wind barbs
Nate Reed
nate at SEASTAR.JPL.NASA.GOV
Fri Jun 10 18:08:00 EDT 2005
I got the barb character to display by making the following changes:
- Changed "SIZE LARGE" to "SIZE 25"
- Changed "ã" to "ã" (was missing the semicolon)
Thanks,
Nate
On Fri, 10 Jun 2005, Nate Reed wrote:
> Hello,
> I'm hoping I can get some pointers on drawing windbarbs in PHP Mapscript
> from this list.
> Currently, I'm able to draw a point on my map by using some code
> that I found on the list archive and various other places on the net.
> However, the character does not appear to be correct (I've attached the
> map - it's that small black speck at -120,30).
> I have downloaded the ESRIWeather font and added it to my fontlist, and
> aliased it with 'weather'.
> The layer definition looks like this:
> LAYER
> NAME tt_symbol
> STATUS ON
> TYPE POINT
> CLASS
> NAME "0"
> STYLE
> END
> LABEL
> FORCE TRUE
> TYPE TRUETYPE
> FONT weather
> SIZE large
> ANTIALIAS true
> OUTLINECOLOR 0 0 0
> COLOR 0 0 0
> POSITION UC
> ANGLE 0
> BUFFER 0
> PARTIALS TRUE
> END
> END
> END
> The code looks like this:
> $this->image = $this->map->draw();
> $layer = $this->map->getLayerByName('tt_symbol');
> $point = ms_newPointObj();
> $point->setXY(-120,30);
> $point->draw($this->map,$layer,$this->image,0,"ã");
> $this->map->drawLabelCache($this->image);
> I could use some help to improve the output. One curious thing is if I
> remove the Style object from the Map file the character does not appear at
> all. This suggests that perhaps something else is required in the layer
> or style objects?
> Thanks,
> Nate
Nate Reed
Physical Oceanography DAAC
Jet Propulsion Lab / Raytheon ITSS
(626)744-5528 nate at seastar.jpl.nasa.gov
