> LAYER
> NAME OrangeCountyAnnotation
> GROUP defaultLayer
> TYPE POLYGON
> DATA usa06059______a8.shp STATUS OFF
> LABELITEM "NAME"
> CLASSITEM "NAME"
> #MAXSCALE 15550000
> #MINSCALE 4000000
> CLASS
> NAME "Orange County Boundary"
> COLOR 255 222 173
> MAXSIZE 50
> MINSIZE 0
> SIZE 1
> SYMBOL 0
> LABEL
> ANGLE AUTO
> ANTIALIAS TRUE
> BUFFER 2
> COLOR 0 0 0
> FONT Georgia
> FORCE TRUE
> # MINDISTANCE 10
> MINFEATURESIZE 10
> MINSIZE 10
> MAXSIZE 256
> OFFSET 0 10
> PARTIALS FALSE
> POSITION CC
> TYPE TRUETYPE
> END
> END
> END
> LAYER
> NAME LA_County
> GROUP defaultLayer
> TYPE POLYGON
> DATA usa06037______a8.shp STATUS ON
> # LABELITEM "NAME"
> CLASSITEM "NAME"
> #MAXSCALE 15550000
> # MINSCALE 100000
> CLASS
> NAME "Los Angeles County Boundary"
> OUTLINECOLOR 0 0 0
> COLOR 225 254 244
> MAXSIZE 50
> MINSIZE 60
> SIZE 1
> SYMBOL 0
> LABEL
> ANGLE AUTO
> ANTIALIAS TRUE
> BUFFER 2
> COLOR 0 0 0
> FONT Georgia
> FORCE TRUE
> # MINDISTANCE 10
> MINFEATURESIZE 25
> MINSIZE 5
> MAXSIZE 256
> OFFSET 6 2
> PARTIALS FALSE
> POSITION CC
> # SIZE 8
> TYPE TRUETYPE
> WRAP " "
> END
> END
> END
> LAYER
> NAME Orange_County
> GROUP defaultLayer
> TYPE POLYGON
> DATA usa06059______a8.shp STATUS ON
> # LABELITEM "NAME"
> CLASSITEM "NAME"
> #MAXSCALE 15550000
> # MINSCALE 100000
> CLASS
> COLOR 255 239 219
> OUTLINECOLOR 0 0 0
> MAXSIZE 50
> MINSIZE 0
> SIZE 1
> SYMBOL 0
> LABEL
> ANGLE AUTO
> ANTIALIAS TRUE
> BUFFER 2
> COLOR 0 0 0
> FONT Georgia
> FORCE TRUE
> # MINDISTANCE 10
> MINFEATURESIZE 20
> MINSIZE 5
> MAXSIZE 256
> OFFSET 0 0
> PARTIALS FALSE
> POSITION CC
> # SIZE 8
> TYPE TRUETYPE
> END
> END
> END
> LAYER
> NAME Riverside_County
> GROUP defaultLayer
> TYPE POLYGON
> DATA usa06065______a8.shp
> STATUS ON
> # LABELITEM "NAME"
> CLASSITEM "NAME"
> #MAXSCALE 15550000
> # MINSCALE 100000
> CLASS
> NAME "Riverside County Boundary"
> COLOR 187 255 255
> OUTLINECOLOR 0 0 0
> MAXSIZE 50
> MINSIZE 0
> SIZE 1
> SYMBOL 0
> LABEL
> ANGLE AUTO
> ANTIALIAS TRUE
> BUFFER 2
> COLOR 0 0 0
> FONT Georgia
> FORCE TRUE
> # MINDISTANCE 10
> MINFEATURESIZE 20
> MINSIZE 5
> MAXSIZE 256
> OFFSET 0 0
> PARTIALS FALSE
> POSITION CC
> # SIZE 8
> TYPE TRUETYPE
> END
> END
> END
> LAYER
> NAME San_Benardino_County
> GROUP defaultLayer
> TYPE POLYGON
> DATA usa06071______a8.shp
> STATUS ON
> # LABELITEM "NAME"
> CLASSITEM "NAME"
> #MAXSCALE 15550000
> # MINSCALE 100000
> CLASS
> NAME "San Bernardino County Boundary"
> COLOR 255 225 255
> OUTLINECOLOR 0 0 0
> MAXSIZE 50
> MINSIZE 0
> SIZE 1
> SYMBOL 0
> LABEL
> ANGLE AUTO
> ANTIALIAS TRUE
> BUFFER 2
> COLOR 0 0 0
> FONT Georgia
> FORCE TRUE
> # MINDISTANCE 10
> MINFEATURESIZE 20
> MINSIZE 5
> MAXSIZE 256
> OFFSET 0 0
> PARTIALS FALSE
> POSITION CC
> # SIZE 8
> TYPE TRUETYPE
> WRAP " "
> END
> END
> END
> LAYER
> NAME Ventura_County
> GROUP defaultLayer
> TYPE POLYGON
> DATA usa06111______a8.shp
> STATUS ON
> # LABELITEM "NAME"
> CLASSITEM "NAME"
> #MAXSCALE 15550000
> # MINSCALE 100000
> CLASS
> NAME "Ventura County Boundary"
> COLOR 255 250 205
> OUTLINECOLOR 0 0 0
> MAXSIZE 50
> MINSIZE 0
> SIZE 1
> SYMBOL 0
> LABEL
> ANGLE AUTO
> ANTIALIAS TRUE
> BUFFER 2
> COLOR 0 0 0
> FONT Georgia
> FORCE TRUE
> # MINDISTANCE 10
> MINFEATURESIZE 20
> MINSIZE 5
> MAXSIZE 256
> OFFSET -1 6
> PARTIALS FALSE
> POSITION CC
> # SIZE AUTO
> TYPE TRUETYPE
> END
> END
> END
> LAYER
> NAME urbanAreas
> GROUP defaultLayer
> TYPE POLYGON
> TILEINDEX td_oa2.shp
> STATUS OFF
> LABELITEM "NAME"
> CLASSITEM "FEATTYP"
> CLASS
> NAME "Urban Area"
> EXPRESSION ( ( [FEATTYP] = 9342 ) )
> COLOR 238 232 205
> OUTLINECOLOR 238 232 205
> MAXSIZE 50
> MINSIZE 0
> SIZE 1
> SYMBOL 0
> LABEL
> ANGLE AUTO
> ANTIALIAS TRUE
> BUFFER 2
> COLOR 0 0 0
> FONT Arial
> FORCE FALSE
> MAXSIZE 256
> MINDISTANCE 10
> MINFEATURESIZE AUTO
> MINSIZE 4
> OFFSET 0 0
> PARTIALS FALSE
> POSITION cc
> SIZE 8
> TYPE TRUETYPE
> END
> END
> END
> LAYER
> NAME landUse
> GROUP defaultLayer
> TYPE POLYGON
> TILEINDEX td_lu.shp
> STATUS ON
> LABELITEM "NAME"
> CLASSITEM "DISPLTYP"
> MAXSCALE 180000
> CLASS
> NAME "Land use"
> COLOR 143 188 143
> OUTLINECOLOR 0 0 0
> MINSIZE 20
> SIZE 1
> SYMBOL 0
> LABEL
> ANGLE AUTO
> ANTIALIAS TRUE
> BUFFER 2
> COLOR 90 90 90
> WRAP " "
> FONT Arial
> FORCE FALSE
> MAXSIZE 256
> MINDISTANCE 10
> MINFEATURESIZE 100
> MINSIZE 4
> OFFSET 0 0
> PARTIALS FALSE
> POSITION cc
> SIZE 8
> TYPE TRUETYPE
> END
> END
> END
> LAYER
> NAME majorWater
> GROUP defaultLayer
> TYPE POLYGON
> TILEINDEX td_wa.shp
> STATUS ON
> LABELITEM "NAME"
> CLASSITEM "DISPCLASS"
> MINSCALE 200000
> # MAXSCALE 1000000
> CLASS
> EXPRESSION ( ( [DISPCLASS] < 3 ) )
> COLOR 30 144 255
> OUTLINECOLOR 30 144 255
> SIZE 1
> SYMBOL 0
> LABEL
> ANGLE AUTO
> ANTIALIAS TRUE
> BUFFER 2
> COLOR 0 0 0
> FONT Arial
> FORCE FALSE
> MAXSIZE 256
> MINDISTANCE 10
> MINFEATURESIZE AUTO
> MINSIZE 4
> OFFSET 0 0
> PARTIALS FALSE
> POSITION cc
> SIZE 8
> TYPE TRUETYPE
> END
> END
> END
> LAYER
> NAME majorWaterIn
> GROUP defaultLayer
> TYPE POLYGON
> TILEINDEX td_wa.shp
> STATUS ON
> LABELITEM "NAME"
> MAXSCALE 200001
> CLASS
> COLOR 30 144 255
> SIZE 1
> SYMBOL 0
> LABEL
> ANGLE AUTO
> ANTIALIAS TRUE
> BUFFER 2
> COLOR 0 0 0
> FONT Arial
> FORCE FALSE
> MAXSIZE 256
> MINDISTANCE 10
> MINFEATURESIZE AUTO
> MINSIZE 4
> OFFSET 0 0
> PARTIALS FALSE
> POSITION cc
> SIZE 8
> TYPE TRUETYPE
> END
> END
> END
> LAYER
> NAME minorWater
> GROUP defaultLayer
> TYPE LINE
> TILEINDEX td_wl.shp
> STATUS ON
> LABELITEM "NAME"
> CLASSITEM "NAME"
> MAXSCALE 200000
> CLASS
> NAME "River"
> COLOR 99 184 255
> OUTLINECOLOR 0 0 0
> MAXSIZE 50
> MINSIZE 0
> SIZE 1
> SYMBOL 0
> LABEL
> ANGLE AUTO
> ANTIALIAS TRUE
> BUFFER 2
> COLOR 0 0 0
> FONT Arial
> FORCE FALSE
> MAXSIZE 256
> MINDISTANCE 10
> MINFEATURESIZE AUTO
> MINSIZE 4
> OFFSET 0 0
> PARTIALS FALSE
> POSITION cc
> SIZE 8
> TYPE TRUETYPE
> END
