Raster/Oracle Spatial Layer Problems.
Fernando Simon
fsimon at UNIVALI.BR
Fri Jun 10 15:26:42 EDT 2005
The problem can be with filter option. Sometimes I had problems with
filter and query functions, can you define your filter option inside of
DATA parameter?
Another hint, can try to define the UNIQUE paramater for your DATA?
Like: (I already defined the "filter" inside the data)
DATA "ORA_GEOMETRY FROM (select c.ora_geometry, c.ramp_name,
c.ramp_type, c.bottom_ele, m.project from boatramps_011305_geo c,
moriver_project_extents2 m where sdo_anyinteract(c.ora_geometry,
m.ora_geometry)='TRUE' and c.bottom_ele is not null) using UNIQUE
<unique_id> SRID 8265"
The <unique_id> is the column (number) that store the unique
identifier for your table (usually the primary key).
Can you test these hints?
Thanks.
Fernando Simon
Mapserver and Oracle Spatial developer
G10 - Laboratorio de Computacao Aplicada - Brazil
http://g10.cttmar.univali.br - UNIVALI/CTTMAR
Owens, Ryan J NWD02 CONTRACTOR wrote:
>Hi Fernando,
>Thanks for responding.
>We are running version 4.4.2. And, we are using CGI. My code is below, with
>the metadata commented out. Not sure what you mean by how I defined my
>layers - I defined my raster as raster (duh), and I defined my Oracle Spatial
>layer as a point layer. Does this help to pin point a problem?
>Ryan
>MAP
> NAME TNS_
> EXTENT -535681 116823 1337533 1458918
> WEB
> log "./test.log"
> TEMPLATE "test_template.html"
> IMAGEPATH "./tmp/"
> IMAGEURL "http://[domain]////"
> END
> DEBUG ON
> OUTPUTFORMAT
> NAME swf
> DRIVER "SWF"
> MIMETYPE "application/x-shockwave-flash"
> EXTENSION "swf"
> IMAGEMODE PC256
> FORMATOPTION "OUTPUT_MOVIE=MULTIPLE"
> END
> IMAGETYPE swf
> SIZE 460 500
> SHAPEPATH "data"
> SYMBOLSET symbols/symbol_mrric.sym
> IMAGECOLOR 255 255 255
> FONTSET fonts/fonts.list
> PROJECTION
># "proj=laea"
># "ellps=clrk66"
># "lat_0=45"
># "lon_0=-100"
> # Alternatively, you can specify an EPSG code.
> "init=epsg:80000"
> END
># Start of LAYER DEFINITIONS ---------------------------------------------
> LAYER
> NAME "basin"
> STATUS DEFAULT
> TYPE RASTER
> # PROJECTION
> # END
> END
> LAYER
> NAME "river"
> DATA missouri_river
> STATUS DEFAULT
> TYPE LINE
> METADATA
> "SWFDUMPATTRIBUTES" "NAME,LENGTH"
> END
> PROJECTION
> "init=epsg:80000"
> END
> CLASS
> COLOR 0 0 254
> END
> END
> LAYER
> NAME boatramps
> CONNECTIONTYPE oraclespatial
> CONNECTION [COMMENTED OUT]
> DATA "ORA_GEOMETRY FROM (select c.ora_geometry, c.ramp_name, c.ramp_type,
>c.bottom_ele, m.project from boatramps_011305_geo c, moriver_project_extents2
>m where sdo_anyinteract(c.ora_geometry, m.ora_geometry)='TRUE') using SRID
>8265"
> FILTER 'BOTTOM_ELE IS NOT NULL'
> PROJECTION
> "proj=latlong"
> "ellps=GRS80"
> "init=epsg:4269"
> END
> TYPE point
> STATUS DEFAULT
># METADATA
># "DESCRIPTION""RAMPS"
># "RESULT_FIELDS" "RAMP_NAME"
># "SWFDUMPATTRIBUTES" "RAMP_NAME,RAMP_TYPE,BOTTOM_ELE,PROJECT"
># END
> LABELMAXSCALE 1500000
> LABELITEM "RAMP_NAME"
> CLASSITEM "RAMP_TYPE"
> CLASS
> NAME "Boat Ramps - Shut Down"
> EXPRESSION ([BOTTOM_ELE]>=5000)
> SYMBOL 'rectangle'
> COLOR 160 60 60
> SIZE 5
> OVERLAYSYMBOL 'rectangle'
> OVERLAYCOLOR 252 214 165 # 128 128 0
> OVERLAYSIZE 3
> LABEL
> ANTIALIAS true
> TYPE truetype
> FONT "tahoma"
> COLOR 180 80 0
> SIZE 7
> POSITION uc
> END
> END
> CLASS
> NAME "Boat Ramps - Operational"
> EXPRESSION ([BOTTOM_ELE]<5000)
> SYMBOL 'rectangle'
> COLOR 60 160 60
> SIZE 5
> OVERLAYSIZE 3
> LABEL
> ANTIALIAS true
> TYPE truetype
> FONT "tahoma"
> COLOR 80 180 0
> SIZE 7
> POSITION uc
> END
> END
> END
>End of LAYER DEFINITIONS ---------------------------------------------
>END # end of map file/object
>-----Original Message-----
>From: Fernando Simon [mailto:fsimon at univali.br]
>Sent: Friday, June 10, 2005 1:01 PM
>To: Owens, Ryan J NWD02 CONTRACTOR
>Cc: MAPSERVER-USERS at LISTS.UMN.EDU
>Subject: Re: [UMN_MAPSERVER-USERS] Raster/Oracle Spatial Layer Problems.
>Hi,
>What version are you using? Some problems can occur in 4.4.0 version, I
>recommend to use the last version (4.6 or 4.4.2).
>How did you defined your layers (Raster and Oracle)? Are you using CGI
>or MapScript?
>Thanks.
>Fernando Simon
>>Hello List,
>>I'm having difficulty implementing a specific combination of a raster
>>and Oracle Spatial data layer.
>>I have two layers: one raster layer and one oracle spatial point
>>layer. Both layers function properly, except for some projection
>>issues that I will fix later. When I go to add METADATA attributes to
>>the oracle spatial layer, I get an "internal server error". When I
>>comment out the raster layer, the oracle spatial layer functions
>>properly with the metadata. When I comment out the oracle spatial
>>layer along with the metadata, the raster layer functions properly.
>>But they do not work together. Does anyone have any idea what is
>>happening?
>>Ryan
