file size issue
Jerl Simpson
jerl.simpso at GMAIL.COM
Thu Jun 16 11:32:34 EDT 2005
Yes, I have already tiled the set. And that did help tremendously.
Even if it would be best if THIS layer is not in the DB I have other
uses for extracting data from the database. I just can't get it to
work. I think something is wrong with my DATA string. Well I'm quite
sure of it. I get an internal server error.
I have no idea how to construct the DATA '' string. If someone could
point me to a tutorial I'd be very appreciative.
Thanks,
jerl
On 6/16/05, Julien-Samuel Lacroix <jlacroix at dmsolutions.ca> wrote:
> Hi,
> I think what you are trying to do will be much more efficient if you
> "tile" your shapefile instead of putting all your data in MySQL. The
> tiling separate your big shape into multiple smaller one. When it's time
> to draw them, mapserver will only read the one it needs. Check both:
> http://mapserver.gis.umn.edu/data2/wilma/mapserver-users/0303/msg00885.html
> http://mapserver.gis.umn.edu/cgi-bin/wiki.pl?Tile4ms
> You can also get tips for data optimization from here:
> http://ms.gis.umn.edu/new_users/index_html#data-optimization
> Julien
> On 06/16/2005 09:41 AM, Jerl Simpson wrote:
> > Hello,
> > I have a particular issue with file size limits. I have a layer (2
> > actually) that contains roads classified as "Local Roads" throughout
> > the entire contiguous 48 US states. I had to split this up into 2
> > files due to filesize limits. My apache server keeps throwing errors
> > that say "[notice] child pid 12855 exit signal File size limit
> > exceeded (25)". So I would like to add these to a MySQL table and
> > pull the data from there.
> > I am running into two problems.
> > 1. I used one of my very small shape files to setup an SQL connection
> > to grab the data. When I modified my .map file I now get an internal
> > server error. Which simply means some data was spit out before HTTP
> > headers terminated. I have a log file and DEBUG ON set in my map file
> > and nothing gets placed in the file. Is there any documentation that
> > tells one how to build the queries? I can't seem to find them.
> > 2. The shape file I have for Local Roads is 1.2Gb. And the perl
> > Shapelib module reads the entire shape file into an array. Well, I
> > don't have 1.2Gb of memory on my machine available so when I run
> > "shp2mysql.pl LocalRoad" the program terminates with the error
> > "Terminated". I looked at the documentation and I don't see a way to
> > just grab records out of the file. I tried get_record() but that
> > threw error messages.
> > I have a tiled this file into 100 smaller files the largest of which
> > is 63Mb. I could write a script to run to shp2mysql.pl on each file.
> > I would rather have a program to operate on the original file though,
> > as I'm afraid I'll end up with 100 seperate tables with the same data.
> > Or I would need to modify the script to foce them all into the same
> > table.
> > I appreciate any help,
> > jerl
> Julien-Samuel Lacroix jlacroix at dmsolutions.ca
> DM Solutions Group http://www.dmsolutions.ca/