> END
> END
> LAYER
> NAME pointsOfInterrest
> GROUP defaultLayer
> TYPE POINT
> TILEINDEX td_pi.shp
> #DATA usa06037______pi
> STATUS ON
> LABELITEM "NAME"
> CLASSITEM "FEATTYP"
> MAXSCALE 150000
> CLASS
> # museum
> EXPRESSION ( ( [FEATTYP] = 7317 ) )
> NAME "Museum"
> BACKGROUNDCOLOR 255 255 255
> COLOR 126 126 126
> OUTLINECOLOR 0 0 0
> MAXSIZE 50
> MINSIZE 0
> SIZE 8
> SYMBOL 'circle'
> LABEL
> ANGLE AUTO
> ANTIALIAS TRUE
> BUFFER 2
> COLOR 0 0 0
> WRAP " "
> FONT Arial
> FORCE FALSE
> MAXSIZE 256
> MINDISTANCE 10
> #MINFEATURESIZE AUTO
> MINSIZE 4
> OFFSET 0 0
> PARTIALS FALSE
> POSITION lr
> SIZE 6
> TYPE TRUETYPE
> END
> END
> CLASS
> # shopping center
> EXPRESSION ( ( [FEATTYP] = 7373 ) )
> NAME "Shopping Center"
> COLOR 126 126 126
> OUTLINECOLOR 0 0 0
> MAXSIZE 50
> MINSIZE 0
> SIZE 4
> SYMBOL 'circle'
> LABEL
> ANGLE AUTO
> ANTIALIAS TRUE
> BUFFER 2
> COLOR 0 0 0
> WRAP " "
> FONT Arial
> FORCE FALSE
> MAXSIZE 256
> MINDISTANCE 10
> MINSIZE 4
> OFFSET 0 0
> PARTIALS FALSE
> POSITION lr
> SIZE 6
> TYPE TRUETYPE
> END
> END
> CLASS
> # outdoor stadium
> EXPRESSION ( ( [FEATTYP] = 7374 ) )
> NAME "Stadium"
> COLOR 126 126 126
> OUTLINECOLOR 0 0 0
> MAXSIZE 50
> MINSIZE 0
> SIZE 8
> SYMBOL 'circle'
> LABEL
> ANGLE AUTO
> ANTIALIAS TRUE
> BUFFER 2
> COLOR 0 0 0
> WRAP " "
> FONT Arial
> FORCE FALSE
> MAXSIZE 256
> MINDISTANCE 10
> MINSIZE 4
> OFFSET 0 0
> PARTIALS FALSE
> POSITION lr
> SIZE 6
> TYPE TRUETYPE
> END
> END
> CLASS
> # tourist attractions
> EXPRESSION ( ( [FEATTYP] = 7376 ) )
> NAME "Attraction"
> COLOR 126 0 0
> OUTLINECOLOR 0 0 0
> MAXSIZE 50
> MINSIZE 0
> SIZE 8
> SYMBOL 'circle'
> LABEL
> ANGLE AUTO
> ANTIALIAS TRUE
> BUFFER 2
> COLOR 0 0 0
> WRAP " "
> FONT Arial
> FORCE FALSE
> MAXSIZE 256
> MINDISTANCE 10
> MINSIZE 4
> OFFSET 0 0
> PARTIALS FALSE
> POSITION lr
> SIZE 6
> TYPE TRUETYPE
> END
> END
> CLASS
> # university & college
> EXPRESSION ( ( [FEATTYP] = 7377 ) )
> NAME "University"
> COLOR 126 126 126
> OUTLINECOLOR 0 0 0
> MAXSIZE 50
> MINSIZE 0
> SIZE 8
> SYMBOL 'circle'
> LABEL
> ANGLE AUTO
> ANTIALIAS TRUE
> BUFFER 2
> COLOR 0 0 0
> WRAP " "
> FONT Arial
> FORCE FALSE
> MAXSIZE 256
> MINDISTANCE 10
> MINSIZE 4
> OFFSET 0 0
> PARTIALS FALSE
> POSITION lr
> SIZE 6
> TYPE TRUETYPE
> END
> END
> CLASS
> # railway station
> EXPRESSION ( ( [FEATTYP] = 7380 ) )
> NAME "Rail Station"
> COLOR 126 126 126
> OUTLINECOLOR 0 0 0
> MAXSIZE 50
> MINSIZE 0
> SIZE 8
> SYMBOL 'circle'
> LABEL
> ANGLE AUTO
> ANTIALIAS TRUE
> BUFFER 2
> COLOR 0 0 0
> WRAP " "
> FONT Arial
> FORCE FALSE
> MAXSIZE 256
> MINDISTANCE 10
> MINSIZE 4
> OFFSET 0 0
> PARTIALS FALSE
> POSITION lr
> SIZE 6
> TYPE TRUETYPE
> END
> END
> CLASS
> # airport
> EXPRESSION ( ( [FEATTYP] = 7383 ) )
> NAME "Airport"
> #BACKGROUNDCOLOR 255 255 255
> COLOR 0 0 0
> #MAXSIZE 50
> #MINSIZE 0
> SIZE 25
> SYMBOL 'airportIcon'
> LABEL
> ANGLE AUTO
> ANTIALIAS TRUE
> BUFFER 2
> COLOR 0 0 0
> WRAP " "
> FONT Arial
> FORCE TRUE
> MAXSIZE 256
> MINDISTANCE 10
> MINSIZE 4
> OFFSET 0 0
> PARTIALS FALSE
> POSITION lr
> SIZE 10
> TYPE TRUETYPE
> END
> END
> CLASS
> # conference and exhibition centers
> EXPRESSION ( ( [FEATTYP] = 7385 ) )
> NAME "Conference Center"
> COLOR 126 126 126
> OUTLINECOLOR 0 0 0
> MAXSIZE 50
> MINSIZE 0
> SIZE 8
> SYMBOL 'circle'
> LABEL
> ANGLE AUTO
> ANTIALIAS TRUE
> BUFFER 2
> COLOR 0 0 0
> WRAP " "
> FONT Arial
> FORCE FALSE
> MAXSIZE 256
> MINDISTANCE 10
> MINSIZE 4
> OFFSET 0 0
> PARTIALS FALSE
> POSITION lr
> SIZE 6
> TYPE TRUETYPE
> END
> END
> CLASS
> # rest areas
> EXPRESSION ( ( [FEATTYP] = 7395 ) )
> NAME "Rest Area"
> COLOR 0 126 0
> OUTLINECOLOR 0 0 0
> SIZE 8
> SYMBOL 0
> LABEL
> ANGLE AUTO
> ANTIALIAS TRUE
> BUFFER 2
> COLOR 0 0 0
> WRAP " "
> FONT Arial
> FORCE FALSE
> MAXSIZE 256
> MINDISTANCE 10
> MINSIZE 4
> OFFSET 0 0
> PARTIALS FALSE
> POSITION lr
> SIZE 6
> TYPE TRUETYPE
> END
> END
> CLASS
> # zoo
> EXPRESSION ( ( [FEATTYP] = 9927 ) )
> NAME "Zoo"
> COLOR 126 126 126
> OUTLINECOLOR 0 0 0
> MAXSIZE 50
> MINSIZE 0
> SIZE 8
> SYMBOL 0
> LABEL
> ANGLE AUTO
> ANTIALIAS TRUE
> BUFFER 2
> COLOR 0 0 0
> WRAP " "
> FONT Arial
> FORCE FALSE
> MAXSIZE 256
> MINDISTANCE 10
> MINSIZE 4
> OFFSET 0 0
> PARTIALS FALSE
> POSITION lr
> SIZE 6
> TYPE TRUETYPE
> END
> END
> END
> LAYER
> NAME cityCenterOut
> GROUP defaultLayer
> TYPE POINT
> TILEINDEX td_sm.shp
> STATUS ON
> LABELITEM "NAME"
> MAXSCALE 1500000
> MINSCALE 500001
> CLASS
> EXPRESSION ( ( [DISPCLASS] = 3 ) )
> #NAME "Big City"
> COLOR 0 0 0
> SIZE 9
> SYMBOL 'circleNoFill'
> LABEL
> ANGLE AUTO
> ANTIALIAS TRUE
> BUFFER 2
> COLOR 0 0 0
> OUTLINECOLOR 255 255 255
> WRAP " "
> FONT Arial_Bold
> FORCE TRUE
> MAXSIZE 256
> MINDISTANCE 50
> MINSIZE 4
> OFFSET 0 0
> PARTIALS FALSE
> POSITION lr
> SIZE 9
> TYPE TRUETYPE
> END
> END
> CLASS
> EXPRESSION ( ( [DISPCLASS] = 6 ) )
> #NAME "Medium City"
> COLOR 0 0 0
> SIZE 7
> LABEL
> ANGLE AUTO
> ANTIALIAS TRUE
> BUFFER 2
> COLOR 0 0 0
> WRAP " "
> FONT Arial_Bold
> FORCE TRUE
> MAXSIZE 256
> MINDISTANCE 75
> MINSIZE 4
> OFFSET 0 0
> PARTIALS FALSE
> POSITION lr
> SIZE 7
> TYPE TRUETYPE
> END
> END
> CLASS
> EXPRESSION ( ( [DISPCLASS] = 7 ) )
> #NAME "Small City"
> COLOR 0 0 0
> MAXSIZE 50
> MINSIZE 0
> SIZE 6
> SYMBOL 'circle'
> LABEL
> ANGLE AUTO
> ANTIALIAS TRUE
> BUFFER 2
> COLOR 0 0 0
> WRAP " "
> FONT Arial
> FORCE FALSE
> MAXSIZE 256
> MINDISTANCE 100
> MINSIZE 4
> OFFSET 0 0
> PARTIALS FALSE
> POSITION lr
> SIZE 7
> TYPE TRUETYPE
> END
> END
> CLASS
> EXPRESSION ( ( [DISPCLASS] = 8 ) )
> #NAME "Big Town"
> COLOR 126 126 126
> MAXSIZE 50
> MINSIZE 0
> SIZE 5
> SYMBOL 'circle'
> LABEL
> ANGLE AUTO
> ANTIALIAS TRUE
> BUFFER 1
> COLOR 0 0 0
> WRAP " "
> FONT Arial
> FORCE FALSE
> MAXSIZE 256
> MINDISTANCE 100
> MINSIZE 4
> OFFSET 0 0
> PARTIALS FALSE
> POSITION lr
> SIZE 6
> TYPE TRUETYPE
> END
> END
> END
> LAYER
