queryByPoint on a Postgis layer...
Julien-Samuel Lacroix
jlacroix at DMSOLUTIONS.CA
Thu Jun 16 10:28:46 EDT 2005
Is your layer queryable? To do so, it should be "STATUS ON" and have a
template (TEMPLATE "dummy"). You can also set the tolerance to accept
clicks that are a little beside the point you tried to click. For more
information about those parameters, check the mapfile documentation:
http://mapserver.gis.umn.edu/doc44/mapfile-reference.html#layer
You can also check the gmap demo if you need an example.
http://dl.maptools.org/dl/gmap-ms40.tar.gz
Julien
On 06/16/2005 04:29 AM, Philippe Gondek wrote:
> Hi list,
> I have a problem. I want to use the function queryByPoint in Mapscript
> to know the item I clicked.
> $qx = $HTTP_POST_VARS["mapa_x"];
> $qy = $HTTP_POST_VARS["mapa_y"];
> $point = ms_newpointOBj();
> $point->setXY($qx, $qy);
> $layerq = $map->getLayerByName("communes");
> $data = $layerq->queryByPoint($point, MS_SINGLE, -1);
> >>>>>>>>>> I have no result... maybe I must do the connection
> to Postgis by myself... any suggestions???
> echo nl2br("\n data : $datadata_val");
> $result = $layerq->getResult(0);
> echo nl2br("\n result : $result");
> $layerq->open();
> $items = $layerq->getitems();
> echo nl2br("\n items : $items");
> $shape =$layerq->getShape($result->tileindex, $result->shapeindex);
> $layerq->close();
> $data_val = $shape->values;
> echo nl2br("\n data_val : $data_val");
> Thanks and have a nice day...
> Philippe
Julien-Samuel Lacroix jlacroix at dmsolutions.ca
DM Solutions Group http://www.dmsolutions.ca/
