JOIN - hope to receive an answer... maybe from a developer
william paul
williampaul28 at YAHOO.COM
Fri Jun 17 10:49:44 EDT 2005
I am not very advanced with MAPSEVER, but still...
Does anyone have EVER successfully used JOIN OBJECT? I want to join a DBF with a SHP (MULTIPLE JOIN)
In Mapserver reference file (http://mapserver.gis.umn.edu/doc44/mapfile-reference.html#join) it is written "Joins are defined within a query object." WHAT IT MEANS? the map file should look like:
LAYER
QUERY
JOIN
etc
I tried like this but I receive the error :loadLayer(): Unknown identifier. Parsing error near (QUERY)
obvious the map file should look different
I have the shape (COUNTY.SHP) file with the following fields (ITEMS): SHAPE, CODE
I have the DBF (CODE.DBF) file with the following fields (ITEMS): CODE, COUNTY, TOWN, YEAR
I wanted to join them (MULTIPLE JOIN=ONE TO MANY), so I used as Mapserver reference say:
LAYER
HEADER 'templates/code_header.html'
FOOTER 'templates/code_footer.html'
TOLERANCE 3
CLASS
COLOR 200 0 200
SIZE 10
SYMBOL "circule"
TEMPLATE 'templates/code.html'
END
JOIN
FROM CODE
NAME CODE_JOIN
TABLE "E:\mapserver\shp\CODE.DBF"
TEMPLATE "templates\CODE.HTML"
TO CODE
TYPE multiple
END
I receive the following result:
CODECOUNTYTOWNYEAR11026[COUNTY][TOWN][YEAR]
If I comment the TEMPLATE from JOIN nothink happend, but if I comment the TEMPLATE from CLASS I get the error: msQueryByRect(): Search returned no results. No matching record(s) found.
WHAT is happening? What and where I do wrong?
DOES ANY ONE HAVE A WORKING EXAMPLE? I MEAN SOME ONE WHO USED OR USE JOIN OBJECT
There are any other ways to JOIN (ONE TO MANY) data?
Thank you in advance
William
Yahoo! Mail
Stay connected, organized, and protected. Take the tour
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20050617/b6f8b7e3/attachment.html