> NAME cityCenter
> GROUP defaultLayer
> TYPE POINT
> TILEINDEX td_sm.shp
> STATUS ON
> LABELITEM "NAME"
> MAXSCALE 500000
> CLASS
> #NAME "Big City"
> COLOR 0 0 0
> MAXSIZE 50
> MINSIZE 1
> SIZE 9
> LABEL
> ANGLE AUTO
> ANTIALIAS TRUE
> BUFFER 2
> COLOR 0 0 0
> WRAP " "
> FONT Arial_Bold
> FORCE TRUE
> MAXSIZE 256
> MINDISTANCE 75
> MINSIZE 4
> OFFSET 0 0
> PARTIALS FALSE
> POSITION lr
> SIZE 10
> TYPE TRUETYPE
> END
> END
> CLASS
> #NAME "Medium City"
> COLOR 0 0 0
> MAXSIZE 50
> MINSIZE 1
> SIZE 7
> LABEL
> ANGLE AUTO
> ANTIALIAS TRUE
> BUFFER 2
> COLOR 0 0 0
> WRAP " "
> FONT Arial_Bold
> FORCE FALSE
> MAXSIZE 256
> MINDISTANCE 75
> MINSIZE 4
> OFFSET 0 0
> PARTIALS FALSE
> POSITION lr
> SIZE 8
> TYPE TRUETYPE
> END
> END
> CLASS
> #NAME "Small City"
> COLOR 0 0 0
> MAXSIZE 50
> MINSIZE 0
> SIZE 7
> SYMBOL 'circle'
> LABEL
> ANGLE AUTO
> ANTIALIAS TRUE
> BUFFER 2
> COLOR 0 0 0
> WRAP " "
> FONT Arial
> FORCE FALSE
> MAXSIZE 256
> MINDISTANCE 10
> MINSIZE 4
> OFFSET 0 0
> PARTIALS FALSE
> POSITION lr
> SIZE 7
> TYPE TRUETYPE
> END
> END
> CLASS
> #NAME "Big Town"
> COLOR 126 126 126
> MAXSIZE 50
> MINSIZE 0
> SIZE 5
> SYMBOL 'circle'
> LABEL
> ANGLE AUTO
> ANTIALIAS TRUE
> BUFFER 2
> COLOR 0 0 0
> WRAP " "
> FONT Arial
> FORCE FALSE
> MAXSIZE 256
> MINDISTANCE 10
> MINSIZE 4
> OFFSET 0 0
> PARTIALS FALSE
> POSITION lr
> SIZE 6
> TYPE TRUETYPE
> END
> END
> CLASS
> EXPRESSION ( ( [DISPCLASS] = 9 ) )
> #NAME "Medium Town"
> COLOR 126 126 126
> MAXSIZE 50
> MINSIZE 0
> SIZE 4
> SYMBOL 'circle'
> LABEL
> ANGLE AUTO
> ANTIALIAS TRUE
> BUFFER 2
> COLOR 0 0 0
> WRAP " "
> FONT Arial
> FORCE FALSE
> MAXSIZE 256
> MINDISTANCE 10
> MINSIZE 4
> OFFSET 0 0
> PARTIALS FALSE
> POSITION lr
> SIZE 6
> TYPE TRUETYPE
> END
> END
> CLASS
> EXPRESSION ( ( [DISPCLASS] = 10 ) )
> #NAME "Village"
> COLOR 126 126 126
> MAXSIZE 50
> MINSIZE 0
> SIZE 3
> SYMBOL 'circle'
> LABEL
> ANGLE AUTO
> ANTIALIAS TRUE
> BUFFER 2
> COLOR 0 0 0
> WRAP " "
> FONT Arial
> FORCE FALSE
> MAXSIZE 256
> MINDISTANCE 10
> MINSIZE 4
> OFFSET 0 0
> PARTIALS FALSE
> POSITION lr
> SIZE 6
> TYPE TRUETYPE
> END
> END
> CLASS
> EXPRESSION ( ( [DISPCLASS] = 11 ) )
> #NAME "Community"
> COLOR 126 126 126
> MAXSIZE 50
> MINSIZE 0
> SIZE 2
> SYMBOL 'circle'
> LABEL
> ANGLE AUTO
> ANTIALIAS TRUE
> BUFFER 2
> COLOR 0 0 0
> WRAP " "
> FONT Arial
> FORCE FALSE
> MAXSIZE 256
> MINDISTANCE 10
> MINSIZE 4
> OFFSET 0 0
> PARTIALS FALSE
> POSITION lr
> SIZE 6
> TYPE TRUETYPE
> END
> END
> CLASS
> EXPRESSION ( ( [DISPCLASS] = 12 ) )
> #NAME "Small Community"
> COLOR 126 126 126
> MAXSIZE 50
> MINSIZE 0
> SIZE 1
> SYMBOL 'circle'
> LABEL
> ANGLE AUTO
> ANTIALIAS TRUE
> BUFFER 2
> COLOR 0 0 0
> WRAP " "
> FONT Arial
> FORCE FALSE
> MAXSIZE 256
> MINDISTANCE 10
> MINSIZE 4
> OFFSET 0 0
> PARTIALS FALSE
> POSITION lr
> SIZE 6
> TYPE TRUETYPE
> END
> END
> END
> LAYER
> NAME bridges
> GROUP defaultLayer
> TYPE LINE
> TILEINDEX td_ls.shp
> STATUS ON
> LABELITEM "NAME"
> CLASSITEM "STRUCTTYP"
> MAXSCALE 70000
> CLASS
> NAME "Bridge"
> COLOR 126 126 126
> OUTLINECOLOR 0 0 0
> MAXSIZE 50
> MINSIZE 0
> SIZE 1
> SYMBOL 0
> OVERLAYBACKGROUNDCOLOR 255 255 255
> OVERLAYCOLOR 126 126 126
> OVERLAYOUTLINECOLOR 0 0 0
> OVERLAYSIZE 1
> OVERLAYMINSIZE 0
> OVERLAYMAXSIZE 50
> OVERLAYSYMBOL 0
> LABEL
> ANGLE AUTO
> ANTIALIAS TRUE
> BUFFER 2
> COLOR 0 0 0
> FONT Arial
> FORCE FALSE
> MAXSIZE 256
> MINDISTANCE 40
> # MINFEATURESIZE AUTO
> MINSIZE 4
> OFFSET 0 0
> PARTIALS FALSE
> POSITION cc
> SIZE 8
> TYPE TRUETYPE
> END
> END
> END
> LAYER
> NAME ferries
> GROUP defaultLayer
> TYPE LINE
> TILEINDEX td_fe.shp
> STATUS ON
> LABELITEM "NAME"
> CLASSITEM "FRC"
> MAXSCALE 70000
> CLASS
> NAME "Ferry"
> COLOR 126 126 126
> OUTLINECOLOR 0 0 0
> MAXSIZE 50
> MINSIZE 0
> SIZE 1
> SYMBOL 0
> LABEL
> ANGLE AUTO
> ANTIALIAS TRUE
> BUFFER 2
> COLOR 0 0 0
> FONT Arial
> FORCE FALSE
> MAXSIZE 256
> MINDISTANCE 100
> MINFEATURESIZE AUTO
> MINSIZE 4
> OFFSET 0 0
> PARTIALS FALSE
> POSITION uc
> SIZE 8
> TYPE TRUETYPE
> END
> END
> END
> LAYER
> NAME street8
> GROUP defaultLayer
> TYPE LINE
> TILEINDEX td_08.shp
> STATUS OFF
> LABELITEM "NAME"
> CLASSITEM "FRC"
> MAXSCALE 10000
> CLASS
> NAME "Allies & Small Streets"
> COLOR 126 126 126
> MAXSIZE 50
> MINSIZE 0
> SIZE 1
> SYMBOL 0
> LABEL
> ANGLE AUTO
> ANTIALIAS TRUE
> BUFFER 2
> COLOR 0 0 0
> FONT Arial
> FORCE FALSE
> MAXSIZE 256
> MINDISTANCE 100
> MINFEATURESIZE AUTO
> MINSIZE 4
> OFFSET 0 0
> PARTIALS FALSE
> POSITION uc
> SIZE 6
> TYPE TRUETYPE
> END
> END
> END
> LAYER
> NAME street7
> GROUP defaultLayer
> TYPE LINE
> TILEINDEX td_07.shp
> STATUS ON
> LABELITEM "NAME"
> CLASSITEM "FRC"
> MAXSCALE 10000
> CLASS
> NAME "Small Streets"
> COLOR 126 126 126
> MAXSIZE 50
> MINSIZE 0
> SIZE 1
> SYMBOL 0
> LABEL
> ANGLE AUTO
> ANTIALIAS TRUE
> BUFFER 2
> COLOR 0 0 0
> FONT Arial
> FORCE FALSE
> MAXSIZE 256
> MINDISTANCE 100
> MINFEATURESIZE AUTO
> MINSIZE 4
> OFFSET 0 0
> PARTIALS FALSE
> POSITION uc
> SIZE 8
> TYPE TRUETYPE
> END
> END
> END
> LAYER
> NAME street6
> GROUP defaultLayer
> TYPE LINE
> TILEINDEX td_06.shp
> STATUS ON
> LABELITEM "NAME"
> CLASSITEM "FRC"
> MAXSCALE 90000
> CLASS
> NAME "Small surface streets"
> COLOR 126 126 126
> MAXSIZE 50
> MINSIZE 0
> SIZE 1
> SYMBOL 0
> LABEL
> ANGLE AUTO
> ANTIALIAS TRUE
> BUFFER 2
> COLOR 0 0 0
> FONT Arial
> FORCE FALSE
> MAXSIZE 256
> MINDISTANCE 100
> MINFEATURESIZE AUTO
> MINSIZE 4
> OFFSET 0 0
> PARTIALS FALSE
> POSITION uc
> SIZE 8
> TYPE TRUETYPE
> END
> END
> END
> LAYER
> NAME street5
> GROUP defaultLayer
> TYPE LINE
> TILEINDEX td_05.shp
> STATUS ON
> LABELITEM "NAME"
> CLASSITEM "FRC"
> MAXSCALE 100000
> MINSCALE 0.01
> CLASS
> NAME "Streets"
> COLOR 126 126 126
> MAXSIZE 50
> MINSIZE 0
> SIZE 1
> SYMBOL 0
> LABEL
> ANGLE AUTO
> ANTIALIAS TRUE
> BUFFER 2
> COLOR 0 0 0
> FONT Arial
> FORCE FALSE
> MINDISTANCE 100
