perl mapscript crash "Can't locate
auto/mapscript/classObj/swig_size_s.al"
Lowell Filak
lfilak at MEDINACO.ORG
Fri Jun 10 09:44:34 EDT 2005
The following message was sent by Joseph Bussell <joe at OTSYS.COM> on Wed,
8 Jun 2005 13:57:09 -0700.
> I have a mapfile that when viewed at certain zoom levels, generates a
> failure. The Apache log indicates that a specific object cannot be
> found. I explicitly turned off all the layers, intending to add them
> one at a time until I observed a failure, but the failure still existed
> for scales 2000001 and higher. I do not understand why some Perl module
> is differentially available based on my scale. Back in the days when
> TrafficDodger was an active application this was working. I updated the
> mapscript to the latest stable rev and had to make a few changes (like
> my extents were improperly ordered). Lower scales work nicely. I have
> other maps that show the whole planet, these render nicely. Does anyone
> have any ideas?
> I am using perl mapscript from version mapserver-4.4.2,
> ( set up with ./configure --with-proj --with-gdal --with-gd
> --with-perl --with-php=../mapserverDeps/php-5.0.2/ )
> Linux 2.6.10-1.771_FC2 #1 built Mon Mar 28 00:50:14 EST 2005 i686 athlon
> i386 GNU/Linux
> Server version: Apache/1.3.31 (Unix)
> I offer the error string:
> Can't locate auto/mapscript/classObj/swig_size_s.al in @INC (@INC
> contains: /usr/traffic2/perl
> /usr/lib/perl5/5.8.3/i386-linux-thread-multi /usr/lib/perl5/5.8.3
> /usr/lib/perl5/site_perl/5.8.3/i386-linux-thread-multi
> /usr/lib/perl5/site_perl/5.8.2/i386-linux-thread-multi
> /usr/lib/perl5/site_perl/5.8.1/i386-linux-thread-multi
> /usr/lib/perl5/site_perl/5.8.0/i386-linux-thread-multi
> /usr/lib/perl5/site_perl/5.8.3 /usr/lib/perl5/site_perl/5.8.2
> /usr/lib/perl5/site_perl/5.8.1 /usr/lib/perl5/site_perl/5.8.0
> /usr/lib/perl5/vendor_perl/5.8.3/i386-linux-thread-multi
> /usr/lib/perl5/vendor_perl/5.8.2/i386-linux-thread-multi
> /usr/lib/perl5/vendor_perl/5.8.1/i386-linux-thread-multi
> /usr/lib/perl5/vendor_perl/5.8.0/i386-linux-thread-multi
> /usr/lib/perl5/vendor_perl/5.8.3 /usr/lib/perl5/vendor_perl/5.8.2
> /usr/lib/perl5/vendor_perl/5.8.1 /usr/lib/perl5/vendor_perl/5.8.0
> /usr/lib/perl5/vendor_perl /usr/local/apache/
> /usr/local/apache/lib/perl) at
> /usr/lib/perl5/site_perl/5.8.3/i386-linux-thread-multi/mapscript.pm line
> 35\n
> Cordially,
> Joe Bussell
> On Time Systems
Joe,
Can you include a snip of the code?
I've seen this type of error occur a lot when the code has a typo, where
I inadvertently call a member or method that doesn't exist.
Lowell
