file size issue
Julien-Samuel Lacroix
jlacroix at DMSOLUTIONS.CA
Thu Jun 16 11:50:02 EDT 2005
I never successfully used the MySQL datasource support in MapServer. The
documentation is here:
http://mapserver.gis.umn.edu/cgi-bin/wiki.pl?MySQL
I don't think there's any tutorial.
Most of the people usually go with PostGIS instead of MySQL. There's
more people to help with it.
You can also consider using a OVF connection to connect to your data. My
experience with it is that is very stright forward and easy to use.
Documentation:
http://mapserver.gis.umn.edu/cgi-bin/wiki.pl?VirtualSpatialData
Julien
On 06/16/2005 11:32 AM, Jerl Simpson wrote:
> Yes, I have already tiled the set. And that did help tremendously.
> Even if it would be best if THIS layer is not in the DB I have other
> uses for extracting data from the database. I just can't get it to
> work. I think something is wrong with my DATA string. Well I'm quite
> sure of it. I get an internal server error.
> I have no idea how to construct the DATA '' string. If someone could
> point me to a tutorial I'd be very appreciative.
> Thanks,
> jerl
> On 6/16/05, Julien-Samuel Lacroix <jlacroix at dmsolutions.ca> wrote:
>>Hi,
>>I think what you are trying to do will be much more efficient if you
>>"tile" your shapefile instead of putting all your data in MySQL. The
>>tiling separate your big shape into multiple smaller one. When it's time
>>to draw them, mapserver will only read the one it needs. Check both:
>>http://mapserver.gis.umn.edu/data2/wilma/mapserver-users/0303/msg00885.html
>>http://mapserver.gis.umn.edu/cgi-bin/wiki.pl?Tile4ms
>>You can also get tips for data optimization from here:
>>http://ms.gis.umn.edu/new_users/index_html#data-optimization
>>Julien
>>On 06/16/2005 09:41 AM, Jerl Simpson wrote:
>>>Hello,
>>>I have a particular issue with file size limits. I have a layer (2
>>>actually) that contains roads classified as "Local Roads" throughout
>>>the entire contiguous 48 US states. I had to split this up into 2
>>>files due to filesize limits. My apache server keeps throwing errors
>>>that say "[notice] child pid 12855 exit signal File size limit
>>>exceeded (25)". So I would like to add these to a MySQL table and
>>>pull the data from there.
>>>I am running into two problems.
>>>1. I used one of my very small shape files to setup an SQL connection
>>>to grab the data. When I modified my .map file I now get an internal
>>>server error. Which simply means some data was spit out before HTTP
>>>headers terminated. I have a log file and DEBUG ON set in my map file
>>>and nothing gets placed in the file. Is there any documentation that
>>>tells one how to build the queries? I can't seem to find them.
>>>2. The shape file I have for Local Roads is 1.2Gb. And the perl
>>>Shapelib module reads the entire shape file into an array. Well, I
>>>don't have 1.2Gb of memory on my machine available so when I run
>>>"shp2mysql.pl LocalRoad" the program terminates with the error
>>>"Terminated". I looked at the documentation and I don't see a way to
>>>just grab records out of the file. I tried get_record() but that
>>>threw error messages.
>>>I have a tiled this file into 100 smaller files the largest of which
>>>is 63Mb. I could write a script to run to shp2mysql.pl on each file.
>>>I would rather have a program to operate on the original file though,
>>>as I'm afraid I'll end up with 100 seperate tables with the same data.
>>> Or I would need to modify the script to foce them all into the same
>>>table.
>>>I appreciate any help,
>>>jerl
>>Julien-Samuel Lacroix jlacroix at dmsolutions.ca
>>DM Solutions Group http://www.dmsolutions.ca/