> MINFEATURESIZE AUTO
> OFFSET 0 0
> PARTIALS FALSE
> POSITION uc
> SIZE 8
> TYPE TRUETYPE
> END
> END
> END
> LAYER
> NAME street4
> GROUP defaultLayer
> TYPE LINE
> TILEINDEX td_04.shp
> STATUS ON
> LABELITEM "NAME"
> CLASSITEM "FRC"
> MAXSCALE 150000
> CLASS
> NAME "Major Streets"
> COLOR 126 126 126
> MAXSIZE 50
> MINSIZE 0
> SIZE 2
> SYMBOL "circle"
> LABEL
> ANGLE AUTO
> ANTIALIAS TRUE
> BUFFER 2
> COLOR 0 0 0
> FONT Arial
> FORCE FALSE
> MAXSIZE 256
> MINDISTANCE 100
> MINFEATURESIZE AUTO
> MINSIZE 4
> OFFSET 0 0
> PARTIALS FALSE
> POSITION uc
> SIZE 8
> TYPE TRUETYPE
> END
> END
> END
> LAYER
> NAME street3
> GROUP defaultLayer
> TYPE LINE
> TILEINDEX td_03.shp
> STATUS ON
> LABELITEM "NAME"
> CLASSITEM "FRC"
> MAXSCALE 2000000
> CLASS
> NAME "Highways"
> COLOR 88 88 88
> SIZE 2
> SYMBOL 'circle'
> LABEL
> ANGLE AUTO
> ANTIALIAS TRUE
> BUFFER 2
> COLOR 0 0 0
> FONT Arial
> FORCE FALSE
> MAXSIZE 256
> MINDISTANCE 100
> MINFEATURESIZE AUTO
> MINSIZE 4
> OFFSET 0 0
> PARTIALS FALSE
> POSITION uc
> SIZE 8
> TYPE TRUETYPE
> END
> END
> END
> LAYER
> NAME street1
> GROUP defaultLayer
> TYPE LINE TILEINDEX td_01.shp
> #DATA usa06037______01
> STATUS ON
> #LABELITEM "NAME"
> #MAXSCALE 15550000.0
> #MINSCALE 0.00001
> CLASS
> NAME "US Highways" BACKGROUNDCOLOR 255 255 255
> COLOR 105 105 105
> SIZE 3
> SYMBOL 'circle'
> LABEL
> ANGLE AUTO
> ANTIALIAS TRUE
> BUFFER 2
> COLOR 0 0 0
> FONT Arial
> FORCE FALSE
> #MINDISTANCE 5
> MINFEATURESIZE AUTO
> OFFSET 0 0
> PARTIALS FALSE
> POSITION lr
> SIZE 8
> TYPE TRUETYPE
> END
> END
> END
> LAYER
> NAME street1
> GROUP defaultLayer
> STATUS ON
> #LABELITEM "NAME"
> #MINSCALE 0.00001
> CLASS
> COLOR 188 188 188
> SIZE 1
> SYMBOL 'circle'
> END
> END
> LAYER
> NAME street0
> GROUP defaultLayer
> TYPE LINE
> TILEINDEX td_00.shp
> STATUS ON
> #LABELITEM "NAME"
> #MAXSCALE 15550000
> #MINSCALE 0.001
> CLASS
> NAME "Interstates"
> COLOR 61 61 61
> SIZE 3
> SYMBOL 'circle'
> END
> END
> LAYER
> NAME street0
> GROUP defaultLayer
> TYPE LINE
> TILEINDEX td_00.shp
> STATUS ON
> LABELITEM "NAME"
> #MAXSCALE 15550000
> #MINSCALE 0.001
> CLASS
> COLOR 188 188 188
> SIZE 1
> SYMBOL 'circle'
> END END
> LAYER
> NAME street01_annotation
> GROUP defaultLayer
> STATUS ON
> TILEINDEX td_01.shp
> TYPE ANNOTATION
> LABELITEM "ROUTENUM"
> CLASSITEM "NAME"
> MAXSCALE 4500000
> #CLASS
> # EXPRESSION /.*\/.*/
> # END
> CLASS
> EXPRESSION /HWY.*/
> COLOR 0 0 0
> SYMBOL 'symbols/sthwy.png' LABEL
> COLOR 0 0 0
> WRAP "/"
> #MINFEATURESIZE 40
> MINDISTANCE 300
> POSITION cc
> PARTIALS FALSE
> SIZE tiny
> END
> END
> CLASS
> EXPRESSION /US.*/
> COLOR 0 0 0
> SYMBOL 'symbols/ushwy.png' LABEL
> COLOR 0 0 0
> WRAP "/"
> #MINFEATURESIZE 40
> MINDISTANCE 300
> POSITION cc
> PARTIALS FALSE
> SIZE tiny
> END
> END
> CLASS
> EXPRESSION /I.*/
> COLOR 0 0 0
> SYMBOL 'symbols/interstate.png' LABEL
> COLOR 255 255 255
> WRAP "/"
> #MINFEATURESIZE 40
> MINDISTANCE 300
> POSITION cc
> PARTIALS FALSE
> SIZE tiny
> END
> END
> END
> LAYER
> NAME street00_annotation
> GROUP defaultLayer
> STATUS ON
> TILEINDEX td_00.shp
> TYPE ANNOTATION
> CLASSITEM "NAME"
> MAXSCALE 4500000
> CLASS
> COLOR 200 0 0
> COLOR 255 255 255
> WRAP "/"
> #MINFEATURESIZE 40
> MINDISTANCE 200
> POSITION cc
> PARTIALS FALSE
> SIZE TINY
> END
> END
> END
> # LAYER
> # NAME county
> # GROUP defaultLayer
> # TYPE POLYGON
> # TILEINDEX td_a8.shp
> # STATUS ON
> # LABELITEM "NAME"
> # CLASSITEM "NAME"
> # MAXSCALE 40000
> # CLASS
> # NAME "County Boundary"
> # COLOR 245 245 245
> # OUTLINECOLOR 97 97 97
> # MAXSIZE 50
> # MINSIZE 0
> # SIZE 1
> # # SYMBOL 'circle'
> # LABEL
> # ANGLE AUTO
> # ANTIALIAS TRUE
> # BUFFER 2
> # COLOR 0 0 0
> # FONT Arial
> # FORCE FALSE
> # MAXSIZE 256
> # MINDISTANCE 10
> # MINSIZE 4
> # OFFSET 0 0
> # PARTIALS FALSE
> # POSITION AUTO
> # SIZE 12
> # TYPE TRUETYPE
> # END
> # END
> # END
> # LAYER
> # NAME urbanAreas
> # TYPE POLYGON
> # TILEINDEX td_oa2.shp
> # STATUS ON
> # LABELITEM "NAME"
> # CLASSITEM "FEATTYP"
> # MAXSCALE 5000
> # CLASS
> # NAME "Urban Area"
> # EXPRESSION ( ( [FEATTYP] = 9342 ) )
> # COLOR 238 232 205
> # OUTLINECOLOR 250 235 215
> # MAXSIZE 50
> # MINSIZE 0
> # SIZE 1
> # # SYMBOL 'circle'
> # LABEL
> # ANGLE AUTO
> # ANTIALIAS TRUE
> # BUFFER 2
> # COLOR 0 0 0
> # FONT Arial
> # FORCE FALSE
> # MAXSIZE 256
> # MINDISTANCE 10
> # MINSIZE 4
> # OFFSET 0 0
> # PARTIALS FALSE
> # POSITION AUTO
> # SIZE 8
> # TYPE TRUETYPE
> # END
> # END
> # END
> # LAYER
> # NAME landUse
> # TYPE POLYGON
> # #DATA usa06037______lu.shp
> # TILEINDEX td_lu.shp
> # STATUS ON
> # LABELITEM "NAME"
> # CLASSITEM "DISPLTYP"
> # MAXSCALE 40000
> # CLASS
> # NAME "Land use"
> # COLOR 143 188 143
> # OUTLINECOLOR 0 0 0
> # MINSIZE 20
> # SIZE 1
> # # SYMBOL 'circle'
> # LABEL
> # ANGLE AUTO
> # ANTIALIAS TRUE
> # BUFFER 2
> # COLOR 90 90 90
> # WRAP " "
> # FONT Arial
> # FORCE TRUE
> # MAXSIZE 256
> # MINDISTANCE 10
> # MINFEATURESIZE 100
> # MINSIZE 4
> # OFFSET 0 0
> # PARTIALS TRUE
> # POSITION AUTO
> # SIZE 8
> # TYPE TRUETYPE
> # END
> # END
> # END
> # LAYER
> # NAME majorWater
> # TYPE POLYGON
> # TILEINDEX td_wa.shp
> # STATUS ON
> # LABELITEM "NAME"
> # CLASSITEM "NAME"
> # MAXSCALE 40000
> # CLASS
> # COLOR 30 144 255
> # OUTLINECOLOR 30 144 255
> # SIZE 1
> # # SYMBOL 'circle'
> # LABEL
> # ANGLE AUTO
> # ANTIALIAS TRUE
> # BUFFER 2
> # COLOR 96 96 96
> # WRAP " "
> # FONT Arial
> # FORCE FALSE
> # MAXSIZE 256
> # MINDISTANCE 10
> # MINSIZE 4
> # OFFSET 0 0
> # PARTIALS FALSE
> # POSITION AUTO
> # SIZE 10
> # TYPE TRUETYPE
> # END
> # END
> # END
> # LAYER
> # NAME minorWater
> # TYPE LINE
> # TILEINDEX td_wl.shp
> # STATUS ON
> # LABELITEM "NAME"
> # CLASSITEM "NAME"
> # MAXSCALE 40000
> # CLASS
> # NAME "River"
> # COLOR 99 184 255
> # MAXSIZE 50
> # MINSIZE 0
> # SIZE 3
> # SYMBOL 'circle'
> # LABEL
