PHPMapscript 4.6 Won't Install
Pascoe,Tim [Burlington]
Tim.Pascoe at EC.GC.CA
Wed Jun 15 12:46:12 EDT 2005
Thanks Emil,
I used Dependency walker, and didn't find anything. I ended up switching back to Mapscript 4.4, and all is fine. Not sure what was wrong, but it sure didn't like it. I used the DLL package bundled with 4.6 too ;(
Timothy Pascoe
Environment Canada / Environnement Canada
Canada Centre for Inland Waters / Centre Canadien des Eaux Intérieures
867 Lakeshore Road / 867, chemin Lakeshore
Burlington, Ontario / Burlington (Ontario)
L7R 4A6
Tel/Tél: (905) 336-6239
Fax/Téléc: (905) 336-4699
E-mail/C. élec: tim.pascoe at ec.gc.ca
Government of Canada/Gouvernement du Canada
This e-mail represents the opinions and views solely held by its author and in no manner may be considered as representing those of his/her employer.
-----Original Message-----
From: taatuut at planet.nl [mailto:taatuut at planet.nl]
Sent: June 15, 2005 12:25 PM
To: Pascoe,Tim [Burlington]
Cc: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: Re: [UMN_MAPSERVER-USERS] PHPMapscript 4.6 Won't Install
Hello Tim,
The MapScript dll is depending on several other dll's (included in the
binary packages).
Check if these are in place in the Windows system32 folder or in the
PATH environment variable.
It looks like in your situation on or more dll's are missing or not
available in the PATH.
A way to debug this, is to run your php page from the command line,
something like:
C:\>C:\php\php.exe C:\path\to\info.php
This way you will receive alert boxes about the missing dependencies.
Regards,
Emil
----- Oorspronkelijk bericht -----
Van: "Pascoe,Tim [Burlington]" <Tim.Pascoe at EC.GC.CA>
Datum: woensdag, juni 15, 2005 5:17 pm
Onderwerp: [UMN_MAPSERVER-USERS] PHPMapscript 4.6 Won't Install
> I've gone through this installation process a number of times, and
> thought I finally had the routine down. However, I have an
> installation that I just can't figure out.
> I'm setting up a test box running Windows Server 2000, IIS,
> Mapserver 4.4, Mapscript 4.6, and PHP 4.3.11. PHP returns a
> regular INFO page so long as I don't have the Mapscript extension
> turned on. As soon as I activate Mapscript, however, no page
> returns, and I eventually get a CGI timeout error. I've searched
> through a number of archives with no luck, started from scratch
> twice, and tested everything I can think of. Has anyone else seen
> this behavior, or have any suggestions?
> Thanks,
> Timothy Pascoe
Intérieures
> L7R 4A6
> his/her employer.
