Raster/Oracle Spatial Layer Problems.
Owens, Ryan J NWD02 CONTRACTOR
Ryan.J.Owens at NWO02.USACE.ARMY.MIL
Fri Jun 10 14:13:25 EDT 2005
Hi Fernando,
Thanks for responding.
We are running version 4.4.2. And, we are using CGI. My code is below, with
the metadata commented out. Not sure what you mean by how I defined my
layers - I defined my raster as raster (duh), and I defined my Oracle Spatial
layer as a point layer. Does this help to pin point a problem?
Ryan
MAP
NAME TNS_
EXTENT -535681 116823 1337533 1458918
WEB
log "./test.log"
TEMPLATE "test_template.html"
IMAGEPATH "./tmp/"
IMAGEURL "http://[domain]////"
END
DEBUG ON
OUTPUTFORMAT
NAME swf
DRIVER "SWF"
MIMETYPE "application/x-shockwave-flash"
EXTENSION "swf"
IMAGEMODE PC256
FORMATOPTION "OUTPUT_MOVIE=MULTIPLE"
END
IMAGETYPE swf
SIZE 460 500
SHAPEPATH "data"
SYMBOLSET symbols/symbol_mrric.sym
IMAGECOLOR 255 255 255
FONTSET fonts/fonts.list
PROJECTION
# "proj=laea"
# "ellps=clrk66"
# "lat_0=45"
# "lon_0=-100"
# Alternatively, you can specify an EPSG code.
"init=epsg:80000"
END
# Start of LAYER DEFINITIONS ---------------------------------------------
LAYER
NAME "basin"
STATUS DEFAULT
TYPE RASTER
# PROJECTION
# END
END
LAYER
NAME "river"
DATA missouri_river
STATUS DEFAULT
TYPE LINE
METADATA
"SWFDUMPATTRIBUTES" "NAME,LENGTH"
END
PROJECTION
"init=epsg:80000"
END
CLASS
COLOR 0 0 254
END
END
LAYER
NAME boatramps
CONNECTIONTYPE oraclespatial
CONNECTION [COMMENTED OUT]
DATA "ORA_GEOMETRY FROM (select c.ora_geometry, c.ramp_name, c.ramp_type,
c.bottom_ele, m.project from boatramps_011305_geo c, moriver_project_extents2
m where sdo_anyinteract(c.ora_geometry, m.ora_geometry)='TRUE') using SRID
8265"
FILTER 'BOTTOM_ELE IS NOT NULL'
PROJECTION
"proj=latlong"
"ellps=GRS80"
"init=epsg:4269"
END
TYPE point
STATUS DEFAULT
# METADATA
# "DESCRIPTION""RAMPS"
# "RESULT_FIELDS" "RAMP_NAME"
# "SWFDUMPATTRIBUTES" "RAMP_NAME,RAMP_TYPE,BOTTOM_ELE,PROJECT"
# END
LABELMAXSCALE 1500000
LABELITEM "RAMP_NAME"
CLASSITEM "RAMP_TYPE"
CLASS
NAME "Boat Ramps - Shut Down"
EXPRESSION ([BOTTOM_ELE]>=5000)
SYMBOL 'rectangle'
COLOR 160 60 60
SIZE 5
OVERLAYSYMBOL 'rectangle'
OVERLAYCOLOR 252 214 165 # 128 128 0
OVERLAYSIZE 3
LABEL
ANTIALIAS true
TYPE truetype
FONT "tahoma"
COLOR 180 80 0
SIZE 7
POSITION uc
END
END
CLASS
NAME "Boat Ramps - Operational"
EXPRESSION ([BOTTOM_ELE]<5000)
SYMBOL 'rectangle'
COLOR 60 160 60
SIZE 5
OVERLAYSIZE 3
LABEL
ANTIALIAS true
TYPE truetype
FONT "tahoma"
COLOR 80 180 0
SIZE 7
POSITION uc
END
END
END
End of LAYER DEFINITIONS ---------------------------------------------
END # end of map file/object
-----Original Message-----
Sent: Friday, June 10, 2005 1:01 PM
To: Owens, Ryan J NWD02 CONTRACTOR
Cc: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: Re: [UMN_MAPSERVER-USERS] Raster/Oracle Spatial Layer Problems.
What version are you using? Some problems can occur in 4.4.0 version, I
recommend to use the last version (4.6 or 4.4.2).
How did you defined your layers (Raster and Oracle)? Are you using CGI
or MapScript?
Thanks.
Fernando Simon
Mapserver and Oracle Spatial developer
G10 - Laboratorio de Computacao Aplicada - Brazil
http://g10.cttmar.univali.br - UNIVALI/CTTMAR
Owens, Ryan J NWD02 CONTRACTOR wrote:
> Hello List,
> I'm having difficulty implementing a specific combination of a raster
> and Oracle Spatial data layer.
> I have two layers: one raster layer and one oracle spatial point
> layer. Both layers function properly, except for some projection
> issues that I will fix later. When I go to add METADATA attributes to
> the oracle spatial layer, I get an "internal server error". When I
> comment out the raster layer, the oracle spatial layer functions
> properly with the metadata. When I comment out the oracle spatial
> layer along with the metadata, the raster layer functions properly.
> But they do not work together. Does anyone have any idea what is
> happening?
> Ryan