> # ANGLE AUTO
> # ANTIALIAS TRUE
> # BUFFER 2
> # COLOR 0 0 0
> # FONT Arial
> # FORCE TRUE
> # MAXSIZE 256
> # MINDISTANCE 100
> # MINSIZE 4
> # OFFSET 0 0
> # PARTIALS FALSE
> # POSITION AUTO
> # SIZE 8
> # TYPE TRUETYPE
> # END
> # END
> # END
> # LAYER
> # NAME bridges
> # TYPE LINE
> # TILEINDEX td_ls.shp
> # STATUS ON # blah
> # LABELITEM "NAME"
> # CLASSITEM "STRUCTTYP"
> # MAXSCALE 70000
> # CLASS
> # NAME "Bridge"
> # COLOR 126 126 126
> # MAXSIZE 50
> # MINSIZE 0
> # SIZE 1
> # SYMBOL "circle"
> # OVERLAYBACKGROUNDCOLOR 255 255 255
> # OVERLAYCOLOR 126 126 126
> # OVERLAYOUTLINECOLOR 0 0 0
> # OVERLAYSIZE 1
> # OVERLAYMINSIZE 0
> # OVERLAYMAXSIZE 50
> # OVERLAYSYMBOL 0
> # LABEL
> # ANGLE AUTO
> # ANTIALIAS TRUE
> # BUFFER 2
> # COLOR 0 0 0
> # FONT Arial
> # FORCE FALSE
> # MAXSIZE 256
> # MINDISTANCE 10
> # MINSIZE 4
> # OFFSET 0 0
> # PARTIALS FALSE
> # POSITION AUTO
> # SIZE 8
> # TYPE TRUETYPE
> # END
> # END
> # END
> # LAYER
> # NAME ferries
> # TYPE LINE
> # TILEINDEX td_fe.shp
> # STATUS ON # blah
> # LABELITEM "NAME"
> # CLASSITEM "FRC"
> # MAXSCALE 70000
> # CLASS
> # NAME "Ferry"
> # BACKGROUNDCOLOR 255 255 255
> # COLOR 126 126 126
> # MAXSIZE 50
> # MINSIZE 0
> # SIZE 1
> # SYMBOL 'circle'
> # OVERLAYSIZE 1
> # OVERLAYMINSIZE 0
> # OVERLAYMAXSIZE 50
> # OVERLAYSYMBOL 0
> # LABEL
> # ANGLE AUTO
> # ANTIALIAS TRUE
> # BUFFER 2
> # COLOR 0 0 0
> # FONT Arial
> # FORCE FALSE
> # MAXSIZE 256
> # MINDISTANCE 10
> # MINSIZE 4
> # OFFSET 0 0
> # PARTIALS FALSE
> # POSITION AUTO
> # SIZE 8
> # TYPE TRUETYPE
> # END
> # END
> # END
> # # LAYER
> # NAME street8
> # TYPE LINE
> # TILEINDEX td_08.shp
> # STATUS ON # blah
> # LABELITEM "NAME"
> # CLASSITEM "FRC"
> # MAXSCALE 10000
> # CLASS
> # NAME "Alleys & Small Streets"
> # COLOR 126 126 126
> # MAXSIZE 50
> # MINSIZE 0
> # SIZE 1
> # SYMBOL 'circle'
> # OVERLAYSIZE 1
> # OVERLAYMINSIZE 0
> # OVERLAYMAXSIZE 50
> # OVERLAYSYMBOL 0
> # LABEL
> # ANGLE AUTO
> # ANTIALIAS TRUE
> # BUFFER 2
> # COLOR 0 0 0
> # FONT Arial
> # FORCE FALSE
> # MAXSIZE 256
> # MINDISTANCE 10
> # MINSIZE 4
> # OFFSET 0 0
> # PARTIALS FALSE
> # POSITION AUTO
> # SIZE 6
> # TYPE TRUETYPE
> # END
> # END
> # END
> # LAYER
> # NAME street7
> # TYPE LINE
> # TILEINDEX td_07.shp
> # STATUS ON # blah
> # LABELITEM "NAME"
> # CLASSITEM "FRC"
> # MAXSCALE 10000
> # CLASS
> # NAME "Small Streets"
> # COLOR 126 126 126
> # MAXSIZE 50
> # MINSIZE 0
> # SIZE 1
> # SYMBOL 'circle'
> # OVERLAYSIZE 1
> # OVERLAYMINSIZE 0
> # OVERLAYMAXSIZE 50
> # OVERLAYSYMBOL 0
> # LABEL
> # ANGLE AUTO
> # ANTIALIAS TRUE
> # BUFFER 2
> # COLOR 0 0 0
> # FONT Arial
> # FORCE FALSE
> # MAXSIZE 256
> # MINDISTANCE 10
> # MINSIZE 4
> # OFFSET 0 0
> # PARTIALS FALSE
> # POSITION AUTO
> # SIZE 8
> # TYPE TRUETYPE
> # END
> # END
> # END
> # LAYER
> # NAME street6
> # TYPE LINE
> # TILEINDEX td_06.shp
> # STATUS ON # blah
> # LABELITEM "NAME"
> # CLASSITEM "FRC"
> # MAXSCALE 40000
> # CLASS
> # NAME "Small surface streets"
> # COLOR 126 126 126
> # MAXSIZE 50
> # MINSIZE 0
> # SIZE 1
> # SYMBOL 'circle'
> # OVERLAYSIZE 1
> # OVERLAYMINSIZE 0
> # OVERLAYMAXSIZE 50
> # OVERLAYSYMBOL 0
> # LABEL
> # ANGLE AUTO
> # ANTIALIAS TRUE
> # BUFFER 2
> # COLOR 0 0 0
> # FONT Arial
> # FORCE FALSE
> # MAXSIZE 256
> # MINDISTANCE 10
> # MINSIZE 4
> # OFFSET 0 0
> # PARTIALS FALSE
> # POSITION AUTO
> # SIZE 8
> # TYPE TRUETYPE
> # END
> # END
> # END
> # LAYER
> # NAME street5
> # TYPE LINE
> # TILEINDEX td_05.shp
> # STATUS ON # blah
> # LABELITEM "NAME"
> # CLASSITEM "FRC"
> # MAXSCALE 40000
> # CLASS
> # NAME "Streets"
> # COLOR 126 126 126
> # MAXSIZE 50
> # MINSIZE 0
> # SIZE 1
> # SYMBOL 'circle'
> # OVERLAYSIZE 1
> # OVERLAYMINSIZE 0
> # OVERLAYMAXSIZE 50
> # OVERLAYSYMBOL 0
> # LABEL
> # ANGLE AUTO
> # ANTIALIAS TRUE
> # BUFFER 2
> # COLOR 0 0 0
> # FONT Arial
> # FORCE FALSE
> # MAXSIZE 256
> # MINDISTANCE 10
> # MINSIZE 4
> # OFFSET 0 0
> # PARTIALS FALSE
> # POSITION AUTO
> # SIZE 8
> # TYPE TRUETYPE
> # END
> # END
> # END
> # LAYER
> # NAME street4
> # TYPE LINE
> # TILEINDEX td_04.shp
> # STATUS ON # blah
> # LABELITEM "NAME"
> # CLASSITEM "FRC"
> # MAXSCALE 90000
> # CLASS
> # NAME "Major Streets"
> # COLOR 126 126 126
> # MAXSIZE 50
> # MINSIZE 0
> # SIZE 1
> # SYMBOL 'circle'
> # OVERLAYSIZE 1
> # OVERLAYMINSIZE 0
> # OVERLAYMAXSIZE 50
> # OVERLAYSYMBOL 0
> # LABEL
> # ANGLE AUTO
> # ANTIALIAS TRUE
> # BUFFER 2
> # COLOR 0 0 0
> # FONT Arial
> # FORCE FALSE
> # MAXSIZE 256
> # MINDISTANCE 10
> # MINSIZE 4
> # OFFSET 0 0
> # PARTIALS FALSE
> # POSITION AUTO
> # SIZE 8
> # TYPE TRUETYPE
> # END
> # END
> # END
> # LAYER
> # NAME street3
> # TYPE LINE
> # TILEINDEX td_03.shp
> # STATUS ON # blah
> # LABELITEM "NAME"
> # CLASSITEM "FRC"
> # MAXSCALE 2000000
> # CLASS
> # NAME "Highways"
> # COLOR 88 88 88
> # SIZE 2
> # SYMBOL 'circle'
> # LABEL
> # ANGLE AUTO
> # ANTIALIAS TRUE
> # BUFFER 2
> # COLOR 0 0 0
> # OUTLINECOLOR 255 255 255
> # FONT Arial
> # FORCE FALSE
> # MAXSIZE 256
> # MINDISTANCE 100
> # MINSIZE 4
> # OFFSET 0 0
> # PARTIALS FALSE
> # POSITION uc
> # SIZE 8
> # TYPE TRUETYPE
> # END
> # END
> # END
> # LAYER
> # NAME street1
> # TYPE LINE # TILEINDEX td_01.shp
> # #DATA usa06037______01
> # STATUS ON # blah
> # #MAXSCALE 40000
> # # CLASS
> # NAME "US Highways" # BACKGROUNDCOLOR 255 255 255
> # COLOR 105 105 105
> # SIZE 3
> # SYMBOL 'circle'
> # LABEL
> # ANGLE AUTO
> # ANTIALIAS TRUE
> # BUFFER 2
> # COLOR 0 0 0
> # FONT Arial
> # FORCE FALSE
> # #MINDISTANCE 5
> # OFFSET 0 0
> # PARTIALS FALSE
> # POSITION uc
> # SIZE 8
> # TYPE TRUETYPE
> # END
> # END
> # END
> # LAYER
> # NAME street1
> # STATUS ON # blah
> # #LABELITEM "NAME"
> # #MAXSCALE 15550000.0
> # #MINSCALE 0.00001
> # # CLASS
> # COLOR 188 188 188
> # SIZE 1
> # SYMBOL 'circle'
> # END
> # END
> # LAYER
> # NAME street0
> # TYPE LINE
