CGI error.
Siddharth Parekh
sid.parekh at ERMAPPER.COM
Fri Jun 17 07:22:49 EDT 2005
Hi Emil,
I assume that the enabling the Mapserver debugging means going through the
IIS and right clicking to properties of .map file to "log access", "read",
"write" and "script source access".
Everything is enabled.
In the file security tab, Anonymous access is set to IUSR_<machinename>.
The option is checked for "Allow IIS to control password".
There is write access to the folder that contains the .map file and I assume
that the log file will be written to that.
The checkbox in unchecked for "Show friendly HTTP error messages".
If this is what is expected of the procedure, then how else can I track the
error.
Thanks in advance,
Cheers,
Siddharth Parekh
Programmer Analyst
ER Mapper
2 Abbotsford Street
West Leederville WA 6007
Australia
Tel: +61 8 9388 2900
Fax: +61 8 9388 2901
Email: Sid.Parekh at ermapper.com
http://www.ermapper.com (ER Mapper Home)
http://www.EarthEtc.com (Image Web Server)
http://forum.ermapper.com (Public Forum)
Just released: ER Mapper 7, Image Web Server 7,
RightWebMap 7 and ECW JPEG 2000 SDK 3.1
Visit www.ermapper.com for more information
-----Original Message-----
Sent: Friday, June 17, 2005 6:32 PM
To: Siddharth Parekh; MAPSERVER-USERS at LISTS.UMN.EDU
Subject: RE: [UMN_MAPSERVER-USERS] CGI error.
Hello Siddharth,
Have you enabled Mapserver debugging in your .map file? This will give you a
log file with request info and error messages (when you're using IIS make
sure the IUSR_<machinename> has write rights on the log file and enable
write rights for the folder containing the log file in the IIS management
console. When you are using Windows authentication and you are an
administrator testing the site on the local host this is not necessary).
This may give you more specific information about what is going wrong.
Also when you use Internet Explorer make sure you turned of 'Show friendly
HTTP error messages' under menu Tools/Internet Options/Advanced
With more debug info it might be easier to find the cause of your problem.
Regards,
Emil
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU]On
Behalf Of Siddharth Parekh
Sent: vrijdag 17 juni 2005 12:07
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: Re: [UMN_MAPSERVER-USERS] CGI error.
There is a link in the README-install.txt for demos.
http://maps.dnr.state.mn.us/mapserver_demos/workshop.zip
This is the demo that is causing the crash message and the CGI error as
detailed in the previous mails.
Cheers.
Siddharth Parekh
Programmer Analyst
ER Mapper
2 Abbotsford Street
Australia
Behalf Of Bart van den Eijnden
Sent: Friday, June 17, 2005 6:01 PM
Okay, just checking.
Can you be more specific on which demo you are using?
Best regards,
Bart
Syncera IT Solutions
Postbus 270
2600 AG DELFT
tel.nr.: 015-7512436
email: BEN at Syncera-ITSolutions.nl
>>> Siddharth Parekh <sid.parekh at ERMAPPER.COM> 06/17/05 11:57am >>>
On running from the command line, it doesnt show me any crash message.
It displays
This script can only be used to decode form results and
should be initiated as a CGI process via a httpd server.
And on running mapserv -v it displays
MapServer version 4.4.1 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
OUTPUT=PDF
OUTPUT=SWF SUPPORTS=PROJ SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER
SUPPORTS=WMS_CLI
ENT SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT SUPPORTS=WCS_SERVER INPUT=EPPL7
INPU
T=POSTGIS INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE DEBUG=MSDEBUG
This isn't an error.
On running through the browser, it displays, "No query information to
decode. QUERY_STRING not set.".
Initially, it asked me that msvcr70.dll is missing.
I downloaded it and still it doesn't work.
Any further ideas?
Thanks in advance.
Siddharth Parekh
Programmer Analyst
ER Mapper
2 Abbotsford Street
Australia
From: Bart van den Eijnden [mailto:BEN at Syncera-ITSolutions.NL]
Sent: Friday, June 17, 2005 5:44 PM
To: sid.parekh at ERMAPPER.COM; MAPSERVER-USERS at LISTS.UMN.EDU
This is probably due to a missing dependency.
Does mapserv.exe run from the command-line? Can you run mapserv.exe in the
browser and does it come back with No query information etc.?
Otherwise check with a dependency tool like depends.
Best regards,
Bart
Postbus 270
2600 AG DELFT
>>> Siddharth Parekh <sid.parekh at ERMAPPER.COM> 06/17/05 11:29am >>>
Hey everyone,
I downloaded Mapserver 4.4.1 (ms441pg.zip) from
http://mapserver.gis.umn.edu/ and installed it as described in the
Install.txt.
On running a mapserver demo, it pops up with a crash message and then
browser displays error:
CGI Error
The specified CGI application misbehaved by not returning a complete set of
HTTP headers. The headers it did return are:
I even reinstalled everything from scratch, but no help.
I am installing it on Win XP SP2.
Any ideas?
Has this issue been resolved by someone?
Can someone throw some light on it?
Thanks in advance.
Siddharth Parekh
Programmer Analyst
ER Mapper
2 Abbotsford Street
Australia
