CGI error.
Emil Zegers
taatuut at PLANET.NL
Fri Jun 17 07:46:29 EDT 2005
Hello Siddarth,
You can enable MapServer debugging by setting DEBUG ON in the .map
file for the MAP, LAYER and CLASS objects you want to debug and adding
a LOG parameter in the WEB object pointing to a file where the log
info will be stored (you can use abdolute or relative paths, this file
needs write access for the IUSR).
See also:
http://mapserver.gis.umn.edu/cgi-bin/wiki.pl?DebuggingMapserver
http://mapserver.gis.umn.edu/doc44/mapfile-reference.html (serach for
DEBUG and LOG)
Now you will get a log file with MapServer log info.
Another handy tool to monitor running programs is filemon from
www.sysinternals.com
Install it and run it and don't forget to use a filter on the name of
your MapServer executable or you will have to dig to giant loads of
log info (sometimes necessary though to not use a filter).
Regards,
Emil
----- Oorspronkelijk bericht -----
Van: Siddharth Parekh <sid.parekh at ERMAPPER.COM>
Datum: vrijdag, juni 17, 2005 1:22 pm
Onderwerp: Re: [UMN_MAPSERVER-USERS] CGI error.
> Hi Emil,
> I assume that the enabling the Mapserver debugging means going
> through the
> IIS and right clicking to properties of .map file to "log access",
> "read","write" and "script source access".
> Everything is enabled.
> In the file security tab, Anonymous access is set to
> IUSR_<machinename>.The option is checked for "Allow IIS to control
> password".There is write access to the folder that contains the
> .map file and I assume
> that the log file will be written to that.
> The checkbox in unchecked for "Show friendly HTTP error messages".
> If this is what is expected of the procedure, then how else can I
> track the
> error.
> Thanks in advance,
> Cheers,
> Siddharth Parekh
> Programmer Analyst
> ER Mapper
> 2 Abbotsford Street
> West Leederville WA 6007
> Australia
> Tel: +61 8 9388 2900
> Fax: +61 8 9388 2901
> Email: Sid.Parekh at ermapper.com
> http://www.ermapper.com (ER Mapper Home)
> http://www.EarthEtc.com (Image Web Server)
> http://forum.ermapper.com (Public Forum)
> Just released: ER Mapper 7, Image Web Server 7,
> RightWebMap 7 and ECW JPEG 2000 SDK 3.1
> Visit www.ermapper.com for more information
> -----Original Message-----
> From: Emil Zegers [mailto:taatuut at planet.nl]
> Sent: Friday, June 17, 2005 6:32 PM
> To: Siddharth Parekh; MAPSERVER-USERS at LISTS.UMN.EDU
> Subject: RE: [UMN_MAPSERVER-USERS] CGI error.
> Hello Siddharth,
> Have you enabled Mapserver debugging in your .map file? This will
> give you a
> log file with request info and error messages (when you're using
> IIS make
> sure the IUSR_<machinename> has write rights on the log file and
> enablewrite rights for the folder containing the log file in the
> IIS management
> console. When you are using Windows authentication and you are an
> administrator testing the site on the local host this is not
> necessary).
> This may give you more specific information about what is going
wrong.
> Also when you use Internet Explorer make sure you turned of 'Show
> friendlyHTTP error messages' under menu Tools/Internet
> Options/Advanced
> With more debug info it might be easier to find the cause of your
> problem.
> Regards,
> Emil
> From: UMN MapServer Users List [mailto:MAPSERVER-
> USERS at LISTS.UMN.EDU]OnBehalf Of Siddharth Parekh
> Sent: vrijdag 17 juni 2005 12:07
> To: MAPSERVER-USERS at LISTS.UMN.EDU
> Subject: Re: [UMN_MAPSERVER-USERS] CGI error.
> There is a link in the README-install.txt for demos.
> http://maps.dnr.state.mn.us/mapserver_demos/workshop.zip
> This is the demo that is causing the crash message and the CGI
> error as
> detailed in the previous mails.
> Cheers.
> Siddharth Parekh
> Programmer Analyst
> ER Mapper
> 2 Abbotsford Street
> Australia
> USERS at LISTS.UMN.EDU]OnBehalf Of Bart van den Eijnden
> Sent: Friday, June 17, 2005 6:01 PM
> Okay, just checking.
> Can you be more specific on which demo you are using?
> Best regards,
> Bart
> Syncera IT Solutions
> Postbus 270
> 2600 AG DELFT
> tel.nr.: 015-7512436
> email: BEN at Syncera-ITSolutions.nl
> >>> Siddharth Parekh <sid.parekh at ERMAPPER.COM> 06/17/05 11:57am >>>
> On running from the command line, it doesnt show me any crash
message.
> It displays
> This script can only be used to decode form results and
> should be initiated as a CGI process via a httpd server.
> And on running mapserv -v it displays
> MapServer version 4.4.1 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
> OUTPUT=PDF
> OUTPUT=SWF SUPPORTS=PROJ SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER
> SUPPORTS=WMS_CLI
> ENT SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT SUPPORTS=WCS_SERVER
> INPUT=EPPL7INPU
> T=POSTGIS INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE DEBUG=MSDEBUG
> This isn't an error.
> On running through the browser, it displays, "No query information to
> decode. QUERY_STRING not set.".
> Initially, it asked me that msvcr70.dll is missing.
> I downloaded it and still it doesn't work.
> Any further ideas?
> Thanks in advance.
> Siddharth Parekh
> Programmer Analyst
> ER Mapper
> 2 Abbotsford Street
> Australia
> From: Bart van den Eijnden [mailto:BEN at Syncera-ITSolutions.NL]
> Sent: Friday, June 17, 2005 5:44 PM
> To: sid.parekh at ERMAPPER.COM; MAPSERVER-USERS at LISTS.UMN.EDU
> This is probably due to a missing dependency.
> Does mapserv.exe run from the command-line? Can you run
> mapserv.exe in the
> browser and does it come back with No query information etc.?
> Otherwise check with a dependency tool like depends.
> Best regards,
> Bart
> Postbus 270
> 2600 AG DELFT
> >>> Siddharth Parekh <sid.parekh at ERMAPPER.COM> 06/17/05 11:29am >>>
> Hey everyone,
> I downloaded Mapserver 4.4.1 (ms441pg.zip) from
> http://mapserver.gis.umn.edu/ and installed it as described in the
> Install.txt.
> On running a mapserver demo, it pops up with a crash message and then
> browser displays error:
> CGI Error
> The specified CGI application misbehaved by not returning a
> complete set of
> HTTP headers. The headers it did return are:
> I even reinstalled everything from scratch, but no help.
> I am installing it on Win XP SP2.
> Any ideas?
> Has this issue been resolved by someone?
> Can someone throw some light on it?
> Thanks in advance.
> Siddharth Parekh
> Programmer Analyst
> ER Mapper
> 2 Abbotsford Street
> Australia