> # TILEINDEX td_00.shp
> # STATUS ON # blah
> # #MAXSCALE 40000
> # CLASS
> # NAME "Interstates"
> # COLOR 61 61 61
> # SIZE 3
> # SYMBOL 'circle'
> # END
> # END
> # LAYER
> # NAME street0
> # TYPE LINE
> # STATUS ON # blah
> # CLASS
> # COLOR 188 188 188
> # SIZE 1
> # SYMBOL 'circle'
> # END # END
> # LAYER
> # NAME street01_annotation
> # STATUS ON # blah
> # TYPE ANNOTATION
> # LABELITEM "ROUTENUM"
> # CLASSITEM "NAME"
> # #MAXSCALE 40000
> # CLASS
> # EXPRESSION /HWY.*/
> # COLOR 0 0 0
> # SYMBOL 'symbols/sthwy.png' # LABEL
> # COLOR 0 0 0
> # WRAP "/"
> # #MINFEATURESIZE 40
> # MINDISTANCE 200
> # POSITION CC
> # PARTIALS false
> # SIZE tiny
> # END
> # END
> # CLASS
> # EXPRESSION /US.*/
> # COLOR 0 0 0
> # SYMBOL 'symbols/ushwy.png' # LABEL
> # COLOR 0 0 0
> # WRAP "/"
> # MINDISTANCE 200
> # POSITION CC
> # PARTIALS false
> # SIZE tiny
> # END
> # END
> # CLASS
> # EXPRESSION /I.*/
> # COLOR 0 0 0
> # SYMBOL 'symbols/interstate.png' # LABEL
> # COLOR 255 255 255
> # WRAP "/"
> # MINDISTANCE 200
> # POSITION CC
> # PARTIALS false
> # SIZE tiny
> # END
> # END
> # END
> # LAYER
> # NAME street00_annotation
> # STATUS ON # blah
> # TYPE ANNOTATION
> # MAXSCALE 4500000
> # CLASS
> # COLOR 200 0 0
> # COLOR 255 255 255
> # WRAP "/"
> # MINDISTANCE 200
> # POSITION CC
> # PARTIALS false
> # SIZE TINY
> # END
> # END
> # END
> # LAYER
> # NAME pointsOfInterest
> # TYPE POINT
> # TILEINDEX td_pi.shp
> # STATUS ON
> # LABELITEM "NAME"
> # MAXSCALE 40000
> # CLASS
> # # museum
> # EXPRESSION ( ( [FEATTYP] = 7317 ) )
> # NAME "Museum"
> # COLOR 126 126 126
> # MAXSIZE 50
> # MINSIZE 0
> # SIZE 8
> # SYMBOL 'circle'
> # LABEL
> # WRAP " "
> # ANGLE AUTO
> # ANTIALIAS TRUE
> # BUFFER 2
> # COLOR 0 0 0
> # WRAP " "
> # FONT Arial
> # FORCE FALSE
> # MAXSIZE 256
> # MINDISTANCE 10
> # MINSIZE 4
> # OFFSET 0 0
> # PARTIALS FALSE
> # POSITION AUTO
> # SIZE 7
> # TYPE TRUETYPE
> # END
> # END
> # # CLASS
> # # shopping center
> # EXPRESSION ( ( [FEATTYP] = 7373 ) )
> # NAME "Shopping Center"
> # COLOR 126 126 126
> # MAXSIZE 50
> # MINSIZE 0
> # SIZE 8
> # SYMBOL 'circle'
> # LABEL
> # WRAP " "
> # ANGLE AUTO
> # ANTIALIAS TRUE
> # BUFFER 2
> # COLOR 0 0 0
> # FONT Arial
> # FORCE FALSE
> # MAXSIZE 256
> # MINDISTANCE 10
> # MINSIZE 4
> # OFFSET 0 0
> # PARTIALS FALSE
> # POSITION AUTO
> # SIZE 6
> # TYPE TRUETYPE
> # END
> # END
> # # CLASS
> # # outdoor stadium
> # EXPRESSION ( ( [FEATTYP] == 7374 ) )
> # NAME "Stadium"
> # COLOR 126 126 126
> # MAXSIZE 50
> # MINSIZE 0
> # SIZE 8
> # SYMBOL 'circle'
> # LABEL
> # WRAP " "
> # ANGLE AUTO
> # ANTIALIAS TRUE
> # BUFFER 2
> # COLOR 0 0 0
> # FONT Arial
> # FORCE FALSE
> # MAXSIZE 256
> # MINDISTANCE 10
> # MINSIZE 4
> # OFFSET 0 0
> # PARTIALS TRUE
> # POSITION AUTO
> # SIZE 7
> # TYPE TRUETYPE
> # END
> # END
> # CLASS
> # # tourist attractions
> # EXPRESSION ( ( [FEATTYP] == 7376 ) )
> # NAME "Attraction"
> # COLOR 126 0 0
> # MAXSIZE 50
> # MINSIZE 0
> # SIZE 8
> # SYMBOL 'circle'
> # LABEL
> # WRAP " "
> # ANGLE AUTO
> # ANTIALIAS TRUE
> # BUFFER 2
> # COLOR 0 0 0
> # FONT Arial
> # FORCE FALSE
> # MAXSIZE 256
> # MINDISTANCE 10
> # MINSIZE 4
> # OFFSET 0 0
> # PARTIALS TRUE
> # POSITION AUTO
> # SIZE 7
> # TYPE TRUETYPE
> # END
> # END
> # # CLASS
> # # university & college
> # EXPRESSION ( ( [FEATTYP] == 7377 ) )
> # NAME "University"
> # COLOR 126 126 255
> # OUTLINECOLOR 255 0 0
> # MAXSIZE 50
> # MINSIZE 0
> # SIZE 8
> # SYMBOL 'circle'
> # LABEL
> # ANGLE AUTO
> # WRAP " "
> # ANTIALIAS TRUE
> # BUFFER 2
> # COLOR 0 0 0
> # FONT Arial
> # FORCE FALSE
> # MAXSIZE 256
> # MINDISTANCE 10
> # MINSIZE 4
> # OFFSET 0 0
> # PARTIALS TRUE
> # POSITION AUTO
> # SIZE 7
> # TYPE TRUETYPE
> # END
> # END
> # CLASS
> # # railway station
> # EXPRESSION ( ( [FEATTYP] == 7380 ) )
> # NAME "Rail Station"
> # COLOR 255 255 255
> # SIZE 40
> # SYMBOL 'transBack'
> # OVERLAYSYMBOL 'railIcon'
> # OVERLAYCOLOR 0 0 170
> # OVERLAYSIZE 40
> # LABEL
> # WRAP " "
> # ANGLE AUTO
> # ANTIALIAS TRUE
> # BUFFER 2
> # COLOR 0 0 0
> # FONT Arial_Bold
> # FORCE FALSE
> # MAXSIZE 256
> # MINDISTANCE 10
> # MINSIZE 4
> # OFFSET 0 0
> # PARTIALS FALSE
> # POSITION AUTO
> # SIZE 6
> # TYPE TRUETYPE
> # END
> # END
> # # CLASS
> # # airport
> # EXPRESSION ( ( [FEATTYP] == 7383 ) )
> # NAME "Airport"
> # COLOR 0 0 0
> # MAXSIZE 50
> # MINSIZE 0
> # SIZE 25
> # SYMBOL 'airportIcon'
> # LABEL
> # ANGLE AUTO
> # WRAP " "
> # ANTIALIAS TRUE
> # BUFFER 2
> # COLOR 0 0 0
> # FONT Arial_Bold
> # FORCE FALSE
> # MAXSIZE 256
> # MINDISTANCE 10
> # MINSIZE 4
> # OFFSET 0 0
> # PARTIALS TRUE
> # POSITION AUTO
> # SIZE 7
> # TYPE TRUETYPE
> # END
> # END
> # CLASS
> # # conference and exhibition centers
> # EXPRESSION ( ( [FEATTYP] == 7385 ) )
> # NAME "Conference Center"
> # COLOR 126 126 126
> # MAXSIZE 50
> # MINSIZE 0
> # SIZE 8
> # SYMBOL 'circle'
> # LABEL
> # WRAP " "
> # ANGLE AUTO
> # ANTIALIAS TRUE
> # BUFFER 2
> # COLOR 0 0 0
> # FONT Arial
> # FORCE FALSE
> # MAXSIZE 256
> # MINDISTANCE 10
> # MINSIZE 4
> # OFFSET 0 0
> # PARTIALS TRUE
> # POSITION AUTO
> # SIZE 7
> # TYPE TRUETYPE
> # END
> # END
> # CLASS
> # # rest areas
> # EXPRESSION ( ( [FEATTYP] = 7395 ) )
> # NAME "Rest Area"
> # COLOR 255 255 255
> # MAXSIZE 50
> # MINSIZE 0
> # SIZE 30
> # OVERLAYSIZE 30
> # OVERLAYCOLOR 0 0 180
> # OVERLAYSYMBOL 'restAreaIcon'
> # TEXT "Rest Area"
> # LABEL
> # WRAP " "
> # ANGLE AUTO
> # ANTIALIAS TRUE
> # BUFFER 2
> # COLOR 0 0 0
> # FONT Arial
> # FORCE FALSE
> # MAXSIZE 256
> # MINDISTANCE 10
> # MINSIZE 4
> # OFFSET 0 0
> # PARTIALS TRUE
> # POSITION lr
> # SIZE 12
> # TYPE TRUETYPE
> # END
> # END
> # CLASS
> # # zoo
> # EXPRESSION ( ( [FEATTYP] == 9927 ) )
> # NAME "Zoo"
> # COLOR 126 126 126
> # MAXSIZE 50
> # MINSIZE 0
> # SIZE 8
> # SYMBOL 'circle'
> # LABEL
> # WRAP " "
> # ANGLE AUTO
> # ANTIALIAS TRUE
