RES: [UMN_MAPSERVER-USERS] RES: [UMN_MAPSERVER-USERS] [PHP
MapScript] Problem with ms_newShapefileObj and path with special
characters
Murilo Lacerda Yoshida
murilo.yoshida at AGX.COM.BR
Fri Jun 17 11:54:18 EDT 2005
So maybe the problem is that I am escaping the parenthesis when I
create the shape ...
I will test here, in my script, for the same shapefile name and path,
it executes
ms_newShapefileObj("/home/test/Hiro´s_Test/Teste\(blablabla:\)_\)/datat
esteShapeFile",MS_SHP_POLYGON);
Ok, thanks a lot, I'll test here.
Murilo
-----Mensagem original-----
De: Julien-Samuel Lacroix [mailto:jlacroix at dmsolutions.ca]
Enviada em: sexta-feira, 17 de junho de 2005 11:49
Para: Murilo Lacerda Yoshida
Cc: MAPSERVER-USERS at LISTS.UMN.EDU
Assunto: Re: [UMN_MAPSERVER-USERS] RES: [UMN_MAPSERVER-USERS] [PHP
characters
It worked fine for me. Here what I did. Note that I also escaped the
':'. I used 4.6 on RedHat 9.
$ cd /home/test/
$ mkdir Hiro´s_Test/
$ cd Hiro´s_Test/
$ mkdir Teste\(blablabla\:\)_\)
$ cd Teste\(blablabla\:\)_\)/
$ ls
$ pwd
/home/test/Hiro´s_Test/Teste(blablabla:)_)
### Here I ran the following script
### dl("php_mapscript.so");
ms_newShapefileObj("/home/test/Hiro´s_Test/Teste(blablabla:)_)/datatest
### exit;
$ ls
datatesteShapeFile.shp datatesteShapeFile.shx
Julien
On 06/17/2005 10:36 AM, Murilo Lacerda Yoshida wrote:
> Sorry, I forgot to put the quotes on the example ..
> You tested the cration with this name
> ("Hiro´s_TestTeste(blablabla:)_)datatesteShapeFile"), right?
> Please try with this name ("testeShapeFile") in the path
> ("/home/test/Hiro´s_Test/Teste(blablabla:)_)/data"). You'll have to
> escape the parenthesis to create the path.
> The problem I had wasn't on the shapefile name, was in the path to
it.
> Thanks,
> Murilo
> Enviada em: sexta-feira, 17 de junho de 2005 10:53
> Cc: MAPSERVER-USERS at lists.umn.edu
> Assunto: Re: [UMN_MAPSERVER-USERS] [PHP MapScript] Problem with
> ms_newShapefileObj and path with special characters
> Hi,
> I tried to create a shapefile and it work in PHP MapScript and it
> worked.
ms_newShapefileObj("/home/test/Hiro´s_TestTeste(blablabla:)_)datatesteS
> Note that I added the opening and closing quotes and that this path
> (/home/test/) is an existing path where the webserver as the right to
> write.
> Julien
> On 06/16/2005 07:18 PM, Murilo Lacerda Yoshida wrote:
>> Hi all,
>> I tried to create a shapefile using a path with special characters
> in
>>a linux system, all escaped by backslashes (\).
>> The problem is that the ms_newShapefileObj function doesn't appear
> to
>>work with this kind of path ... I tried to create a regular file using
>>the same path and the same name as the failed shapefile in a terminal,
>>and it worked fine.
>> Is it a bug? Did somebody had this problem?
>> Example:
ms_newShapefileObj(/teste/mapas/btg/Hiro´s_Test/Teste\(blablabla:\)_\)/d
>>ata/testeShapeFile,MS_SHP_POLYGON);
>> Thanks in advance,
>> Murilo
Julien-Samuel Lacroix jlacroix at dmsolutions.ca
DM Solutions Group http://www.dmsolutions.ca/
