ASP with server-side scripting in map template
David Shorthouse
dps1 at UALBERTA.CA
Thu Jun 16 07:24:54 PDT 2005
Hey folks,
Is it possible to include server-side vbscript on a map template?
MapServer can use .asp as a map template, but nothing is done with the
scripting I tried to include. In fact, if you look at the source of the
resultant page, the vbscript is clearly visible. My problem is that I'm
stuck with asp and there are a few things I would like to add to the map
template that would be more efficient to do via vbscript than a MapServer
layer.
Thanks for any advice,
David
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20050616/fd3c7a81/attachment.htm>
More information about the MapServer-users
