more wind barbs problems
    Nate Reed
    nate at SEASTAR.JPL.NASA.GOV
    Fri Jun 10 15:29:35 PDT 2005
How do I set the angle of the wind barb character?
I tried
$class = $layer->getClass(0);
$class->label->angle = 45;
$point->draw($this->map,$layer,$this->image,0,'ã');
$this->map->drawLabelCache($this->image);
The angle is unchanged.
Nate
On Fri, 10 Jun 2005, Nate Reed wrote:
> I got the barb character to display by making the following changes:
> - Changed "SIZE LARGE" to "SIZE 25"
> - Changed "ã" to "ã" (was missing the semicolon)
> Thanks,
> Nate
> > Hello,
> > I'm hoping I can get some pointers on drawing windbarbs in PHP Mapscript
> > from this list.
> > Currently, I'm able to draw a point on my map by using some code
> > that I found on the list archive and various other places on the net.
> > However, the character does not appear to be correct (I've attached the
> > map - it's that small black speck at -120,30).
> > I have downloaded the ESRIWeather font and added it to my fontlist, and
> > aliased it with 'weather'.
> > The layer definition looks like this:
> >   LAYER
> >     NAME tt_symbol
> >     STATUS ON
> >     TYPE POINT
> >     CLASS
> >       NAME "0"
> >       STYLE
> >       END
> >       LABEL
> >         FORCE TRUE
> > 	TYPE TRUETYPE
> > 	FONT weather
> > 	SIZE large
> > 	ANTIALIAS true
> > 	OUTLINECOLOR 0 0 0
> > 	COLOR 0 0 0
> > 	POSITION UC
> > 	ANGLE 0
> > 	BUFFER 0
> > 	PARTIALS TRUE
> >       END
> >     END
> >   END
> > The code looks like this:
> >     $this->image = $this->map->draw();
> >     $layer = $this->map->getLayerByName('tt_symbol');
> >     $point = ms_newPointObj();
> >     $point->setXY(-120,30);
> >     $point->draw($this->map,$layer,$this->image,0,"ã");
> > I could use some help to improve the output.  One curious thing is if I
> > remove the Style object from the Map file the character does not appear at
> > all.  This suggests that perhaps something else is required in the layer
> > or style objects?
> > Thanks,
> > Nate
Nate Reed
Physical Oceanography DAAC
Jet Propulsion Lab / Raytheon ITSS
(626)744-5528  nate at seastar.jpl.nasa.gov
More information about the MapServer-users
