PHP MapScript zoomscale optional parameter
Julien-Samuel Lacroix jlacroix at DMSOLUTIONS.CA
Thu Jun 16 08:09:17 PDT 2005
Simply don't specify the optional parameter is correct. There's a
parameter missing in the documentation.
void zoomscale(double nScale, pointObj oPixelPos, int nImageWidth,
                   int nImageHeight, rectObj oGeorefExt,
                   [rectObj oMaxGeorefExt])
So your problem here is that one parameter is missing:
The fifth parameter (oGeorefExt) is mandatory and the sixth
(oMaxGeorefExt) is optional.
Julien
On 06/15/2005 01:52 PM, Abe Gillespie wrote:
> According to the docs the oGeorefExt parameter of mapObj::zoomscale is
> optional.  How do I send in an optional parameter in PHP?  I've tried
> both of the following with no success:
> $map->zoomscale($scale, $pnt, $w, $h, null);
> and
> $map->zoomscale($scale, $pnt, $w, $h);
> Please help if you can.  Also, and slightly OT, you need to pass in
> the height and width of the image.  This doesn't make sense to me.
> Shouldn't the current height and width of the mapObj be used???
> Thanks for the help.
> -Abe
Julien-Samuel Lacroix            jlacroix at dmsolutions.ca
DM Solutions Group               http://www.dmsolutions.ca/
More information about the MapServer-users mailing list