> # BUFFER 2
> # COLOR 0 0 0
> # FONT Arial
> # FORCE FALSE
> # MAXSIZE 256
> # MINDISTANCE 10
> # MINSIZE 4
> # OFFSET 0 0
> # PARTIALS TRUE
> # POSITION AUTO
> # SIZE 7
> # TYPE TRUETYPE
> # END
> # END
> # END
> # LAYER
> # NAME cityCenter
> # TYPE POINT
> # TILEINDEX td_sm.shp
> # STATUS ON
> # LABELITEM "NAME"
> # CLASSITEM "DISPCLASS"
> # MAXSCALE 40000
> # CLASS
> # EXPRESSION ( ( [DISPCLASS] = 3 ) )
> # #NAME "Big City"
> # COLOR 126 126 126
> # MAXSIZE 50
> # MINSIZE 1
> # SIZE 10
> # SYMBOL 'circle'
> # LABEL
> # ANGLE AUTO
> # ANTIALIAS TRUE
> # BUFFER 2
> # COLOR 0 0 0
> # WRAP " "
> # FONT Arial_Bold
> # FORCE TRUE
> # MAXSIZE 256
> # MINDISTANCE 10
> # MINSIZE 4
> # OFFSET 2 2
> # PARTIALS TRUE
> # POSITION AUTO
> # SIZE 14
> # TYPE TRUETYPE
> # END
> # END
> # CLASS
> # EXPRESSION ( ( [DISPCLASS] = 6 ) )
> # #NAME "Medium City"
> # COLOR 126 126 126
> # MAXSIZE 50
> # MINSIZE 1
> # SIZE 7
> # SYMBOL 'circleNoFill'
> # LABEL
> # ANGLE AUTO
> # ANTIALIAS TRUE
> # BUFFER 2
> # COLOR 0 0 0
> # WRAP " "
> # FONT Arial_Bold
> # FORCE TRUE
> # MAXSIZE 256
> # MINDISTANCE 10
> # MINSIZE 4
> # OFFSET 0 0
> # PARTIALS TRUE
> # POSITION AUTO
> # SIZE 11
> # TYPE TRUETYPE
> # END
> # END
> # CLASS
> # EXPRESSION ( ( [DISPCLASS] = 7 ) )
> # #NAME "Small City"
> # COLOR 126 126 126
> # MAXSIZE 50
> # MINSIZE 0
> # SIZE 1
> # SYMBOL 'circle'
> # LABEL
> # ANGLE AUTO
> # ANTIALIAS TRUE
> # BUFFER 2
> # COLOR 0 0 0
> # WRAP " "
> # FONT Arial
> # FORCE FALSE
> # MAXSIZE 256
> # MINDISTANCE 10
> # MINSIZE 4
> # OFFSET 0 0
> # PARTIALS TRUE
> # POSITION AUTO
> # SIZE 10
> # TYPE TRUETYPE
> # END
> # END
> # CLASS
> # EXPRESSION ( ( [DISPCLASS] = 8 ) )
> # #NAME "Big Town"
> # COLOR 126 126 126
> # MAXSIZE 50
> # MINSIZE 0
> # SIZE 1
> # SYMBOL 'circle'
> # LABEL
> # ANGLE AUTO
> # ANTIALIAS TRUE
> # BUFFER 2
> # COLOR 0 0 0
> # WRAP " "
> # FONT Arial_Bold
> # FORCE TRUE
> # MAXSIZE 256
> # MINDISTANCE 10
> # MINSIZE 4
> # OFFSET 0 0
> # PARTIALS TRUE
> # POSITION AUTO
> # FORCE FALSE
> # MAXSIZE 256
> # MINDISTANCE 10
> # MINSIZE 4
> # OFFSET 0 0
> # PARTIALS TRUE
> # POSITION AUTO
> # SIZE 8
> # TYPE TRUETYPE
> # END
> # END
> # CLASS
> # EXPRESSION ( ( [DISPCLASS] = 9 ) )
> # #NAME "Medium Town"
> # COLOR 126 126 126
> # MAXSIZE 50
> # MINSIZE 0
> # SIZE 1
> # SYMBOL 'circle'
> # LABEL
> # ANGLE AUTO
> # ANTIALIAS TRUE
> # BUFFER 2
> # COLOR 0 0 0
> # WRAP " "
> # FONT Arial
> # FORCE FALSE
> # MAXSIZE 256
> # MINDISTANCE 10
> # MINSIZE 4
> # OFFSET 0 0
> # PARTIALS TRUE
> # POSITION AUTO
> # SIZE 8
> # TYPE TRUETYPE
> # END
> # END
> # CLASS
> # EXPRESSION ( ( [DISPCLASS] = 10 ) )
> # #NAME "Village"
> # COLOR 126 126 126
> # MAXSIZE 50
> # MINSIZE 0
> # SIZE 3
> # SYMBOL 'circle'
> # LABEL
> # ANGLE AUTO
> # ANTIALIAS TRUE
> # BUFFER 2
> # COLOR 0 0 0
> # WRAP " "
> # FONT Arial
> # FORCE FALSE
> # MAXSIZE 256
> # MINDISTANCE 10
> # MINSIZE 4
> # OFFSET 0 0
> # PARTIALS TRUE
> # POSITION AUTO
> # SIZE 8
> # TYPE TRUETYPE
> # END
> # END
> # CLASS
> # EXPRESSION ( ( [DISPCLASS] = 11 ) )
> # #NAME "Community"
> # COLOR 126 126 126
> # MAXSIZE 50
> # MINSIZE 0
> # SIZE 2
> # SYMBOL 'circle'
> # LABEL
> # ANGLE AUTO
> # ANTIALIAS TRUE
> # BUFFER 2
> # COLOR 0 0 0
> # WRAP " "
> # FONT Arial
> # FORCE FALSE
> # MAXSIZE 256
> # MINDISTANCE 10
> # MINSIZE 4
> # OFFSET 0 0
> # PARTIALS TRUE
> # POSITION AUTO
> # SIZE 8
> # TYPE TRUETYPE
> # END
> # END
> # CLASS
> # EXPRESSION ( ( [DISPCLASS] = "12" ) )
> # #NAME "Small Community"
> # COLOR 126 126 126
> # MAXSIZE 50
> # MINSIZE 0
> # SIZE 1
> # SYMBOL 'circle'
> # LABEL
> # ANGLE AUTO
> # ANTIALIAS TRUE
> # BUFFER 2
> # COLOR 0 0 0
> # WRAP " "
> # FONT Arial
> # FORCE FALSE
> # MAXSIZE 256
> # MINDISTANCE 10
> # MINSIZE 4
> # OFFSET 0 0
> # PARTIALS TRUE
> # POSITION AUTO
> # SIZE 8
> # TYPE TRUETYPE
> # END
> # END
> # # END
> LAYER
> NAME MSensors1
> TYPE POINT
> STATUS ON
> TILEINDEX sensors/means.shp
> CLASSITEM LEVEL
> LABELITEM LEVEL
> MAXSCALE 30000
> CLASS
> NAME 'fast'
> EXPRESSION ( ( [SPEED] > 55 ) AND ( [LEVEL] == 1 ) )
> OUTLINECOLOR 0 255 0
> SIZE 11
> OVERLAYSYMBOL 'circleNoFill'
> OVERLAYOUTLINECOLOR 0 255 0
> OVERLAYSIZE 8
> TEXT ( [LEVEL]/[ID]/[SPEED] )
> LABEL
> BUFFER 2
> ANGLE AUTO
> ANTIALIAS TRUE
> COLOR 50 50 50
> FONT Arial
> POSITION AUTO
> SIZE 20
> TYPE TRUETYPE
> END
> END
> CLASS
> NAME 'medium'
> EXPRESSION ( ( [SPEED] >= 35 ) AND ( [SPEED] <= 55 ) AND (
> [LEVEL] == 1 ) )
> OUTLINECOLOR 255 255 0
> SIZE 11
> OVERLAYOUTLINECOLOR 255 255 0
> OVERLAYSIZE 8
> END
> CLASS
> NAME 'mediumslow'
> EXPRESSION ( ( [SPEED] >= 20 ) AND ( [SPEED] <= 35 ) AND (
> [LEVEL] == 1 ) )
> OUTLINECOLOR 255 128 0
> SIZE 11
> OVERLAYOUTLINECOLOR 255 128 0
> OVERLAYSIZE 8
> END
> CLASS
> NAME 'slow'
> EXPRESSION ( ( [SPEED] < 20 ) AND ( [SPEED] > 0 ) AND (
> [LEVEL] == 1 ) )
> SIZE 11
> OVERLAYOUTLINECOLOR 255 0 0
> OVERLAYSIZE 8
> END
> END
> LAYER
> NAME MSensors2
> TYPE POINT
> STATUS ON
> CLASSITEM LEVEL
> MINSCALE 30001
> MAXSCALE 200000
> CLASS
> NAME 'fast'
> EXPRESSION ( ( [SPEED] > 55 ) AND ( [LEVEL] == 2 ) )
> SIZE 9
> OVERLAYSIZE 7
> END
> CLASS
> NAME 'medium'
> [LEVEL] == 2 ) )
> SIZE 9
> OVERLAYSIZE 7
> END
> CLASS
> NAME 'mediumslow'
> [LEVEL] == 2 ) )
> SIZE 9
> OVERLAYSIZE 7
> END
> CLASS
> NAME 'slow'
> [LEVEL] == 2 ) )
> SIZE 9
> OVERLAYSIZE 7
> END
> END
> LAYER
> NAME MSensors3
> TYPE POINT
> STATUS ON
> CLASSITEM LEVEL
> MINSCALE 200001
> MAXSCALE 1000000
> CLASS
> NAME 'fast'
> EXPRESSION ( ( [SPEED] > 55 ) AND ( [LEVEL] == 3 ) )
> SIZE 5
> OVERLAYSIZE 4
> END
> CLASS
> NAME 'medium'
> [LEVEL] == 3 ) )
> SIZE 5
> OVERLAYSIZE 4
> END
> CLASS
> NAME 'mediumslow'
> [LEVEL] == 3 ) )
> SIZE 5
> OVERLAYSIZE 4
> END
> CLASS
> NAME 'slow'
> [LEVEL] == 3 ) )
> SIZE 5
> OVERLAYSIZE 4
> END
> END
> LAYER
> NAME MSensors4
> TYPE POINT
> STATUS ON
