queryByPoint
Bart van den Eijnden
BEN at SYNCERA-ITSOLUTIONS.NL
Mon Jun 13 07:53:34 PDT 2005
Do you have a TEMPLATE set on your LAYER, and do you have a TOLERANCE defined? Also look at TOLERANCEUNITS.
Second question, there is code for this in Chameleon, pasted below.
* convert a pixel position to a georef position
* @param nPixPos integer the pixel position
* @param dfPixMin float the minimum pixel position
* @param dfPixMax float the maximum pixel position
* @param dfGeoMin float the minimum georeferenced position
* @param dfGeoMax float the maximum georeferenced position
* @param nInversePix boolean, flag to invert Y coordinates if UL > LR
* @return double geocoded position.
function Pix2Geo($nPixPos, $dfPixMin, $dfPixMax, $dfGeoMin, $dfGeoMax,
$nInversePix = false)
$dfWidthGeo = $dfGeoMax - $dfGeoMin;
$dfWidthPix = $dfPixMax - $dfPixMin;
$dfPixToGeo = $dfWidthGeo / $dfWidthPix;
if (!$nInversePix)
$dfDeltaPix = $nPixPos - $dfPixMin;
else
$dfDeltaPix = $dfPixMax - $nPixPos;
$dfDeltaGeo = $dfDeltaPix * $dfPixToGeo;
$dfPosGeo = $dfGeoMin + $dfDeltaGeo;
return ($dfPosGeo);
Best regards,
Bart
Syncera IT Solutions
Postbus 270
2600 AG DELFT
tel.nr.: 015-7512436
email: BEN at Syncera-ITSolutions.nl
>>> Philippe Gondek <philippe.gondek at GMAIL.COM> 06/13/05 16:26 PM >>>
Hi List,
I want to use queryByPoint, but when I try I have this result :
>>>>>>>>>>>Warning: [MapServer Error]: msQueryByPoint(): No matching
record(s) found. in /var/www/localhost/htdocs/sigma/sigma.php on line
64
My second question is when I get the coordonates of my point where I
click it's a number of pixel... How to have my real coordonates???
Thank you all...
Philippe GONDEK
More information about the MapServer-users
