Running different versions on Windows simultaneously
Jacob Delfos
jacob.delfos at MAUNSELL.COM
Fri Jun 17 04:52:11 EDT 2005
Hi All,
I am about to set up a new internal server for running mapserver-based sites, and I am trying to do it such that I can run different versions of php_mapscript (and mapserver).
The problem I am running into is that certain versions of the dll are compiled against certain of its dependent dll's. For example, php_mapscript_46 works fine with the gdal12.dll that comes with it, but not with the dll I compiled for php_mapscript_44. And one gdal12.dll will only work with the ecw dll's it was compiled with.
I have tried keeping them in separate directories. This nearly worked, but for some reason gdal12.dll MUST sit in the windows System directory (even if you set up your paths correctly). I cannot just sit with the php_mapscript dll. The same goes for some other dll's. Even if the dependency walker says that all is fine, the website will not run unless it sits in system32.
Has anyone been able to implement this more successfully? Any tips?
Regards,
Jacob
JACOB DELFOS
SPATIAL INFORMATION ANALYST
Maunsell Australia Pty Ltd
629 Newcastle Street, Leederville, WA 6007
PO Box 81, Leederville, WA 6902
Western Australia
ABN 20 093 846 925
Tel + 61 8 9281 6185
Fax + 61 8 9281 6297
jacob.delfos at maunsell.com
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20050617/f3aed35d/attachment.html
