ASP with server-side scripting in map template
    Ed McNierney
    ed at TOPOZONE.COM
    Thu Jun 16 08:56:54 PDT 2005
David -
No, you can't do that.  Your Web server will run one processor/handler
for each page request.  You're essentially trying to send *one* HTTP
request to a CGI program, and then have the ASP output of that program
treated as if it were an ASP source page, and run through the ASP
processor.  That's double-dipping.
However, most of the MapServer template functionality allows you to do
pretty powerful things WITHOUT a scripting language.  If you've already
got a scripting language like ASP, you can just do those things in ASP.
The easiest way (IMHO) to do this is to have your ASP code generate the
"template" output, and insert the appropriate IMG tags with SRC
properties specifying MapServer CGI requests, like:
<img src="mapserv.exe?mode=scalebar&....">
where you'd like to insert the scalebar in the output HTML generated by
your ASP page.
     - Ed
Ed McNierney
President and Chief Mapmaker
TopoZone.com / Maps a la carte, Inc.
73 Princeton Street, Suite 305
North Chelmsford, MA  01863
ed at topozone.com
(978) 251-4242
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On
Behalf Of David Shorthouse
Sent: Thursday, June 16, 2005 10:25 AM
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: [UMN_MAPSERVER-USERS] ASP with server-side scripting in map
template
Hey folks,
    Is it possible to include server-side vbscript on a map template?
MapServer can use .asp as a map template, but nothing is done with the
scripting I tried to include. In fact, if you look at the source of the
resultant page, the vbscript is clearly visible. My problem is that I'm
stuck with asp and there are a few things I would like to add to the map
template that would be more efficient to do via vbscript than a
MapServer layer.
Thanks for any advice,
David
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20050616/761a83cd/attachment.htm>
More information about the MapServer-users
