ASP with server-side scripting in map template
Julien-Samuel Lacroix
jlacroix at DMSOLUTIONS.CA
Thu Jun 16 10:55:36 EDT 2005
It's possible that some people already did that kind of thing. Maybe
they will have better answer.
Currently there's no ASP support in MapServer. You will probably have
more success by calling the MapServer CGI from your ASP script and
modifying whatever it returns.
Julien
On 06/16/2005 10:24 AM, David Shorthouse wrote:
> Hey folks,
> Is it possible to include server-side vbscript on a map template?
> MapServer can use .asp as a map template, but nothing is done with the
> scripting I tried to include. In fact, if you look at the source of the
> resultant page, the vbscript is clearly visible. My problem is that I'm
> stuck with asp and there are a few things I would like to add to the map
> template that would be more efficient to do via vbscript than a
> MapServer layer.
> Thanks for any advice,
> David
Julien-Samuel Lacroix jlacroix at dmsolutions.ca
DM Solutions Group http://www.dmsolutions.ca/