> CLASSITEM LEVEL
> MINSCALE 1000001
> CLASS
> NAME 'fast'
> COLOR 0 255 0
> SIZE 3
> END
> CLASS
> NAME 'medium'
> [LEVEL] == 3 ) )
> COLOR 255 255 0
> SIZE 3
> END
> CLASS
> NAME 'mediumslow'
> [LEVEL] == 3 ) )
> COLOR 255 128 0
> SIZE 3
> END
> CLASS
> NAME 'slow'
> [LEVEL] == 3 ) )
> COLOR 255 0 0
> SIZE 3
> END
> END
> LAYER
> NAME Sensors1
> TYPE POINT
> STATUS ON
> TILEINDEX CurrentSensorData.shp
> MAXSCALE 30000
> CLASS
> NAME 'fast'
> COLOR 0 255 0
> OUTLINECOLOR 140 140 140
> SYMBOL 'circle'
> SIZE 11
> END
> CLASS
> NAME 'medium'
> [LEVEL] == 1 ) )
> COLOR 255 255 0
> SYMBOL 'circle'
> SIZE 11
> END
> CLASS
> NAME 'mediumslow'
> [LEVEL] == 1 ) )
> COLOR 255 128 0
> SYMBOL 'circle'
> SIZE 11
> END
> CLASS
> NAME 'slow'
> [LEVEL] == 1 ) )
> COLOR 255 0 0
> SYMBOL 'circle'
> SIZE 11
> END
> END
> LAYER
> NAME Sensors2
> TYPE POINT
> STATUS ON
> MINSCALE 30001
> MAXSCALE 200000
> CLASS
> NAME 'fast'
> COLOR 0 255 0
> SYMBOL 'circle'
> SIZE 9
> END
> CLASS
> NAME 'medium'
> [LEVEL] == 2 ) )
> COLOR 255 255 0
> SYMBOL 'circle'
> SIZE 9
> END
> CLASS
> NAME 'mediumslow'
> [LEVEL] == 2 ) )
> COLOR 255 128 0
> SYMBOL 'circle'
> SIZE 9
> END
> CLASS
> NAME 'slow'
> [LEVEL] == 2 ) )
> COLOR 255 0 0
> SYMBOL 'circle'
> SIZE 9
> END
> END
> LAYER
> NAME Sensors3
> TYPE POINT
> STATUS ON
> MINSCALE 200001
> MAXSCALE 1000000
> CLASS
> NAME 'fast'
> COLOR 0 255 0
> #OUTLINECOLOR 140 140 140
> SYMBOL 'circle'
> SIZE 5
> END
> CLASS
> NAME 'medium'
> [LEVEL] == 3 ) )
> COLOR 255 255 0
> SYMBOL 'circle'
> SIZE 5
> END
> CLASS
> NAME 'mediumslow'
> [LEVEL] == 3 ) )
> COLOR 255 128 0
> SYMBOL 'circle'
> SIZE 5
> END
> CLASS
> NAME 'slow'
> [LEVEL] == 3 ) )
> COLOR 255 0 0
> SYMBOL 'circle'
> SIZE 5
> END
> END
> LAYER
> NAME Sensors4
> TYPE POINT
> STATUS ON
> MINSCALE 1000001
> CLASS
> NAME 'fast'
> COLOR 0 255 0
> SYMBOL 'circle'
> SIZE 3
> END
> CLASS
> NAME 'medium'
> [LEVEL] == 3 ) )
> COLOR 255 255 0
> SYMBOL 'circle'
> SIZE 3
> END
> CLASS
> NAME 'mediumslow'
> [LEVEL] == 3 ) )
> COLOR 255 128 0
> SYMBOL 'circle'
> SIZE 3
> END
> CLASS
> NAME 'slow'
> [LEVEL] == 3 ) )
> COLOR 255 0 0
> SYMBOL 'circle'
> SIZE 3
> END
> END
> LAYER
> NAME SensorPoint
> TYPE POINT
> STATUS ON
> CLASS
> NAME 'Slow'
> COLOR 255 0 0
> OUTLINECOLOR 0 0 0
> SYMBOL 'circle'
> SIZE 6
> LABEL
> BUFFER 2
> ANGLE AUTO
> ANTIALIAS TRUE
> COLOR 0 0 0
> FONT Arial
> POSITION AUTO
> SIZE 8
> TYPE TRUETYPE
> END
> END
> CLASS
> NAME 'Medium'
> COLOR 255 255 0
> OUTLINECOLOR 0 0 0
> SYMBOL 'circle'
> SIZE 6
> LABEL
> BUFFER 2
> ANGLE AUTO
> ANTIALIAS TRUE
> COLOR 0 0 0
> FONT Arial
> POSITION AUTO
> SIZE 8
> TYPE TRUETYPE
> END
> END
> CLASS
> NAME 'Fast'
> COLOR 0 255 0
> OUTLINECOLOR 0 0 0
> SYMBOL 'circle'
> SIZE 6
> LABEL
> BUFFER 2
> ANGLE AUTO
> ANTIALIAS TRUE
> COLOR 0 0 0
> FONT Arial
> POSITION AUTO
> SIZE 8
> TYPE TRUETYPE
> END
> END
> CLASS
> NAME 'Start'
> COLOR 0 255 0
> SYMBOL 'star'
> SIZE 15
> LABEL
> ANGLE AUTO
> ANTIALIAS TRUE
> COLOR 0 255 0
> FONT Arial
> POSITION AUTO
> SIZE 8
> TYPE TRUETYPE
> END
> END
> CLASS
> NAME 'Finish'
> COLOR 255 0 0
> SYMBOL 'star'
> SIZE 15
> LABEL
> ANGLE AUTO
> ANTIALIAS TRUE
> COLOR 255 0 0
> FONT Arial
> POSITION AUTO
> SIZE 8
> TYPE TRUETYPE
> END
> END
> CLASS
> NAME 'Unknown'
> COLOR 128 128 128
> OUTLINECOLOR 0 0 0
> SYMBOL 'circle'
> SIZE 6
> LABEL
> ANGLE AUTO
> ANTIALIAS TRUE
> COLOR 128 128 128
> FONT Arial
> POSITION AUTO
> SIZE 8
> TYPE TRUETYPE
> END
> END
> CLASS
> NAME 'UserStart'
> #COLOR 0 255 0
> SYMBOL 'star'
> SIZE 12
> LABEL
> ANGLE AUTO
> ANTIALIAS TRUE
> COLOR 0 255 0
> FONT Arial
> POSITION AUTO
> SIZE 8
> TYPE TRUETYPE
> END
> END
> CLASS
> NAME 'UserFinish'
> #COLOR 255 0 0
> SYMBOL 'star'
> SIZE 12
> LABEL
> ANGLE AUTO
> ANTIALIAS TRUE
> COLOR 255 0 0
> FONT Arial
> POSITION AUTO
> SIZE 8
> TYPE TRUETYPE
> END
> END
> END
> LAYER
> NAME Incident
> TYPE POINT
> STATUS ON
> DATA incidents.shp
> MAXSCALE 2000000
> CLASS
> # test
> NAME "Test"
> COLOR 0 0 0
> MAXSIZE 50
> MINSIZE 0
> # SIZE 19
> # SYMBOL 'event'
> SYMBOL 'symbols/incident.png'
> # OVERLAYSYMBOL 'triangle'
> # OVERLAYCOLOR 255 255 0
> # OVERLAYSIZE 14
> # TEXT "!"
> LABEL
> WRAP " "
> ANGLE AUTO
> ANTIALIAS TRUE
> BUFFER 2
> COLOR 255 0 0
> FONT Arial_Bold
> FORCE TRUE
> MAXSIZE 256
> MINDISTANCE 30
> MINSIZE 4
> OFFSET 0 0
> PARTIALS TRUE
> POSITION cc
> SIZE 11
> TYPE TRUETYPE
> END
> END
> END
> LAYER
> NAME Labelling
> TYPE POLYGON
> STATUS ON
> TRANSFORM FALSE
> LABELCACHE FALSE
> CLASS
> NAME 'gray'
> SIZE 1
> COLOR 220 220 220
> LABEL
> ANTIALIAS TRUE
> COLOR 0 0 0
> TYPE TRUETYPE
> FONT Arial
> SIZE 7
> POSITION cc
> END
> END
> CLASS
> NAME 'red'
> SIZE 1
> COLOR 230 230 230
> LABEL
> ANTIALIAS TRUE
> COLOR 200 0 0
> TYPE TRUETYPE
> FONT Arial
> SIZE 7
> POSITION cc
> END
> END
> CLASS
> NAME 'blue'
> SIZE 1
> COLOR 230 230 230
> LABEL
> ANTIALIAS TRUE
> COLOR 0 0 200
> TYPE TRUETYPE
> FONT Arial
> SIZE 7
> POSITION cc
> END
> END
> FEATURE
> END
> END
> LAYER
> NAME RouteLine
> TYPE LINE
> STATUS ON
> FEATURE
> END
> CLASS
> NAME 'Path'
> COLOR 204 153 255
> OUTLINECOLOR 0 0 0
> SYMBOL 'circle'
> SIZE 15
> OVERLAYSYMBOL 'pointer'
> OVERLAYCOLOR 155 0 155
> OVERLAYSIZE 20
> END
> END
> # Start of web interface definition (including WMS enabling metadata)
> # ignored as near as I can tell for what we are doing.
> WEB
> HEADER route_header.html
> TEMPLATE route.html
> FOOTER route_footer.html
> MINSCALE 0.001
> MAXSCALE 15550000
> LOG "/tmp/log.txt"
> METADATA
> WMS_TITLE "TrafficDodger Demo"
> WMS_ABSTRACT "This is the TrafficDodger Demo application for Los
> Angeles Metro."
> WMS_ACCESSCONSTRAINTS none
> # change this value to match your setup
> WMS_ONLINERESOURCE "http://extempore.otsys.com/~dodger/mapsite/"
> WMS_SRS "EPSG:26915"
> END
> END
> END # Map File
> Cordially,
> Joe Bussell
> On Time Systems
